The end of 3G cellular
Discussion in 'Prime Technical Discussion' started by Old Bear, Dec 23, 2021.
  1. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I know that the telematics and Entune remote functions for my 2017 Prius Prime Advanced run over the Verizon cellular network, but I do not know if the link between Toyota's servers and the Prime uses 3G or 4G service.
    This is important as explained by Boston Globe technology columnist Hiawatha Bray in his December 23rd column:
    When millions of obsolete mobile phones stop working next year, they’ll have plenty of company.
    In 2022, the nation’s wireless carriers will shut down their 3G data networks to make room for better 4G and 5G services. The transition will affect not only phones, but also countless other devices that rely on 3G data links — home security systems, medical alert devices for senior citizens, the driver assistance systems inside many cars, and even the ankle bracelets used by law enforcement agencies to keep track of parolees. . .
    . . . And then there are Internet-connected cars. Again, it’s unclear how many such vehicles rely on 3G networks. But in a filing with the FCC, the Alliance for Automotive Innovation said that about 260,000 vehicles from a single brand, the luxury carmaker Jaguar Land Rover, could be hit by the 3G shutdown. The alliance also noted that Jaguar Land Rover holds less than 1 percent of the US auto market, suggesting that the total number of cars with 3G service is probably much higher.
    The impact of the 3G shutdown won’t be limited to older cars. Automakers have installed 3G systems in some vehicles as recently as the 2019 model year, long after 4G had entered the mainstream. Major carmakers say they’re reaching out to vehicle owners and warning them of the coming change. Some 3G vehicles already have compatible cellular hardware, and only need a software upgrade. Others may require installation of a new module. Tesla, for instance, charges $200 to put a 4G system in its older cars. Still other vehicles . . . can’t be upgraded at all.
    Does anyone know if any of the Prime model years will be affected by this?
    Bill Norton and privilege like this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    My Volt has “edge”
    Never could understand the immense desire by auto makers to use 20+ year old telematics on modern cars.
    Leafs through 2015 went dead a few years ago
  3. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    I wish Prime telematics are 3G... Then I did not have to opt-out of the Connected Service. It is not 3G, even in 2017 Prime. So, as long as you keep paying Connected service subscription fees, you will be OK at least until 4G gets shut down.
    Old Bear likes this.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    The only Prius models in the list on Toyota’s 3G Network Retirement page are the 2012–2016 Prius v, 2012–2015 Prius Plug-in, and 2010–2016 Prius.
    Sapphire Dragon and Old Bear like this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,496
    2,471
    Taylors, SC
  6. fuzzy1
    10,577
    Somehow late last year, I missed the push-back of these 3G shutdown dates, so was in a mad scramble to get my Tracfone (VMNO on Verizon) switched over before the shutdown that I thought was coming at the end of 2020. And that was already a push-back from an earlier 'firm date' of 12/31/2019.
    Though I did see then that AT&T wasn't shutting down its 3G until early 2022, so didn't around to getting the spouse's Tracfone (VMNO'ed on AT&T) switched over until this past autumn.
    Here is another item giving shut-off dates already in the past. It isn't like this is a surprise to the industry, and they can't keep pushing back the dates over and over again forever.
  7. CharlesH
    2,797
    1,164
    Roseville, CA
    When some folks looked up the part numbers for the 2017 Advanced telematics unit a while ago, the FCC ID showed it as using 4G (LTE). And it is not on the "kill" list mentioned above. So they will be happy to keep on taking the SafetyConnect fees from those owners.
  8. Gokhan
    Gokhan Senior Member
    6,467
    2,581
    Paramount CA
    None affected. All US Prius Prime models 2017–2022 have LTE.
    86740
    Mobile Phone Control Module
    ZVW51..G,H
    TELEMATICS-WITH(LTE)
    Part Number: 86740-47160
    TELEPHONE & MAYDAY. 2021 Toyota Prius Prime | Toyota
  9. Old Bear
    712
    1,050
    That's good news. (And thanks to both Elektroingenieur and Georgina Rudkus for the details and list.)
    I believe Verizon's 4G-LTE will be around for a while until many more of their customers switch their phones to newer the 5G models.
    (Kind of scary considering that the landline network is designed to be sufficiently backward-compatible that you could plug a Model 50AL candlestick phone made a century ago into a fiber optic Optical Network Terminal and still have it work.)
    Georgina Rudkus likes this.
  10. Georgina Rudkus
    3,496
    2,471
    Taylors, SC
    As I recall from my dad, who has an extensive collection of antique phones, the Western Electric "vertical desk stand" was designated 20L, not 50L. I have one in my collection that my dad gave me.
    Very rare is the Model AA-1 with a cradle mounted to a cut off 20L. More common is the first custom handset cradle base (round) designated as the 102. That was superseded by the oval base 202.
    I even have a 20L converted with a 3A clickety dial.
  11. fuzzy1
    10,577
    Thanks for the link illustrating the models. So the dial (not touch-tone) phone I unplugged just a year ago last week, was the not-nearly-as-old Model 500.
    I unplugged it (along with a couple modern units) only because it was time to tell the landline company to stick it where the sun don't shine, as they were degrading the associated DSL service to 'encourage' us to upgrade to optic fiber, but then didn't actually have fiber service on my street. Bye-bye to both your internet, and your landline too.
    I think that phone is still in service at a friend's house, where an extension is useful.
  12. Georgina Rudkus
    3,496
    2,471
    Taylors, SC
    The 300 and the 500 were designed by Henry Drefus, the industrial designer who did the Honeywell round thermostat.
    The 300 had a concave body, while the 500 had a convex body. We have two 5300's in our collections. The 5300 was a modernized convex body that fitted over the inner works of the 300. It is easily distinguished in that there is no "hump" extending out the back of the phone.
    The DTMF (dual tone multi-frequency) touch pad was introduced at the 1964 New York Worlds Fair at the same Flushing Meadows sit ast the 1939 Worlds Fair.
  13. privilege
    privilege Active Member
    659
    169
    Birmingham
  14. privilege
    659
    169
    Birmingham
    I'm looking for the slew of "obsolete" ipads, iPhones and tablets that "won't work on 5g" to hit eBay and swappa.... they'll be great GPS and multi media devices
  15. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I knew I was getting old the day the lights in the bathroom at work wouldn't turn on and the kid who came to fix them told me, "Oh yeah, these switches do that sometimes. You have to reboot them." I was thinking to myself, "If crashing light switches are progress we are in trouble as a species."
    Then I got to thinking, "how could a someone be so incompetent at programming a single-function device with a fixed and known hardware that it crashes?" and I felt even more irritated.
    mjoo and Data Daedalus like this.
  16. CharlesH
    2,797
    1,164
    Roseville, CA
    In a commercial setting, the light switches may may be complex enough where they can get hung up and have to be reset. Features like timers, motion sensors, and remote control. Even my home X-10 remote-control light switches sometimes need to be reset. Sometimes a power glitch can get the control logic tied up in knots. Although calling it "reboot" rather than just "reset" may be a stretch.
    Data Daedalus likes this.
  17. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    5g, at least in the US, is a big scam. I'm reading articles recommending to stay on lte for faster speeds and better battery life.
    jerrymildred and Gokhan like this.
  18. Gokhan
    6,467
    2,581
    Paramount CA
    I don't think it is a scam, but my impression is that cell-phone service in the US has never improved ever since the introduction of 3G. There was 3+ G, 4G, 4+ G, and 5G afterwards, and whichever carrier I tried, the service has been miserable with every upgrade. 5+ G and 6G are next, but nothing is going to change. That's because the numbers refer to theoretical performance, but we don't see any performance improvement in practice due to poor infrastructure.
  19. MikeDee
    1,580
    597
    At least for me where I live, Verizon lte was a huge difference from 3g.
    fuzzy1 and Gokhan like this.
  20. Gokhan
    6,467
    2,581
    Paramount CA
    I get impressive rates with Mint Mobile 5G at home, which is on T-Mobile US's network—over 500 Mbit/s download. However, if I go to a shopping center, the signal diminishes and everyone is sharing the network, and I am lucky if I can open webpages. Mint Mobile is hard to beat with $25 a month.
    #20 Gokhan, Dec 30, 2021
