Prius plug in battery only getting 8 miles per charge. Help!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by J wil, Dec 27, 2021.
  1. J wil
    J wil Junior Member
    30
    Punta gorda
    2012 prius plug in advanced with 149,100 miles on it. I sold it to the ex wife...then bought it back. She had not plugged it in for three years. Warranty? Bad cells that need to Be replaced? What do you all think? Btw. This battery has very little time on it. Less than 1percent of the cars life has been on full electric. Thanks for the help. Car was purchased from a dealer in maryland with 20k on it. Since that 20k The car has been in Florida
  2. arttuj
    arttuj Junior Member
    Finland
    2013 Prius Plug-in
    Lithium-ion battery degrades over time even though the battery has not been charged. Battery is affected by extreme heat, cold weather, etc. We have a Prius plug-in 2013. The car was made in Japan in August 2012 so it is pretty much the same car as yours. I bought the car over a year ago with approx 138 000km / 86 000 miles on it. It now has approx 170 000km / 106 000 miles. I did a Dr Prius life expectancy test in May. It gave me 77% capacity left which I think was ok. I got maybe 16km / 10 miles of electric range. Now half a year later I get less than 14km / 8,75 miles of electric range. I have to say that the winter has affected the range a lot. We live in Finland. Summers are sometimes hot, and winters sometimes very cold.
    curtainsales likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Eight miles is a little disappointing, but remember that the EPA rates it at just 11 miles and it is a 10 year old battery, so that really isn't very surprising.
    If there were bad cells, you'd have trouble codes and a light to alert you. So, no warranty without trouble codes even if the warranty hadn't expired two years and 49k miles ago. Probably, they have reduced capacity thanks to heat and time, especially if it was out in the sun. If that's all that's wrong, that's just wear and tear and there's not much you can do about that except to slow future degradation by keeping it out of the heat as much as you can, which ain't easy down here.
    But there is also likely to be imbalance between the cells. If you charge it more than she did, that imbalance might get a little less over time if there's any management taking place while it's charging.
  4. privilege
    privilege Active Member
    659
    169
    Birmingham
    Was it driven during those 3 years ? Plugging in shouldn't matter to the battery life
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    BECAUSE......even when not plugged in, it should use part of the battery's capacity acting like a conventional hybrid.
    THEN....if the 12 V battery is over 5 years old, start looking for a new one.
    And/or get it tested.
    A weak 12 V can make other things look bad when they really aren't.
    I can't help but wonder if actually USING it in electric mode and plugging it in for a couple of months might show slightly more capacity.
  6. privilege
    659
    169
    Birmingham
    I'm not sure if you're agreeing with me or pointing out a failure ?
  7. sam spade 2
    7,035
    2,803
    2017 Prius c
    Both. :)
  8. arttuj
    Finland
    2013 Prius Plug-in
    I forgot to mention that our car still has one year guarantee left on the hybrid battery. In Finland the guarantee is for 10 years / 350 000 km which is 218 750 miles. When maintenance is done by Toyota authorized shop, that activates the guarantee again for one year or 15 000km (= 9375 miles).
  9. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    2012 PIP Advanced here. 85,000 miles. Down to just under 9 miles showing for available EV. I wish it had more, but am accepting this as the norm at this point.
  10. bisco
    51,996
    it depends on where you are getting your information. start by disconnecting the 12v neg for a minute. that will set the battery icon to factory default.
    make sure the tires are pumped up,
    then charge the battery and take it for a drive on 30 mph back roads until the engine comes on.
    don't use any hvac.
    report back here with how many miles it went. i get around 13-14 in nice weather. if you're not, there might be some brake drag or something.
    there is nothing wrong with the battery, other than it's 10 years old, and they do lose a bit of capacity over time.
    dig4dirt likes this.
  11. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    She let the batt drain down and deep cycle. It's ruined by neglect
  12. bisco
    51,996
    not true of the pip hybrid battery
  13. bisco
    51,996
    no response from the o/p
  14. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    It's been a while since I've been on the forum but this thread caught my eye.
    I'm in the same boat as many with my 2012...maybe 9 or so miles range at this point?
    My question: are there any reliable/cost-effective "add-on" battery options to increase our range? I'm not needing a lot more range, but doubling what I have now would get me to town/work/charging options so I'd be running significantly higher EV. I last researched this several years ago and I didn't find anything that looked attractive, but just thought I'd check before heading back into that research again.
    Thanks!
  15. bisco
    51,996
    unfortunately, nothing. when the prime came out, all hope of aftermarket pip enhancement evaporated.
    i'm at 9.9 right now, but it was 14 last fall, and will be agin this spring.
    jerrymildred likes this.
  16. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Too bad. I had hoped someone might have homebrewed some kind of battery add-on, but I'm probably underestimating the complexity/difficulty of something like that.
  17. T1 Terry
    T1 Terry Active Member
    929
    491
    What chemistry is the battery cells? Lithium ion is just a broad name for any chemistry battery that uses the lithium ion exchange as its method of energy storage.
    Need to know if it is LFP or some other chemistry if it is a lithium ion battery, from there I can walk you through a charging regime for each cell to regain the capacity.
    T1 Terry
  18. bisco
    51,996
    everything toyota is proprietary
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    Besides being pretty out of date, they didn't make many PiPs, so even if someone did develop something and every PiP owner bought it, they still wouldn't recoup their investment and make a profit on it.
    Merkey likes this.
  20. T1 Terry
    929
    491
    Seems no one is interested in actually trying to revive their lost capacity .... interesting ...
    T1 Terry
