Dealership used wrong oil - 5k vs 10k?
Discussion in 'Prime Main Forum (2017-2022)' started by PeninsulaPrime, Aug 2, 2021.
  1. PeninsulaPrime
    69
    47
    Washington
    At my first oil change, I noticed that my dealer used 0w-20 oil instead of the 0w-16 technically required by my 2021 Prime. The manual says that this is OK, but that an earlier change must happen if it does.
    Is this correct? Do I really need to pay for an extra oil change because my dealer is too lazy to use the right oil?
  2. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    No, just make sure it's changed with OW-16 at the next oil change. (That's what my manual for my 21 Prius says.) Did you point this out to them when you had it serviced? They should've fixed it, free, for you...it says OW-16 right on the oil fill cap!!
    PeninsulaPrime likes this.
  3. PeninsulaPrime
    69
    47
    Washington
    Oil change interval is reduced to 5k when 0w-20 is used per what I saw, unfortunately.
    I didn't know what oil they used because they f*cked up the check-out process, said they'd email me a receipt, I had to call three times to actually get it... and then saw they used the wrong oil.
  4. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    Most cars are very tolerant of being 1 or even 2 grades thicker (but not thinner) in normal weather
    overseas the manual says to get the oil changed at 5k if you don’t use 0w16
    so no biggie
    Some here will say the dealer did you a service and 5k changes are cheap insurance
    Good Luck
  5. Trollbait
    12,680
    The Prius Prime called for 0W20 when it first arrived.
    Has the engine physically changed since then?
  6. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    From what I've read, yes, it's the same 1.4L engine but is now tweaked to accept the lighter OW16 oil. I have a 17 and 21 Prius and the older one takes OW20 while the new one takes OW16. I don't know what the tweaks are but assume it involves the rings and pistons.
    Trollbait likes this.
  7. Mendel Leisk
    41,901
    I think you're just fine with 0W20. I can't really comment on the oil change interval, because I'd never let ANY weight linger in there, over 6 months or 5K miles.
    douglasjre and Georgina Rudkus like this.
  8. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Yes, I'm a little concerned with the lighter oil but I do oil changes every 6-months (regardless of mileage) so hoping it's not an issue. It'll be interesting to compare the different oils in the cars in the future. (I'm going to get them on the same oil-change schedule.)
  9. burrito
    burrito Active Member
    274
    114
    Lower viscosity oil will give the engine less internal resistance, and, in theory anyway, should result in better gas mileage. My guess is that that's all Toyota really cares about. I mean, they lined the underbody and even gave us hubcaps to reduce wind resistance. I think they just want to be able to publish fuel economy numbers that are better than the competition, as much as possible.
    I don't think the oil you have is a problem at all.
    Take it from me: someone who has never changed their own oil (but I'm preparing to!!).
    douglasjre likes this.
  10. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    I took all 4 off and have not noticed any differences in MPG.
  11. Trollbait
    12,680
    Fuel efficiency is a way of lowering carbon emissions, and the 0w16 oil was in use in Japan first. They are already testing 0w8 there.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I am SURE that you don't have a problem.......and never will because of that tiny difference in the oil.
    Don't worry. Be happy.
    It is likely that your dealer does not put 0W16 in any cars.
  13. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    The next time have the service writer put "0W-16 oil" on the work order. Don't sign it until you see that. Then look at the oil charged to the car on the work order when you get the car back. If it says 0W-20 tell them you won't pay for the job. I'd bet that they buy the 0W-20 cheap in bulk and don't want to use the 0W-16 in more expensive small quantities. In any case there will be a sliver of fuel savings with the 0W-16.
    I've taken hundreds of oil samples for analysis and reviewed the reports of the tests. Oil is good for several years in an oil sump. If anyone has doubts, one or two $30 oil analyses will let one know what's happening. That's cheaper than unneeded oil & filter changes.
    As can be seen, 16 viscosity grade is very slightly lower viscosity at 100°C and 150°C than 20 VG. The main difference is a chemical difference in 16VG, and it must not be used in an engine not made for it (or tested to see that it's suitable). (xW viscosity grades are "Winter" and only get low temperate tests. 0W-x oils pass tests at -35°C and -40°C. A 0W-20 oil meets the 0W cold specs and the 20 hot specs.)
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Maybe, maybe not. You will have NO good way to really tell.
    AND.....this is certainly NOT worth making a big stink over, or even a little stink for that matter.
  15. DOHCtor
    DOHCtor Member
    162
    94
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    I work at a Toyota dealership in Canada, (parts dept.) and the only reason you got 0w20 is because the 0w16 is often on national backorder...
    Don't worry, your Prime will live a happy life even with 0w20 in it. Much better then neglecting oil changes just to have old, soiled 0w16 oil in it anyway...
    Marko!
  16. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    The dealers over here provides full synthetics only in 0W20 and 5W40 for current year Prius models, not Prime though.
    Heck, blend and mineral oils are offered too at a lower oil change interval of 5000 km.
  17. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    When 5W20 first became the standard for Japanese 4 cylinder engines, one of my old-school friends continued to use heavier weight oils because he was convinced that extending mileage was the only concern of the Japanese engineers. The heavier weight oil had a much slower pour rate, especially in cold temps. It was the top end of his engine that suffered, camshaft, valve train, etc. - not the pistons or rings. I was surprised.
    Mendel Leisk and dig4dirt like this.
  18. Mendel Leisk
    41,901
    5W20 was second gen spec, and they've been very reliable. (y)
    FWIW, it's available in synthetic and conventional.
  19. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    This is why I do my own oil changes. I don’t trust shops or dealers to do the right thing. Although very tempting because you don’t save a lot of money doing oil changes yourself and you have to deal with recycling the oil filter and oil. You just know that it was done right. Or may be wrong if you don’t have a mechanical ability. LOL
    Michael Wood likes this.
  20. Mendel Leisk
    41,901
    One thing that's very easy to do, and the immediate consequences are nil, is neglect to put a fresh oil filter in. I know, no one would do that, but it happens; your attention drifts, whatever. If the oil filter housing could be designed so it couldn't be installed without a filter, that'd be great.
    Conversion to spin-on filter more-or-less eliminates that possibility: it's near-impossible to miss, and the consequences are immediate.
