2021 (ending), which tyres in UK
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlexY, Oct 10, 2021.
  1. AlexY
    AlexY Member
    163
    45
    UK
    I did (almost) read lenghty thread by u/Britprius which is excellent source of knowledge but it is almost 10 years old and as usually proposed tyres are no longer made.
    Before I start browsing internet to find what now, I'm asking what you guys can advise for now, I have 16 rims and think I'll go into 205/55/16 option ideally with A in wet and dry grip.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    What were the brand and model of the OEM tires there? I’ve often found the OEM is the best choice if still available.
  3. AlexY
    AlexY Member
    163
    45
    UK
    Still can't make decision.
    At the moment have 2 options:
    Turanza 205/55R16 BST T005 91V
    205/55R16 FALKEN ZE310AEC 94VXL AO
    And I have no clue what was OEM stock fitment 13 years ago but for sure they were not 205/55 and there are better options now.
  4. Another
    1,819
    517
    Naples, Florida
    May be different in UK but try this
    https://tiresetc.com/oem-original-equipment-tires-toyota-prius
  5. dolj
    dolj Senior Member
    8,408
    4,281
    Wellington, New Zealand
    It will almost certainly be irrelevant to the UK market.
    Tires (tyres) are probably one of the most region-specific components that do not translate well across regions.
    Even if a named make and model tire that is available in America (for example), it is more than likely that the same named make and model tyre in the UK (for example) is a totally different tyre. In addition, often a particular manufacturer's models of tire are not available in other countries which also reflects this same idea of regional differences.
  6. Another
    1,819
    517
    Naples, Florida
    Go here and look them up
    Costco
  7. Another
    1,819
    517
    Naples, Florida
  8. AlexY
    AlexY Member
    163
    45
    UK
    Costco added Michelin 205/55 R16 (91)H PRIMACY 4 to the list. I'm not their customer but can source rubber elsewhere.
  9. Another
    1,819
    517
    Naples, Florida
    In the USA Costco site, they usually will list a number of options for any given car and trim level then one of the options will be identified as the Original Specification.
  10. AlexY
    AlexY Member
    163
    45
    UK
    I don't want original spec, 205/55 is bigger than original.
  11. Another
    1,819
    517
    Naples, Florida
    Then don’t buy the OEM.
  12. AlexY
    AlexY Member
    163
    45
    UK
    I never asked about OEM, check my first post above.
  13. Another
    1,819
    517
    Naples, Florida
    I guess I misunderstood your original statement “and as usually proposed tyres are no longer made.” As meaning the tires that came with the car.
  14. AlexY
    AlexY Member
    163
    45
    UK
    Probably I was not clear enough this is about tyres proposed in thread I've refereed.
