Wire ripped after someone stole my cat converter. I believe it’s frm the o2 sensor. What to replace?
Discussion in 'Gen 2 Prius Main Forum' started by Ian Simons, Jan 6, 2022.
Tags:
  1. Ian Simons
    Ian Simons Junior Member
    48
    Lake arrowhead
    After my cat convertor was stolen, a wire was left severed under the car. I was told that the severed wire is likely from the O2 sensor, as it’s a common occurrence when these damm thieves steal the cat. I’m in the process of getting a new cat, and was hoping someone could explain what I should do about the presumably damaged (or stolen) O2 sensor.
    In these type of scenarios, is it just the wire that needs to be replaced/repaired or do I need a new O2 sensor as well? I’m assuming new wiring will come with a sensor?
    Thanks.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,394
    2,372
    Taylors, SC
    You will need a downstream O2 sensor. Instead of screwing it out, the thief just cut the wire and took it with the cat.
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Many will buy an OEM (from a dealership / online) or the Denso equivalent, but some here have used cheap aftermarket sensors as well.
    Will you be doing this job yourself?
  4. Ian Simons
    48
    Lake arrowhead
    Will a replacement part of the downstream O2 sensor come with a new wire?
  5. Ian Simons
    48
    Lake arrowhead
    I’m having a DIY enthusiast friend installing it for me. He told me to get the parts, and he do it, but I didn’t ask about the parts cause I didn’t wanna look dumb. I’m Prius enthusiast.. just not a DYI Prius enthusiast.
  6. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Watch this video first
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    The DENSO 2344623 is your puppy. $49. The wires go under the carpet on the front passenger side floor. It plugs into the car harness on near the passenger side of the center console (under the carpet). Very easy to get to by popping off a bit of trim and lifting the carpet.
    I keep a couple of these on the shelf. You just never know when you'll need one.
    2007 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Oxygen (O2) Sensor | RockAuto
