2010 Wiper motor dead; where to buy replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tart_green, Jan 3, 2022.
  1. tart_green
    tart_green Junior Member
    35
    In the interwebs
    Only the fastest setting work on the front wipers. I guessing the motors are pretty dead. I looked online and cannot find anywhere that sells prius wiper motors. Suggestions?
  2. Mendel Leisk
    41,822
    #2 Mendel Leisk, Jan 3, 2022
    tart_green likes this.
  3. tart_green
    35
    In the interwebs
  4. Mendel Leisk
    41,822
    Not showing 2011 Prius, but maybe worth a gamble.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    You've confirmed it is not the wiper switch???
    REVVL V+ 5G ?
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Agree, if it works on High speed, then there's nothing wrong with the motor.
    On the other hand, it seems that the speed control could be located on the motor unit. Changing the motor unit might work.
    #6 xliderider, Jan 6, 2022
    jzchen likes this.
  7. Kaufam7
    Kaufam7 New Member
    Upstate NY
    2014 Prius v wagon
    I just recently replaced the wiper motor on my Prius. Had to get it from a junk yard. Cost me only $85 and it works great! FYI, be sure you mark the position of the mechanical arms that attach to the old motor before removing it. I didn’t and it cost me a lot of time in trial and error getting the wiper movement correct. Hope you find this helpful!
    xliderider likes this.
