Weird rattling sound when starting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GalenB, Jan 10, 2022.
  1. GalenB
    GalenB New Member
    PA
    My 2010 Prius just started making a weird sound when I start it. It continues while the motor is on. Any idea what it is? I can't find anything loose. The oil level is good.
    Here's a video:
  2. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    IF miles are 150 to 180 most likely headgasket is blown
    or could be dirty EGR cooler
    or could be cloged egr intake ports
    fastest way to confirm headgasket is to check you coolant if it is low your engine is likely done.
    cost is about 1600 to 2800 at a shop. for that price I would just replace the engine with a gen 4
  3. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    It's called the Engine Rattle Cold Start issue.
    There are many videos and many post on how people try to make it better but no exact fix.
    I would start with the EGR system cleaning first, like mentioned above.
    #3 rrg, Jan 11, 2022
  4. ChapmanF
    18,458
    Because of the way the Prius powertrain works, engine misfires from any cause will result in horrible-sounding rattles. The reason there has been no one exact fix found is that there is no one exact reason engines misfire.
    Another thread just today demonstrated that one reason for an engine misfire can be that somebody did recent work on the intake and forgot to put two bolts back in. :) Probably not going to be the explanation in most other cars, but it goes to show the variety of things that can cause misfires, and the importance of not jumping to narrow conclusions too quickly.
    One constant, though, is that misfiring isn't good for the engine, catalytic converter, or powertrain, and so it is worth making a good effort to find the cause before letting it go on too long.
    Here's a classic old article where somebody let a pretty good car go for scrap price after overlooking a very inexpensive reason for misfiring.
    Starting on page 15 of this Toyota Tech issue, there are a bunch of tips given on how to reproduce and isolate the engine conditions where misfiring is happening.
  5. Mendel Leisk
    41,826
    How many miles on it? Ever cleaned the Exhaust Gas Recirculation system, or Intake Manifold? See first link in my signature*.
    * If viewing on phone, turn to landscape orientation to view sig's.
  6. GalenB
    GalenB New Member
    PA
    Thank you all for replying! I'll check out all the links and see if we can figure this out. Your help is greatly appreciated!!
  7. Mendel Leisk
    41,826
    Good luck with it. Again: what's the miles on it? If it's over 100K you're getting into EGR clog territory. If over 150K it's pretty much a certainty you've got advanced clogging.
  8. Abarnabe
    Abarnabe Active Member
    169
    100
    Netherlands
    Does it always occur on start up? I have a similar sound if I shut down improperly, I mean if I shut down while the ice charging from 40% to 50%, if that is the case, wait until the ice stops before shutting down and the rattle won't replicate the next start up.
  9. Mendel Leisk
    41,826
    I've experienced that, suspect it's "another of the many roads that leads to Rome". Maybe that short-cycliing of the the engine does the same as a failing head gasket: leaves a little (uncompressible) liquid in a cylinder.
    Abarnabe likes this.
  10. ChapmanF
    18,458
    If you do venture into EGR system cleaning, it would be very helpful if you could contribute both the before-cleaning and after-cleaning flow test numbers, and your mileage, over on the thread we have for that purpose.
    Many diagnostic scan tools and phone apps are able to pull up those numbers; you don't need something specialized and it isn't hard. But it does take a bit of forethought; obviously, you won't be able to post the before-cleaning value if it is an afterthought when you've already cleaned.
    For the time being, rules of thumb like "over 150K it's pretty much a certainty you've got advanced clogging" are kind of because-Mendel-says-so statistics, but the more actual data we can collect, the sooner we will have good quantified ones to serve that purpose.
  11. Lkb1450
    Lkb1450 New Member
    Asheville NC
    Is EGR cleaning a good place to start diagnostics for a cold start rattle that doesn't throw codes?
  12. ChapmanF
    18,458
    No, because EGR clogging isn't, itself, a cause of cold-start rattling.
    Whether or not you believe, as some do, that dirty EGR may lead to a head-gasket failure, keep in mind that's a separate failure then, and isn't going to un-fail because someone cleans the EGR after the fact. If head gasket failure is what's causing cold-start rattles, head gasket failure is what has to be fixed.
    If you do find a head gasket failure and decide to fix it, you'll probably want to clean the EGR at the same time, just in case the EGR clogging ⇒ gasket failure connection is real, so the new gasket will last. But to try cleaning EGR beforehand as a diagnostic step would be to misunderstand the sequence of events.
    On the other hand, the awful rattling sound accompanies misfiring from any cause, and head gasket failure is far from the only cause of misfiring. So the best use of diagnostic effort will be spent on finding out what is causing the start-up misfiring: whether it is coolant in the cylinder from a leaking gasket, or something else.
    I don't know about the c, but the gen 3 liftback is well known for brief start-up misfiring after sitting a while when the last use of the car didn't fully warm the engine up. When that happens, it's a result of water condensing in small passages of the intake manifold and being snorted in from those passages on the next start-up.
    CR94 likes this.
  13. Mendel Leisk
    41,826
    Cleaning the EGR when engine is rattling, is akin to closing the barn door after the horses have bolted.
  14. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    :confused::confused::eek::eek: Do everything except check what is extremely likely to be the problem...
    Head Gasket, failing between cylinders 1 and 2, which is where 99% of the people have said
    that it has failed, first.
    It's best to spend time and money on symptoms rather than the cause.
    Coolant pressure test with bore scope in the cylinders....
  15. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    Are you getting that rattle regularly, or only occasionally? If only occasionally, it may have the less malignant cause ChapmanF mentioned. If it's consistent, the doomsayers may be correct that it's your head gasket failing.
    I've heard the scary start-up rattle a few times during the 11 years I've had mine, but not in the past couple of years.
