Featured Another Gen 5 Rumour Article
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Dec 1, 2021.
  1. dbstoo
    dbstoo Senior Member
    1,224
    655
    Near Silicon Valley
    2024 Prius Prime
    I noticed the improved drivability of the prime today when I went into an average banked curve in the Siskiyou mountain range. The speed limit was 45 mph and I went through the curve at 72. There was no sign of exceeding the car's ability. It was a stretch of road that I'm familiar with, and my wife's Camry feels like a boat by comparison.
    I'm looking forward to the next version. :)
    Tideland Prius likes this.
  2. MIkeDr
    MIkeDr Active Member
    249
    136
    Seattle, WA
    2020 Prius
    XLE AWD-e
    It’s a bit of apples and oranges considering differences in roads, but I find a 2021 Prius Prime that I rent for weeks at a time while in Arizona handles better than our 2020 non-Prime Prius XLE AWD-e driving in Seattle proper.
  3. vvillovv
    vvillovv Senior Member
    3,525
    1,241
    NY
    @Tideland I missed the autocar link until today. I was curious if anyone else saw part 4 of the "Will it Drift" series, further down the page titled
    Will a Toyota GR Yaris drift? | 4wd hot hatchback Will It Drift? special, part 4
    It's shot on a test track, and although I was unplugged (no audio) while I scrolled onto it, I was curious about just how slippery that track was. Since they did show the sprinkler system working, it was still hard to detect if that's asphalt under the 1/4 inch of water, that made the track look like glass. Not ice, but close, anyway.
    In the linked article I was klnda bummed to hear autocar suggest toyota might use the bZ4X platform for the gen5 prius. Still hoping toyota will wait a while longer to increase the size of the car. Americans fixation on land barges is bad enough already.
  4. Trollbait
    11,292
    The weight of the battery has been reported as helping with driving feel.
    MIkeDr and Tideland Prius like this.
  5. Tideland Prius
    16,051
    There’s better weight distribution with the heavier battery in the rear (56/44) vs the Gen 4 (58/42).
    Having a 2016 Touring and a Prime, there’s a notable difference in suspension tuning. The Touring is stiffer and the Prime is soft but not old school Toyota soft. The shocks are still firm. The chassis is much better than any of the old Prii.
    I haven’t watched that series yet.
    I don’t know. The Prius Prime is longer than the current gen RAV4.
  6. vvillovv
    3,525
    1,241
    NY
    It has been my impression that the bZ4X platform would be longer and wider then the current prius platform. But I don't know the proposed dimensions yet either. I guess looks can still be deceiving.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,018
    Westminster, Colorado
    Wider and taller, but not longer.
  8. Trollbait
    11,292
    Platform dimensions aren't set in stone, and designers have leeway to adjust them. The Rav4 and Camry are on the same platform, yet there is a 5.3 inch difference in wheelbase between the two. There is intended to be a bZ line up, which would require more than one e-TNGA platform to meet different segment needs. A Prius on it could easily have the same dimensions as the current one.
    e-TNGA is not a 100% BEV platform, and was designed to handle engines. The reason for moving the Prius to it is because of the traction battery. It should package that better than the TNGA platform the Prius is currently on.
    https://en.wikipedia.org/wiki/Toyota_New_Global_Architecture
    austingreen and Tideland Prius like this.
  9. vvillovv
    3,525
    1,241
    NY
    thanks for the link!
    who says it's going to be wider, taller and the same length?
  10. Tideland Prius
    16,051
    No idea where the person who input the data got the dimensions but here's one "source"
    https://en.wikipedia.org/wiki/Toyota_bZ4X
    It's about 10cm/4" wider than a Prius Prime. Naturally it's significantly taller because it's an SUV.
  11. vvillovv
    3,525
    1,241
    NY
    Yeah, my bad! I'm more interested in the gen 5 prime and I can see I didn't make that obvious, so getting a response about the bz4x suv would be natural. Even if the suv wasn't what I was thinking about when I wrote it.
  12. Tideland Prius
    16,051
    Ohhh I see. I can see Toyota keeping the width. It’s near the max for a typical Japanese parking spot IIRC (less than 1800mm width). There was an article on a Japanese car website that voices their concerns about cars getting wider and surpassing 1800mm making it more difficult to park and manœuvre around tighter roads and parking spots.
    vvillovv likes this.
  13. vvillovv
    3,525
    1,241
    NY
    without going into what I believe is a big problem in translations, cause it also includes religion and politics, a lot of Toyota info is gathered from translations of Japanese releases, some good some not so much. Leaving a lot of room for personal embellishments or additions never actually included in the original.
    I do understand why many might not understand such a view, still, it doesn't mean I have to like it, for example (almost everything) on this page Toyota bZ4X Specifications Revealed | Page 8 | PriusChat
  14. toronado455
    toronado455 Member
    179
    22
    What part of that system? Because I would prefer a 2.0 liter replacing the 1.8 rather than a 2.5 liter. Do you have any info?
  15. Lee Jay
    5,850
    4,018
    I'd prefer a 1 liter (or less) and a 16kWh battery.
  16. Tideland Prius
    16,051
    No idea. Could be the motors and battery (although that'll make it even heavier unless they've found a way to reduce weight even further in that time)
  17. toronado455
    toronado455 Member
    179
    22
    There has been speculation that the USA hybrid Corolla Cross will have a 2.0 instead of the 1.8 as it does in other markets. I just thought maybe a 2.0 based HSD (similar to the Lexus UX) could be shared with the 5th gen Prius as well, especially if they are talking about increased performance for the 5th gen. I don't know, but that just seems more logical than the 2.5 liter.
  18. Storm88000
    Storm88000 Active Member
    321
    143
    LHValley, PA
    2020 Prius Prime
    Here's what I'd want:
    -60 miles all electric with same charge time
    -About 40 more horsepower (with 60 all elec miles I would be OK with losing a few MPG as a regular hybrid if the vehicle had more power - but no more than a few)
    -AWD option for the plug in.
    I was disappointed when first researching Prime about 2 years ago that there was no AWD, only with the regular Prius. I assume because it would be too expensive and/or the big battery is in the way for some type of rear trans-axle - no idea..
  19. Lee Jay
    5,850
    4,018
    If it's a plug-in, there's no reason for the engine to have more power than the average power draw of the car over an hour or so. All the peak power can come from the battery.
  20. austingreen
    austingreen Senior Member
    13,531
    4,062
    Austin, TX, USA
    They do have a 2.0L hybrid system although I believe it is only currently sold in europe.
    2.0-liter Toyota Hybrid System (THS II) | Toyota's New Powertrain | TNGA | Mobility | Toyota Motor Corporation Official Global Website
    In a European toyota corola hybrid the newer 2L system provides 180 hp peak almost 50% more than the prius or corola hybrid using the current 1.8L system. The engine itself is 41% efficient slightly higher than the prius.
    The rav4 hybrid has either a 1.6 kwh nimh battery or a 1.1 kwh lion battery. The lion battery actually has more usable energy. Its likely weight savings from using that rav4 lion battery would cancel out the weight gain of using a 2L system instead of the current 1.8L system without port injection. That rav4 battery would allow peak 190+ hp if mg2 and electronics were allowed to use it.
    We will know when toyota tells us, until then its all speculation.
