Gen 2 shifts on it's own from drive into neutral!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SuzDP, Jan 23, 2022.
  1. SuzDP
    SuzDP New Member
    Dana Point
    Three Touring
    I could use some help...
    My 2008 Prius with 126K miles is shifting on it's own from drive into neutral repeatedly. Thus far it has only occurred at slow speeds. I had the car towed to the dealer who has no idea why this is happening. They have only suggested experimenting. First to try a new starter switch. If that doesn't work, to try putting in a new shifter. If that doesn't work to try look at the transmission.
    Has anyone had any experience with this problem? Any ideas what the problem might be? I would love to have a more definitive direction to head in rather than pursuing expensive experiments.
    Thanks!
  2. JC91006
    JC91006 Senior Member
    16,470
    8,383
    I would think a new/different shifter would be best option. You can find them really cheap, they don’t normally fail so there is an abundance of supply
    jerrymildred likes this.
  3. ChapmanF
    15,074
    I think you should try to find a dealer who has heard of cars that are controlled by computers, and thinks about asking the computer what it shifted to neutral for.
  4. PriusCamper
    PriusCamper Senior Member
    10,898
    4,419
    Pacific Northwest, USA
    Have you been drinking?
  5. ChapmanF
    15,074
    Little bit of coffee, most recently.
    The Prius "shifter" is a lever that moves two small magnets around next to some Hall effect magnet-sensor ICs.
    The ICs create a pair of voltage signals that are inputs to the HV ECU, and tell it what "gear" you would like to be in. Roughly speaking, it's a game-controller input.
    As gets pointed out daily on PriusChat, there is nothing inside the transmission that physically shifts (aside from the piece that stops it from moving in Park).
    All of its other behavior, including neutral, is generated by the HV ECU, according to what "gear" it decides it is in, following your input from the game controller.
    There are a number of conditions that will make the ECU change its mind about what "gear" it is in.
    Any dealer who looks at a Prius that "shifts into neutral" and whose very first step is anything besides "ask the HV ECU why it did that" might be happier in another line of work.
    #5 ChapmanF, Jan 24, 2022
  6. SuzDP
    SuzDP New Member
    Dana Point
    Three Touring
    Thank you for giving me a direction to go in with the dealer besides the shifter and one that might yield a more definite diagnosis! I will post the results.
  7. SuzDP
    SuzDP New Member
    Dana Point
    Three Touring
    Follow up:
    Since no codes or history is up there are no diagnostics to go on. The dealer says they are unable to duplicate the issue. Though I have seen this problem reported on Prius Chat and other Prius community platforms, people are not posting what resolved their problem, other than people who've stated the problem seem to go away after manually manipulating, the shifter into different positions or clearing around the shifter and the problem didn't return. I'd love to hear from people who've resolved this problem.
    Also, is it damaging or unsafe to drive holding the shifter in Drive?
  8. PriusCamper
    10,898
    4,419
    Easiest way to address this is to go to a junk yard and pull a shifter out and swap it with the one in your car... Only experience I've had we these shifters going bad is the return springs not working, which could be dangerous in some situations.
  9. ChapmanF
    15,074
    I wonder whether such an issue would be more about the return spring or about the grease in there getting peanut-buttery with age (which would make the return-spring action sluggish even if the spring is ok).
    I don't think the spring gets flexed anywhere near its elastic limit ever in the few cm the shift lever moves, and I'd be surprised if anyone has ever shifted a Prius enough times for the spring to fatigue.
    I'm pretty sure if mine ever were returning sluggishly (and if I confirmed that the reason the ECU was shifting to neutral was because it really got that signal from the shifter), I would just take it apart and clean out the old grease and regrease it and see what that did. I've had it apart and there's nothing difficult about the disassembly/assembly; it's a simple mechanism.
    My nearest U-pull yards are a half-hour drive or so, and I could probably clean and regrease a few shifters in the time to go pull one.
  10. PriusCamper
    10,898
    4,419
    The Prius I was referring to was an '04 Gen2 with date of manufacture of November 2003 and it was driven in areas with salty roads and was trashed in most every way. There was zero resistance from the springs, just kind flapped around in the bottom slots due to gravity...
  11. pasadena_commut
    pasadena_commut Senior Member
    1,351
    409
    Southern California
    I can see where the ECU would shift from an active gear to neutral on a problem, but not without throwing a code. If there is no code then perhaps the ECU read "something" as a command to make that change, suggesting a problem at the shifter or in the wiring in between.
    By any chance are there any knick-knacks, phone holders, or other nonstandard car items near the shifter? I suppose it is possible that a cross or some other chunk of metal might be magnetized enough to confuse the shifter mechanism. (As precedent, I have seen video clips where people could not start their cars, and the problem was a little metallic bling ring they had installed around the key barrel on the dash or steering column, which blocked communication to the active part of the key.)
    Another possibility is that the connection from the shifter to the wiring harness is corroded or dirty. Might be worth a try unplugging it, giving both sides a blast with some electrical contact cleaner, let it dry. Examine it closely for problems, and if none are seen, then reassemble.
    PriusCamper likes this.
  12. ChapmanF
    15,074
    exactly—and that's also something you'd confirm by checking what is and isn't recorded in the ECU.
    You can also data log the signal voltages coming in from the shifter, so you know what inputs the ECU is getting.
    Keep in mind that the ECU does not act immediately on the input voltages that signal "neutral". It has to see those voltages held for about a second. That's long enough to catch on a data log, even at a low polling rate.
  13. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
    Sticky spring?
  14. Another
    1,802
    510
    Naples, Florida
    I assume you’ve checked the transmission fluid level?
  15. ChapmanF
    15,074
    The fluid in a Prius transmission has a lot less opportunity to escape than in a conventional automatic. It's more like a manual in that way: there's no dipstick, there's a fill and a drain plug, and when you drain it, you generally find the same amount of fluid you filled it with.
  16. pasadena_commut
    1,351
    409
    Southern California
    Why, exactly? I suppose if there was a major leak the car would eventually detect that the transmission is too hot or the gears are binding and might go into neutral, but not without throwing a code. Remember, while there are gears in the "transmission" no shifting of said gears occurs. Also, there is no dip stick, the only way to check is to drain it and see how much comes out.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    3,243
    1,352
    NJ-USA
    Haven't seen this type of fault myself, but if it is intermittent, then no springs in the shifter are "broken" (as it would be a problem all of the time).
    Old grease and dirt in the mechanism can certainly be worse when the temperature drops.
  18. mr_guy_mann
    3,243
    1,352
    NJ-USA
    I would expect that if there was severe fluid loss, then the first outward sign would be bearing or planetary gear noise/failure. You might notice fluid stains on the ground- or not.
  19. SuzDP
    SuzDP New Member
    Dana Point
    Three Touring
    Hi all,
    I want to say thank you to everyone who is chiming in about possible causes!
    Here is my update...
    -I took my car back from the dealer. Believe it or not, they charged me nothing for their time looking at my car.
    -I have no leaks.
    - Pasadena_commut -- I have been using the shifter as a place to hang my n95 masks! About 5 of them. As some may know, the portion of the masks that secure around the bridge of the nose has a strip of metal. Since removing the masks (hasn't been a long time yet), I have not had a repeat of the shifter slipping into neutral. It may be too soon to tell. So far, I am holding the shifter in D at higher speeds and not holding it in place when driving in parking lots or in my subdivision.
    -If the problem returns I will explore some of the other possibilities posted.
    I will let you know.
  20. PriusCamper
    10,898
    4,419
    Probably not relevant, but the one time I had this problem it was at night and I didn't see that my black backpack strap got caught around the shifter when I was getting in the car.
