Size of e-AWD Gas Tank?
Discussion in 'Gen 4 Prius Main Forum' started by Cricky, Jan 24, 2022.
  1. Cricky
    Cricky New Member
    Michigan
    2020 Prius
    LE AWD-e
    I know that Toyota got in trouble for exaggerating the size of the Rav4 Hybrid gas tank. I'm wondering if they got away with that on the e-AWD? I've always filled it up 15 miles after I got a low fuel warning but I never put 8.1 gallons in my tank. If I do a internet search I'm supposed to have 11.
    Just Curious.
    Cricky
  2. Tideland Prius
    16,017
    Note that the AWD-e has a smaller size tank than the regular Prius. I believe the 11 gal you’re quoting is the regular Gen 4 size.
    Also, there’s around 10 litres (2.5 gal) of buffer after the low fuel light comes on.
  3. jdenenberg
    jdenenberg EE Professor
    3,831
    1,825
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I always treat my 2021 AWDe as having 10 gallons of usable gas. That is one gallon less than my earlier Prii and leaves a small safety buffer as the fill is inconsistent.
    JeffD
  4. ColoradoBoo
    ColoradoBoo Senior Member
    903
    593
    Monument, Colorado USA
    Yep, my wife's 2017 Prius 2 has an 11.0 gallon tank and my 2021 Prius AWD has a 10.6 gallon tank. I wouldn't know how much is left after the low fuel light comes on....usually get filled up between 1/4 and 1/2.
  5. Cricky
    Cricky New Member
    Michigan
    2020 Prius
    LE AWD-e
    Thanks. It may be Google misinformation - lol. I searched "Toyota Prius 2020 e-AWD gas tank size".
    I haven't got a gas tank yet to test my real tank size.
    Cricky
  6. jdenenberg
    3,831
    1,825
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 and 2016 Prii had 11.9 gallon tanks.
    JeffD
  7. Mendel Leisk
    38,108
  8. jteran5
    jteran5 Active Member
    408
    202
    2019 Prius
    XLE AWD-e
    The buffer is at least 2 gallons after "empty"
    When my display hits "----" til empty (no numbers), it takes about 8.5 gallons to fill up. I drove another maybe 20 miles AFTER the blank reading and when I filled up, it was about 9 gallons. This was the most I've ever been able to fill up in my AWD model. Screenshot_20220125_111529.jpeg
  9. jerrymildred
    jerrymildred Senior Member
    11,490
    14,095
    Tampa, FL
    You beat me to it. :LOL:
    Amazing what you can learn from a quick peek in the owner's manual. Especially using search on a pdf version.
    fuzzy1 and Mendel Leisk like this.
  10. ColoradoBoo
    903
    593
    A PDF search? You cheater!! ;-)
    jerrymildred likes this.
  11. Pulse07
    Pulse07 Active Member
    273
    137
    East Bay, California
    2020 Prius
    XLE AWD-e
    Just put the gas in and go.
  12. fuzzy1
    10,013
    Do remember that advertised fuel capacities are almost never from the low fuel warning point. Instead, they are from the "engine sputtered to a stop and left you stranded on the roadside" level, allowing them to claim a larger number. Because fuel stations can be sparse in some areas, and fuel consumption is much more highly variable (depending on conditions) than most drivers realize, and there is some gauging variability, there really needs to be a significant safety margin. Drivers should be given enough advance notice to make a reasonable choice between continuing forward to the next station, or backtracking to the last one, without getting stranded.
    [​IMG] [​IMG]
    Here is one where a daydreaming driver, not paying attention until getting surprised by a low fuel warning, may need to turn back:
    #12 fuzzy1, Jan 26, 2022
    Pulse07 and jerrymildred like this.
  13. Mambo Dave
    Mambo Dave Active Member
    640
    305
    2019 Prius
    L Eco
    These cars would be awesome (for the USA) if they had 15 or 16 gallon fuel tanks.
    vvillovv likes this.
  14. bisco
    48,862
    gas tank size controversies, love these threads :p
  15. MIkeDr
    MIkeDr Active Member
    248
    136
    Seattle, WA
    2020 Prius
    XLE AWD-e
    my bladder gives out way before the gas tank does as it is with the Prius AWD.
    Pulse07 likes this.
  16. Mambo Dave
    640
    305
    2019 Prius
    L Eco
    lol.
    Mine does not.
    Pulse07 likes this.
  17. Pulse07
    273
    137
    2020 Prius
    XLE AWD-e
    Stop topping off the tank!
  18. jdenenberg
    3,831
    1,825
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You must be a coffee drinker like me.
    JeffD
    Mambo Dave likes this.
  19. jerrymildred
    11,490
    14,095
    Tampa, FL
    Topping off is a really bad thing to do, but I don't see any indication of topping off.
    Hang on!! I think I got it. Not the gas tank ... the OTHER tank. :ROFLMAO::ROFLMAO::ROFLMAO:
    Pulse07 and Mambo Dave like this.
  20. Mambo Dave
    640
    305
    2019 Prius
    L Eco
    On the long trips I manage my coffee carefully. First, it will be 3/4 decaf and 1/4 caffeinated. Second, I drink it if I need it, but not if I don't. It's cold most of the trip.
    I will have something like a smaller hard salami (protein and fat) to eat from, and only take one bite of it per hour or so. Car driving isn't burning calories, and carbs make one sleepy.
