Fusion research progress
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Jan 27, 2022.
  1. bwilson4web
    15,400
    Source: Burning plasma achieved in inertial fusion | Nature
    Abstract
    Obtaining a burning plasma is a critical step towards self-sustaining fusion energy1. A burning plasma is one in which the fusion reactions themselves are the primary source of heating in the plasma, which is necessary to sustain and propagate the burn, enabling high energy gain. After decades of fusion research, here we achieve a burning-plasma state in the laboratory. These experiments were conducted at the US National Ignition Facility, a laser facility delivering up to 1.9 megajoules of energy in pulses with peak powers up to 500 terawatts. We use the lasers to generate X-rays in a radiation cavity to indirectly drive a fuel-containing capsule via the X-ray ablation pressure, which results in the implosion process compressing and heating the fuel via mechanical work. The burning-plasma state was created using a strategy to increase the spatial scale of the capsule2,3 through two different implosion concepts4,5,6,7. These experiments show fusion self-heating in excess of the mechanical work injected into the implosions, satisfying several burning-plasma metrics3,8. Additionally, we describe a subset of experiments that appear to have crossed the static self-heating boundary, where fusion heating surpasses the energy losses from radiation and conduction. These results provide an opportunity to study α-particle-dominated plasmas and burning-plasma physics in the laboratory.
    This report is about a decades long attempt to make fusion by laser implosion. This is not even close to a practical power plant but another incremental step for our understanding. It is a lab experiment with more insights to how fusion works. But there is a parallel, a micro hydrogen bomb.
    My understanding, a hydrogen bomb is a fission ignited fusion reaction with some clever twists. The fission device effectively ignites a fissionable cylinder filled with the hydrogen filler, a lithium-hydrogen compound. The initial neutrons convert the lithium to a fusion-friendly hydrogen already adjacent in a compound with the other hydrogen. The cylinder compresses the filler to ignite the fusion reaction and the fusion reaction creates more neutrons to fission the cylinder and the subsequent heat results in compression and further fusion and heating. But it only works once like this fusion pellet experiment in miniature.
    Elon says 'A prototype is easy but production is much, much harder.' But you need the lab and prototype to begin understanding how to make a production system. Regardless, even if you don't understand the maths, this is a good read.
    48,983
    i didn't understand a word, but it is fascinating in a way, even to the less educated mind.
    i hope that bomb isn't another potential weapon.
  3. ChapmanF
    15,099
    For an odd perspective, the amount of energy (1.9 MJ), in one of those pulses, is in the ballpark of burning around two ounces of gasoline.
    But doing that in a very very very very small fraction of a second.
  4. PriusCamper
    PriusCamper Senior Member
    10,923
    4,427
    Pacific Northwest, USA
    By applying quantum theory you can use existing fusion particle from the sun and replicate them inside a chamber... Way easier that way. Catch is we don't understand quantum mechanics well enough to do that yet. But we do know that under certain conditions a particle in one place will behave identically to a particle in another place.
    #4 PriusCamper, Jan 27, 2022
  5. Trollbait
    11,327
    That bomb already exists as a weapon. In general discussion, they are called hydrogen bombs. These are the nuclear bombs that make the first ones look like firecrackers.
  6. fuzzy1
    10,045
    Some of the existing bombs go at least one, maybe even two stages beyond that.
  7. fuzzy1
    10,045
    ... and a very very small volume, much smaller than two ounces of gasoline.
    This one started out as BB size, before compression.
    PS. That BB size comment came from a different article yesterday. Looking at this far more detailed paper, I'm seeing a fuel capsule radius of 1 to 1.05 mm, inside a larger carrier. During capsule compression, the wall is accelerated inwards at 10 trillion g's. Inward speed reaches 350 kilometers per second (more than 20X our fastest rocket launch), in under a millimeter. Pressure reaches hundreds of billions atmospheres. But I haven't yet found how small it gets at maximum compression.
    ... then there is vastly more material than I can possibly absorb or comprehend.
    #7 fuzzy1, Jan 27, 2022
  8. fuzzy1
    10,045
    Another step forward in fusion research: a fusion experiment using a different process, magnetic confinement of a plasma torus in a tokamak machine, appears to have produced 59 MJ over 5 seconds, back in December, in the UK. 5 seconds is the machine's run time limit before its magnets overheat.
    Climate change: A giant donut-shaped machine just proved a near-limitless clean power source is possible - CNN
    A larger version of this type machine is under construction in France, and is hoped to be begin running its experiments in 2025-26.
