2023 Toyota Sequoia will be All-Hybrid
Discussion in 'Toyota Hybrids and EVs' started by drash, Feb 3, 2022.
  1. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    See this article for more info - Standing Tall: All-New 2023 Sequoia Full-Size SUV is Ready to Make its Mark - Toyota USA Newsroom
    Highlights
    Will use the same power plant as the 2022 Tundra Hybrid: i-FORCE MAX across all 5 grades, 437 hp, 583 lb-ft of torque
    9,000 lb towing capacity
    3-row SUV will have a novel sliding third row with adjustable cargo shelf system.
    10-speed 2WD or 4WD for SR5, Limited, Platinum and Capstone grades. 10-speed 4WD only for TRD Pro grade. Like the 2022 Tundra, the Capstone grade is the highest grade.
    No details yet on dimensions, ground clearance or MPG. Being made on the same line as the Tundra, it would be interesting to see how MPG compares.
    iPad ? Pro
    Meg&Bear likes this.
  2. Trollbait
    12,534
    Have Tundra hybrid MPG numbers been released? Fueleconomy.gov only has the ICE models posted.
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Toyota just updated their Tundra MPG for the i-FORCE MAX from an updated version (2/1/2022) of their specs:
    2022 Toyota Tundra i-FORCE MAX - Toyota USA Newsroom
    Note: these are Toyota estimates only
    4x2: 20/24/22 (city/highway/combined)
    4x4: 19/22/21 for all non TRD Pro grades
    4x4: 19/21/20 for TRD Pro
    Meg&Bear and Trollbait like this.
  4. Trollbait
    12,534
    The F150 hybrid ratings (city/hwy/combined mpg).
    4x2: 25/26/25
    4x4: 24/24/24
    I think it is smaller than the Sequoia, but here is the Explorer's.
    RWD: 27/28/27
    AWD: 23/26/25
    Truck beds just hurt fuel economy.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,464
    2,427
    Taylors, SC
    Here's a good video on the Tundra hybrid that shows a lot of the mechanicals that will be on the Sequoia hybrid.
  6. Leadfoot J. McCoalroller
    8,082
    7,562
    Pennsylvania
    2018 Prius c
    Finally, they're addressing this longstanding pernicious motive power deficiency, even if it does look like a lackluster phoned-in tally this time around.
    I can only hope it's enough to bridge them into the 4-figure torque segment before the end of the decade.
    Our children's safety depends on it.
    toronado455 and Trollbait like this.
  7. toronado455
    toronado455 Member
    179
    22
    Southern California
    Yeah. Wow. Toyota is using the hybrid tech in Tundra/Sequoia primarily as a power boost strategy. Fuel economy is only up 2 MPG over the gas version of the 2022 Tundra. This is a disappointment to me, but certainly not the only thing I dislike about the new Tundra/Sequoia.
  8. Trollbait
    12,534
    It's because these trucks might actually need to do truck things. Power-split hybrid systems have always seemed lacking on the hauling and towing front, and they don't get great fuel economy if mated to a larger engine.
    For people that don't need a truck that does truck things, there is the Highlander and Sienna.
    toronado455 likes this.
  9. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Additional info on the 2023 Sequoia.
    Live Legendary with the All-New 2023 Sequoia Full-Size SUV - Toyota USA Newsroom
    Specs and pricing links are also there.
    Battery: 1.87 kWh, 288V (240 cells - 40 modules)
    Cargo room: Behind 3rd row: 22.3 - 11.5 cu. ft., behind 2nd row: 49.0 cu. ft., behind 1st row: 86.9 cu. ft.
    2022 Cargo room: Behind 3rd row: 18.9 cu. ft., behind 2nd row: 66.6 cu. ft., behind 1st row: 120.1 cu. ft.
    Towing Capacity (SR5 2WD) 9,520 lb vs 2022 5.0L V8 (SR5 2WD) 7,400 lb
    2023 Fuel capacity: 22.5 gal standard, 32.2 gal TRD Pro
    2022 Fuel capacity: 26.4 gal all
    Length: 208.1 inches (3 inches longer than 2022)
    Width: 79.6 inches (0.3 inches shorter than 2022)
    Height: 74.2 inches to 74.6 inches on all grades except TRD Pro (2.8 to 2.4 inches shorter than the 2022)
    Ground clearance: 8.6 inches (1 inch lower than 2022)
    On sale: Late Summer 2022
    Model # Grade MSRP* 23MY
    7946 SR5 4x2 $58,300
    7947 SR5 4x4 $61,300
    7948 Limited 4x2 $64,700
    7949 Limited 4x4 $67,700
    7950 Platinum 4x2 $70,900
    7951 Platinum 4x4 $73,900
    7953 TRD PRO 4x4 $76,900
    7954 Capstone 4x2 $75,300
    7955 Capstone 4x4 $78,300
    Tideland Prius likes this.
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Official specs are out.
    https://toyota-cms-media.s3.amazonaws.com/wp-content/uploads/2022/01/2023_Toyota_Sequoia_Product_Information-1.pdf
    EPA MPG (city/highway/combined): 2WD - 21/24/22
    4WD - 19/22/20
    2022 V8 EPA MPG: 2WD - 13/17/15
    4WD - 13/17/14
    7 MPG gain for the 2WD and 6 MPG gain for the 4WD or a 47% increase for the 2WD and a 43% increase in MPG for the 4WD. So it’s more powerful, has better gas mileage, more towing power (28%), better headroom, but have to sacrifice some cargo room, ground clearance and leg room not to mention there’s about a not insignificant $7,800 increase (SR5 2WD). The increased headroom makes for better access to the rear seats.
    iPad ? Pro
  11. toronado455
    toronado455 Member
    179
    22
    Southern California
    Are you sure it has better headroom?
  12. Trollbait
    12,534
    I'd be a little circumspect with that news. It highlights that Toyota's full frame trucks were thirsty beasts compared to Ford and GM.
    2021 model MPG, Ford is a V6 turbo and Chevy a V8
    Expedition, 2WD - 17/23/19, 4WD - 17/22/19
    Tahoe, 2WD & 4WD- 16/20/18
    The new Sequoia will best them, specially around town, but it isn't a huge. Then it looks like the Expedition will be getting a hybrid. the F150 one bests the Tundra. The Tundra actually needs the hybrid to match the non-hybrid F150.
    Toyota had let the efficiency of their trucks languish for years, with the old Tundra actually being a step back. While Ford and GM were working to match the gen1 Tundra.
  13. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Year. Front Row/2nd Row/3rd Row
    2022 34.8/34.9/34.5
    2023 39.2/38.4/35.6
    Measurements are in inches. And include Moonroof in 2023.
    Surprising since they lowered the overall height but they also lowered ground clearance as well. They also made the 3rd row seats slide forward and back an impressive amount.
    iPad ? Pro
  14. hill
    8,803
    What about towing? Especially compared to the Ford /GM / hybrid competition.
  15. Trollbait
    12,534
    The Expedition with V6 turbo is a little less than the Sierra; a few hundred pounds with both being 9000 min.
    The Tahoe with V6 diesel is just over a thousand less, and the V8 is lower still.
  16. toronado455
    toronado455 Member
    179
    22
    Southern California
    Yes, that is surprising. I think perhaps the secret sauce is they lowered the seats.
  17. Trollbait
    12,534
    Or less padding.
