Refrigerant leak?
Discussion in 'Prime Main Forum (2017-2022)' started by PeninsulaPrime, Feb 3, 2022.
  1. PeninsulaPrime
    69
    47
    Washington
    I noticed these two white splotches below the H and L ports, which I assume is some sort of refrigerant leak from the HVAC system. Anyone seen this before? Is it something that needs to be fixed?
    2021 LE, 31k miles
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,475
    2,442
    Taylors, SC
    Leaks of the shrader access valves is quite common. I'd have them replaced. There are shops that have tools that can replace them without discharging the system.
    PeninsulaPrime likes this.
  3. PeninsulaPrime
    69
    47
    Washington
    Seems like something that should be covered under warranty, no? The car isn’t even a year old yet.
    Georgina Rudkus likes this.
  4. Georgina Rudkus
    3,475
    2,442
    Taylors, SC
    Yes, absolutely!
  5. bisco
    52,070
    or 12,000 miles?
  6. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    I've never seen white splotches due to a refrigerant leak. Oil dissolves in the refrigerant and circulates through the system. An oil spot is a sign of a leak. I don't know what the white is, but it isn't refrigerant.
