Can you continue to drive with a bad Hybrid Battery?
Discussion in 'Gen 3 Prius Technical Discussion' started by Robert Shields, Feb 5, 2022.
  1. Robert Shields
    Robert Shields New Member
    Will the vehicle stop functioning or is does the poor battery quality simply trigger a code to encourage you to replace the battery? Obviously there would be poor gas mileage but interested how the system is designed. In other words, in a worst case scenario can the car continue to be driven or will there be other symptoms involved other than poor mpg? Thanks in advance for any input.
  2. drbtz
    drbtz Member
    102
    51
    United States
    My understanding is that you can continue to drive but the MPG will poor and also consider the engine is an atikinson cycle and it may not be appropriate to run it under load 100% of the time. I am NOT an engineer so it would be best to ask some of our other members whom are more experience than myself.
    Relevant read:
    Driving prius with bad battery | PriusChat (IMPORTANT NOTE: Reverse may not work as the battery sends reverse voltage to the motors to allow the car to go backyards, TLDR: Reverse gear is powered from battery)
    Robert Shields likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    • Nope the hybrid battery is used to start the car. Hybrid battery powers up the motor generator in the trans that in turn rotates the engine till it starts.
    No hybrid battery no start. Car is a brick.
    Keep reading the forum it has all the info you need. If you have a question just use the search forums link up top and search in the appropriate forum.
  4. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    While true, the car will usually keep the engine running long enough for you to pull over, and may even be able to drive some distance at a very reduced speed.
  5. edthefox5
    10,096
    4,833
    Clearwater, Florida
  6. Robert Shields
    Thank you. Very helpful information.
  7. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I'm interpreting that as a sarcastic response to the post above it. It is, in fact, an important feature. I've had several cars suddenly die on the road, leaving me with no way to even get to a safe shoulder. An F150 with a bad spark plug wire. A Ford XL with a defective ground to the ECU. A Mazda RX7 that grenaded the rear differential, locking the rear tires at 65 MPH.
    So it was comforting that when my hybrid battery developed a leak it was able to limp home in turtle mode.
    freddywayne and Robert Shields like this.
  8. ChapmanF
    18,006
    So it depends on how bad is bad.
    The battery is used to start the engine, so if it gets bad enough, eventually that isn't going to happen, and you're not going anywhere. (Whether the car will "keep the engine running" becomes a sort of academic question once it has no way to get the engine running.)
    The reason for all the diversity in answers is that the car starts giving you trouble codes earlier than that, when the battery is just bad, not only when it's kaput. So you can keep driving around for a while.
    It's hard to predict how long "a while" is. Generally, if you keep driving around, and then you get a loud bang and bad smells from the back of the car, you've just found out how long your "while" was.
    dbstoo and Robert Shields like this.
  9. Robert Shields
    Thank you for providing input. One of the issues is whether a HYBRID BATTERY warning can be a false positive. I received the warning and in conjunction heard the engine vibrate upon start up. I cleaned up the EGR and so far so good. Do you have an opinion as to crossover problems re codes for the hybrid battery?
  10. rjparker
    10,049
    6,210
    There have been people who reset the failed high voltage battery code many times and continue driving for months. Some think they are driving on engine alone because the engine never shuts off, for example at stop signs and lights. That simply means the high voltage battery is so bad it won't take enough charge to allow a stop light shutdown. The car needs high voltage at all times when it is in Ready mode.
    Nevertheless, you can get stranded because of a bad hv battery when you stop at a store and can't restart it.
    At that point you are being towed and forced to buy a new hv battery on the spot. The good news is you usually get weeks to months of warnings that are impossible to miss.
    #10 rjparker, Feb 6, 2022
  11. Robert Shields
    That explains the enthusiastic youtube posts of people reseting the warning! In most cases I bet they are putting off the inevitable. I am trying to monitor and be proactive because my daughter loves this car! I will be posting a question today regarding monitoring the battery differential subject and hope you will contribute.
  12. ammdb
    ammdb Active Member
    277
    111
    Indianapolis
    First the dash warning lights come on and trouble codes are set. Clearing codes may or may not get the warning lights to turn off for a while.
    Next the battery fan starts working overtime even on short trips, due to heat caused by imbalanced voltage between modules.
    Eventually car will give up on the HV battery altogether and go into limp mode, which is only good for getting down the road a short distance. Turning engine off and clearing codes will get the car going again, but only until the next time it goes into limp mode.
  13. ChapmanF
    18,006
    Or there will be the eventual bang and bad smells followed by a walk home.
    freddywayne, edthefox5, ammdb and 2 others like this.
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
    yup. Lots of posts of bangs and smoke with resetting the Ground Fault nag.
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Ive been on this site 16 years. Bought my 07 new.
    Back in the day idiots would run there G2's out of gas all the time and kill the Hybrid battery.
    Lots of guys still on this site who know what I'm talking about. It was hilarious.
    When your low on gas in a G2 First the gas gauge blinks...then when your almost dry it does a loud beep...nope they kept driving till the engine shut off but wait then like a magic carpet the car still drove...AWESOME... till the hybrid battery went dry. Not far...Then your done....
    Its a 4000 lb brick.
    In those days you had to tow it to the dealer and wait weeks till Toyota Corp sent that dealer a High Voltage Power supply and special charging harness to charge the Hybrid battery back up outboard. Engine wont start with a dead hybrid battery so it has to be out board charged.
    It was $$$$$.
    Your still screwed if you pull that now unless you happen to own a Hybrid Automotive charger and have the harness installed. But if you have that you know what time it is and would not do that idiocy anyway. Run out of gas stop the car.
    That magic carpet car happened alot. Idiots trying to get the last drop out of the tank to get the best mileage. Nothing more frustrating then getting stuck behind a new G2 owner back in the day going 20 miles lower than the posted in those days.
    That's a big contributing factor why there was so much Prius hate. At least for me lol....
  16. ammdb
    ammdb Active Member
    277
    111
    Indianapolis
    The walk home is the worst part. :)
  17. ChapmanF
    18,006
    Depends how you feel about bad smells.
