Is my car battery dying?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by icyrius, Feb 12, 2022.
  1. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    Hello. Is my 12 V Battery dying? Take times to finally make it turn on.
    Most of my dashboard stays lit up (see picture)
    thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Maybe but probably not.
    Get it tested.
    BUT.....I don't see any place in that picture that it says "READY".
    That might mean that your foot wasn't firmly on the brake.......or you pushed the button a few milliseconds before pressing the brake.
  3. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    I get 14.75 DCV from my voltage meter
  4. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    it finally turned on. It’s bed doing this the last couple of days. It’s around 40 degrees here.
  5. sam spade 2
    7,035
    2,801
    2017 Prius c
    That is NOT the battery voltage.
    It is the charging voltage and indicates that the car WAS in the "ready" mode when you took that reading.
    It tells you NOTHING about the battery itself.
  6. bisco
    51,844
    if it's original, just replace it
  7. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    Advanced auto parts said the battery is fine.
    i have no idea then…
  8. rjparker
    10,088
    6,258
    Time to read codes
  9. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    Advance Auto parts doesn't have licensed mechanics. You're trusting the opinion of a kid who needed a job. Load test the battery yourself
    icyrius likes this.
  10. douglasjre
    2,164
    715
    Null, NL
    This is the best battery load tester. Do not buy fancy technical ones that check resistance
    icyrius likes this.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    14.75 volts is most likely with the car on, so it says little about the battery. It speaks to the Inverter's DC to DC converter
    The voltage when the car has been off for at least 8 hours would be of interest.
    #11 JimboPalmer, Feb 13, 2022
  12. fuzzy1
    10,409
    Lots of places said that even on batteries that were not fine. So don't take it as a final answer.
    Pop the hood so that you can read the voltage at the under-hood jump point tomorrow morning without opening the driver door, which triggers some brake booster activity. Then as Jimbo suggested, measure the battery voltage after the whole thing has rested overnight, or 8 hours, without being started. That measurement will be more useful, though unfortunately still not absolutely definitive as it isn't a load test.
    icyrius likes this.
  13. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    The battery reading this morning was 12.85 V measured from under the hood without opening the doors.
  14. rjparker
    10,088
    6,258
    Verify the brake lights work. Then it is s time to forget about the 12v battery and start reading codes.
    #14 rjparker, Feb 14, 2022
  15. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    Yes. It did it again. This time it only took two times. I do not have an ODBC reader. Can you recommend one?
  16. rjparker
    10,088
    6,258
    Might want to verify the brake switch is working, required to achieve Ready mode.
    Autosupplies have free scans but they are usually too generic for a hybrid issue. Toyota's Techstream is the best, some like the xtool d8, others try to get by with the Dr Prius app and a bluetooth scanner. Considering the best scanners are $699 and above (unless you get an illegal copy of techstream which still needs a hardware interface); considering there is a learning curve to using the tool and diagnosing the problem; and considering intermittent electrical problems are particularly tricky even for the experienced, most go to the dealer and at least get their diagnosis.
    Bluetooth Obd2
    https://bit.ly/ObdTwo
    Xtool D8
    https://www.amazon.com/XTOOL-Diagnostic-Diagnostics-Bi-Directional-Programming/dp/B098L7ZD4K/ref=sr_1_1_sspa?crid=35AO19CB30ECW&keywords=xtool+d8&qid=1644844015&sprefix=Xtool,aps,162&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExME1DQlVaR0FaWVZRJmVuY3J5cHRlZElkPUEwODc2MzAyMVlTVFJLQ1lQNFE5RCZlbmNyeXB0ZWRBZElkPUEwMDk2OTQ0MzhQSVMzT1hQNVpUSCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    icyrius likes this.
  17. sam spade 2
    7,035
    2,801
    2017 Prius c
    This.
    AND.....be absolutely sure that your foot is firmly on the brake BEFORE you push the "start" button.
    Every time mine won't start it is because my finger hits the button before my foot pushes the brake pedal.
    And I think that pushing the brake causes something extra to light up on the dash.
    icyrius likes this.
  18. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    Thank you for your help
