'16 Prius V - Gas Gauge Stuck on on Full
Discussion in 'Prius v Main Forum' started by jjtrindc, Feb 2, 2022.
  1. jjtrindc
    jjtrindc Junior Member
    Falls Church, Virginia
    2013 Prius v wagon
    Completely bonehead move on my part that I acknowledge. I got distracted while filling up my 2016 Prius V and didn't realize the gas pump did not automatically shut off causing fuel to spill outside of the tank.
    Car drives fine, but it's been about a week and the gas tank has not dropped from full.
    I've skimmed some posts about how to reset/recalibrate the fuel gauge, but those appear to be more older models. I've also seen suggestions to disconnect the battery.
    I want to see what suggestions others may have before I explore any DIY possibilities. I also understand I may have damaged a sensor.
    TYIA.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,513
    Bay Area, California
    2019 Prius Prime
    How many miles have you put on the car in the week since the overfill?
  3. jjtrindc
    2013 Prius v wagon
    Maybe 60-70? It's been about a week and I haven't driven that much. Especially with using heat and seat warmers her in the North, I'd have expected it to drop by a bar or two. Perhaps I need to be patient!
  4. Kenny94945
    Kenny94945 Active Member
    844
    420
    Sausalito
    2016 Prius v wagon
    Yes, be more patient.
    FWIW I always average 40+ mpg. Sometimes even 50 mpg.
    Since you "stuffed" the fuel tank, I'd be more patient.
    Good luck.
    Raytheeagle likes this.
  5. rjparker
    9,831
    6,067
    Agree it is probably ok. My gauge does not move for quite a while. The actual level gauge is in gas anyway; you may have dumped gas into the evap system but it would throw codes if its fouled up.
    #5 rjparker, Feb 2, 2022
    jzchen, Raytheeagle and Air_Boss like this.
  6. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I've filled up with those red (plastic) gas cans which end up overfilling. Also topped off because I don't trust the automatic shutoff.
    There's a float. It's still floating at the top and may for 2 more weeks I would guess at your usage...
    REVVL V+ 5G ?
  7. jjtrindc
    2013 Prius v wagon
    Update! After about 2 1/2 weeks, the gas gauge finally started going down, so turns out I just needed some patience. Luckily no signs of any other damage due to my error.
    Oh - and don't be me! Pay attention to the gas nozzle, lol!
  8. Tim Jones
    Tim Jones Senior Member
    1,751
    562
    SE Texas
    2011 Nissan LEAF
