Hello everyone I have a 2017 prius and my a/c is blowing hot when driving down the road and when
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by John Wise, Feb 15, 2022.
Tags:
  1. John Wise
    John Wise New Member
    My a/c blows hot when driving down the road and blows cold when sitting still any thoughts
    48,985
    check if the cooling fans come on
  3. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    There is an ECO mode and other modes in the A/C system, depending on a few things and settings there might be a setting that got turned on that could be causing that. I just noticed that there was a setting that only the driver gets air. Might just check settings to make sure they are all good, other than that it could be a door in A/C system not working right.
    There is only one fan and he said it was working.
  4. AzWxGuy
    AzWxGuy Weather Guy
    968
    490
    Tucson, AZ
    2021 Prius
    i think Bisco meant the radiator/A/C condenser element fans at the front of the car. Those won't be on when A/C is on if the freon charge has been lost. The compressor won't turn on either. I don't believe there is a sight glass anymore in the lines to confirm freon level. OP said it was blowing hot, but was that the same temperature air as outside air? It is Florida, but was the outside air warm? You can get heated A/C (dried) air in the car with the temperature turned up. That is about the extent of my postulating. Minus an obvious leak in the condenser due to salt corrosion or stone nick (oil spot) I would be taking it to the dealer for proper diagnosis.
  5. Hidyho
    2,698
    529
    2018 Prius
    “blows cold when sitting still”
    Doesn’t that kind of blows the condenser fan idea?
    AzWxGuy likes this.
  6. AzWxGuy
    AzWxGuy Weather Guy
    968
    490
    Tucson, AZ
    2021 Prius
    AAaack, missed that very important point. Clueless, I am now...
    Back in the old vacuum motor days, that could be an indication of a leak somewhere. It's all stepper motors and fuzzy logic now. Could be a misinformed blend door or some such.
    #6 AzWxGuy, Feb 21, 2022
  7. Terry Trump
    Terry Trump New Member
    oregon
    mine is doing the same thing
    please help if you find a cure!
