Featured Gen 5 Prius now further delayed to the model year 2024
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Jun 3, 2021.
  1. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Nationwide, but the info has been somewhat ambiguous... like what does "reservation" actually equate to? We know region distribution varies anyway.
    #81 john1701a, Nov 6, 2021
    52,275
    'you can take the reservation, but you can't keep the reservation'
    watch
    MTN and Merkey like this.
  3. Tideland Prius
    16,601
    You sure? I was under the impression the December timeline was for Europe.
  4. john1701a
    12,820
    5,305
    58
    Could be just for them. But then again, the reservation is likely nothing but a list to get to place your order. You know, the handoff from national to regional.
    Regardless, this particular delivery wait will seem like forever.
  5. bwilson4web
    16,326
    At age 71, I suspect my driving might be restricted in the future. Autopilot and FSD are my last hope to remain mobile and independent. But like the ‘draft’, I may be a year or so late.
    farmecologist likes this.
  6. farmecologist
    farmecologist Senior Member
    1,959
    1,799
    Southern MN
    That's a very good point Bob. I have often thought about the fact that autopilot, etc... could make senior citizens more mobile. And that could be a very good thing with the existing labor shortages that will only get worse as time goes on.
  7. bisco
    52,275
    maybe it will be perfected by the time the 5th gen comes out :p
  8. fuzzy1
    10,583
    :ROFLMAO::ROFLMAO:
    I sure hope the Gen5 Prius isn't delayed that long.
    vvillovv likes this.
  9. bisco
    52,275
    me too, but it could be a race to the bottom
    vvillovv and bwilson4web like this.
  10. mikefocke
    4,038
    1,832
    Sanford, NC
    There is hope Bob. Still driving anywhere at 78+. It isn't age but the things often associated with it.
  11. toronado455
    toronado455 Member
    179
    22
    Southern California
  12. CHIZ
    CHIZ Junior Member
    Nova Scotia
    2022 Prius Prime
    Solid State Batteries by that time may be a huge improvement.
  13. bwilson4web
    16,326
    • Fusion energy
    • Hydrogen fuel cell cars
  14. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    Perhaps given Toyota keeps teasing solid state specifically for hybrids maybe there will be a Gen 5 hybrid
    They claim to have a solid state bev at the Tokyo Olympics
    Also dropping is more “nuclear diamond” battery hype
  15. bwilson4web
    16,326
    I would expect some hydrogen powered vehicles too.
    Brilliant and improved over time, the hybrid-synergy drive remains an innovation but a technology ridden too long:
    • Gen 0 - production prototype, only seen in Japan and some Asian gray markets.
    • Gen 1 - brilliant battery but weak cells. A great little sedan that went +260 k miles at 52 MPG.
    • Gen 2 - significantly improved battery and body aerodynamics, I skipped this generation.
    • Gen 3 - improved ICE with cooled exhaust and better batteries.
    • Prius Prime - moved exhaust tap AFTER catalytic converter and one-way clutch for limited BEV. Traded in for pure BEV.
    Personally, I would prefer to see the hybrid synergy drive become the universal transmission to retire the remaining, Toyota ICE vehicles. Their significant improvement in efficiency and reduced parts count makes a lot of sense.
    I look forward to Toyota joining the BEV market with significant production across multiple body styles. Just as I type this line, they appear to lag behind looking for a 'magic bullet' technology instead of seeing the system is the solution.
  16. Trollbait
    12,653
    [QUOTE="bwilson4web, post: 3249030, member: 10647"
    Bob Wilson[/QUOTE]
    Cost is probably the issue. They have more parts, but the production capacity for traditional transmissions is already in place, and in the millions. Toyota opened up HSD patents a few years ago, hoping it would lead to an increase in production numbers from others to drive down costs.
    And since HSD came to market, engines and mild hybrids have improved over that time. Yeah, they don't match power-split hybrids in results, but they do see improvements for lower costs. Full parallel hybrids can match power-splits, and might do it for a lower price.
    Toyota also likes to squeeze all the profit they can out of something. Look at the US Corolla. It took years for technology in the model for other markets to reach here. Extended life of older tech, and the factory lines making it, was a draw for trying out the Scion experiment. There is nothing wrong with this. Most US customers were happy with the products. Holding on to older resources while they still have value can be a drag on moving to newer ones though, as even Toyota has limits on resources.
  17. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Is it confirmed? I should not hold my breath for a redesign to come out this year as a 2023 model year vehicle?
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I believe that the rumors from Japan are for release there in December of this year. Release in the U.S. would likely be in early 2023 as a 24 model. This is absolutely not confirmed, just rumor that hasn't changed in several months.
    I do hope that some real info comes out before December, sometime in the fall.
    bwilson4web and Tideland Prius like this.
  19. hill
    8,894
    Look at it this way. Toyota is already Supply constrained, not only from the virus, but - because they were one of the very last to start up their electric car production, they are last in line to get on board with massive quantities of batteries / supplier for their electric cars - which will mostly be going to China at first. Wouldn't that mean less batteries for the plug-in or standard hybrid? So there are 2 competing interests with getting a new hybrid model to market
  20. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Hybrid models will still continue to use mostly NimH batteries, so no competing interests regarding battery supplies...
