DR PRIUS results
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Kutcher, Feb 27, 2022.
  1. Daniel Kutcher
    Daniel Kutcher Junior Member
    30
    Richmond, Virginia
    Just got Dr Prius going for the first time and here’s a screen shot. Of course the green bars go up and down a lot, but they all read 15.8 so that’s good. But what’s up with the blue bar on cell #1? 24milliohm resistance seems like a small number, and the other cells are reading NO resistance at all. Thoughts?
  2. Daniel Kutcher
    30
    Richmond, Virginia
    Just realized I read it wrong. All the cells are at 23 milliohms except #1, which is at 24.
  3. ChapmanF
    18,552
    One Dr. Prius thing I'm not wild about is the way it crops its bar charts so they don't start at zero, and that makes tiny differences between blocks look yuuge. My grade school teacher would have raked me over the coals for drawing charts that way. Bars that really showed the difference between 23 somethings and 24 somethings would look very different.
    StarCaller and Daniel Kutcher like this.
  4. Daniel Kutcher
    30
    Richmond, Virginia
    I’ve doing a bit of research now and it seems like 23 (and one 24) milliohms is like a “middle aged” value. Like they are 13 when new, and 30 and above will make dr Prius turn red with anger lol. So I guess I’m normal. 120,000 miles so far. And all the blocks have similar resistance
  5. ChapmanF
    18,552
    I don't think I've ever seen 13, but then I've never bought a Prius new, so maybe it serves me right.
  6. Daniel Kutcher
    30
    Richmond, Virginia
    lol
    either way, I guess that 23 is an acceptable number
  7. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Note that the "23 milliohms" is for two Modules (12 NiMh cells) in series so that is about 12-13 milliohms per module.
    JeffD
  8. PriusCamper
    PriusCamper Senior Member
    13,070
    5,306
    Pacific Northwest, USA
    Those aren't good measures... I will always argue that "Voltage Diff" is the best number to monitor if you want to know when your pack is going to have problems. Currently you're at 0.07v difference and that's super healthy... Once that number gets up to 0.40v on occassion that's when you need to think about doing pack maintenance/module or pack replacement.
  9. Daniel Kutcher
    30
    Richmond, Virginia
    Good point
  10. Daniel Kutcher
    30
    Richmond, Virginia
    Good to know! I’ve seen it fluctuate as high at 0.20v on occasion.
