1. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    How can I change the arrival time? When I've entered a destination I like to have the arrival time listed. Only daylights savings time has come and gone and it still has not updated. Is there a way I can do this?
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    You mean the arrival time actually shows the true clock time that you will arrive? Is that new to the updated GPS? I must have missed that. I think mine just has a count-down in hours and minutes.
    Are you sure you are not mistaking the count-down for the arrival time? Can you take a picture? Something showing the regular clock, the travel-time and the arrival-time? I would just like to see that.
  3. kdmorse
    kdmorse Member
    205
    Germantown, MD
    The GPS/Nav unit does both. Set one way, it shows time to arrival (ie, you'll arrive in 32 minutes (shown as 0:32)), and the other way it shows arrival time (ie, you'll arrive at 8:32pm). Touch the display there and it should toggle back and fourth. (*)
    However, the clock doesn't seem, to switch into/out of daylight savings time on it's own. Either it's not supposed to, or it's supposed to and doesn't work right. As a result, as the OP indicated, it's suddenly an hour off on all arrival times.
    There's a setting, buried within the menu's, to manually toggle DST on/off, and that's where you need to go to fix it. I last did it in the spring, so I don't remember the exact path - however I need to do it again, as of the fall time change it's an hour off again.
    (*) 2006 Package 7.
    -Ken
  4. aaf709
    3,862
    2022 Prius Prime
    I believe the toggle from arrival time (ex 8:32) to time to arrival (ex 25 minutes) is on the 2006 on.
