Momentary low oil pressure light when starting cold.
Discussion in 'Gen 3 Prius Main Forum' started by Frogerelli, Mar 10, 2022.
  1. Frogerelli
    Frogerelli Junior Member
    Fort Smith, Arkansas
    Hello Prius Hive,
    I gave my 2010 Prius to my daughter 2 years ago. The other day I needed to move it and about 5 seconds after the engine came on, there was a short beep and the Low Oil Pressure on the display for 1-2 seconds and then it disappeared. I checked the car again the next day and same thing.
    98,000 miles. Full oil. If the engine is warm, this does not happen. Oil service done by local, non dealer shop. Because so many people are wary of their car getting the correct oil, I did an oil change today. (I don't normally do it because my only access to the underside of the car is with a pair of jackstands and it's a pain.) After replacing oil and filter, it did it again, but that could have been due to the filter filling. It may be too warm for me to replicate with a cold engine until tomorrow morning.
    If it isn't due to low oil volume or incorrect viscosity, and it only happens when cold, what else could it be? The Toyota parts image looks like it is shaft driven, not an electric pump like the water pump.
    2010 toyota Prius Engine Oil Pump. Pressure - 1510037040 - Genuine toyota Part
    But why would it only be trouble in that brief moment?
    Thanks for your thoughts!
  2. JC91006
    JC91006 Senior Member
    16,813
    8,595
    Is there a lot of oil under the Parking spot?
    maybe whoever did the oil change put the filter gasket on the wrong groove, allowing oil to empty out of the filter. So when you first start the car, the filter is empty
  3. Frogerelli
    Everything is dry and clean, including the plastic access panel door. Prior to today, the last oil change was about 2000 miles ago.
  4. JC91006
    16,813
    8,595
    And you’re certain the oil was full when in your daughter’s possession? Some 2010 cars will burn oil
    #4 JC91006, Mar 10, 2022
  5. Frogerelli
    Yes. I read several posts on the issue and so twice checked the oil level with a cold engine. It was basically up to the top marker on the dipstick.
  6. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Bad sensor or loose wiring?
    Mike
    PriusGuy32 and Mendel Leisk like this.
  7. Mendel Leisk
    41,818
    ^ This.
  8. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Yeah, lets not throw the baby out with the bath water.... You've verified oil level by changing it & the oil filter; now, focus on the Oil pressure sending unit/switch. $5 on Rockauto. No need to start throwing main bearings at the engine just yet.
    #8 PriusGuy32, Mar 16, 2022
