valve cover gasket parts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by abubin, Mar 14, 2022.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    I am planning to do a valve cover gasket replacement soon.
    Been poking around this forum for the parts number. Seems like the information is a bit over the place.
    Here are the parts number for 4 gaskets that need to be replaced:
    11159-37010
    90430-10024
    11214-88480
    11213-88480
    Can someone please help to confirm if these parts are correct? I am ordering it from overseas and would like to make sure it is correct. Hopefully, I can make a video out of it as well once I have done it.
    Thank you.
  2. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    What year Prius? Looks like this is for the Gen 4 Prius 2016+
    iPhone ?
  3. abubin
    abubin Member
    193
    92
    Malaysia
    It's for gen3 and I got the information from gen3 threads.
  4. Mendel Leisk
    42,345
    Look it up on Amayama.
  5. abubin
    abubin Member
    193
    92
    Malaysia
    If you click on the parts number, it actually links to Amayama. Would like to get it double confirmed before ordering.
    Thanks.
  6. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    The part numbers are for the Gen 4. Look at the Valve cover it’s different.
  7. Mendel Leisk
    42,345
  8. abubin
    abubin Member
    193
    92
    Malaysia
  9. Mendel Leisk
    42,345
    Are you entering your year and model specifications at amayama, or just entering the parts numbers you found earlier? The first two links you posted look to be 4th gen (model year 2016 and up). Safest bet is to tell amayama what you've got, then go to the engine section, search there.
  10. abubin
    abubin Member
    193
    92
    Malaysia
    The first picture in the parts are for gen 4. You can click on next picture and see gen 3 engine there.
    #10 abubin, Mar 17, 2022
  11. Mendel Leisk
    42,345
    Not sure how you would get a combined picture. If you go into the catalogue function, spec your model and year, it’ll show you parts specific to your car.
  12. abubin
    abubin Member
    193
    92
    Malaysia
    Cause the part number is the same for gen2,3 and 4 for item 1 and 2.
  13. ilhouhou
    ilhouhou Junior Member
    39
    Uk
    Thanks for everyone in this post, really helpful in 2025.
