Manually Changing Tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherlockcrypto, Mar 21, 2022.
  1. sherlockcrypto
    sherlockcrypto Junior Member
    I need to change 3 tires on my Prius. Is it feasible to change them manually myself? I am considering buying this manual tire changer from Harbor Freight: Manual Tire Changer
    or just try this method using tire spoons from this guy on youtube:
    Will I damage my wheels if I try to change them manually? I have experience changing bicycle tires but this will be my first time with car tires.
    I am looking to do it manually because from calling around it will seem to cost me $35/tire to get it changed in my area and I would rather spend that on getting tools.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Check if your local Walmart with tire center will replace them and ask how much.
    REVVL V+ 5G ?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    There's always the possibility of scratching the rims. And you need a big enough air compressor to get them onto the seats on the rim or else monkey with ropes or straps to try to get them in place. And then you need to balance them. I'm big on DIY, but replacing tires is a big enough PITA that I let the pros use the machines for car & truck tires. Money well spent IMHO.
    WilDavis, ColoradoBoo and hill like this.
  4. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    If you search, you can find a manual automotive tire changer for around $200. Maybe less
    if you REALLY search.
  5. RRxing
    RRxing Senior Member
    2,555
    1,828
    NEPA
    I helped my son-in-law manually remove some tires from a set of wheels he wanted from a u-pull-it yard. What a PITA! I would let a tire shop do it, considering how infrequently it is done.
    #5 RRxing, Mar 21, 2022
    jerrymildred likes this.
  6. ASRDogman
    7,844
    3,997
    He should have sprayed the inside part of tire. Spraying the outside didn't help.
    Fill the tire first before puting in the valve core, it will fill faster.
    And I guess he doesn't know how to use that tire machine....
    Don't forget you'll have to have the tire balanced...
  7. jerrymildred
    11,517
    14,158
    Tampa, FL
  8. Mendel Leisk
    41,947
    Considering the guys selling the tires have all the equipment, I'd let the pros do it. I am partial to just bringing in loose rims though, mounting them myself at my leisure. One downside to that: they can't verify your odo, makes it impossible to take advantage of tread-life warranties.
  9. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    It's a pain in the butt that's why I got the machine from eBay
  10. ttou68
    ttou68 Active Member
    351
    211
    This was my project during Pandemic lockdown...
    Bought a Prius with blown head gasket and needs new set of tires but no tire shop nearby was open... So, I come up with this and a bubble balancer to get me by... Wasn't cheap, cheap.. but don't have much room in the garage and this doesn't take much room..
    I own 5 vehicles plus occasional fix uppers so 3 sets of tires so far...
    Now looking for a small footprint tire balancer because bubble balancer is kind of pain and time consuming.. 20210413_233951.jpeg 20210414_183013.jpeg Resized_20210415_173203.jpeg
    #10 ttou68, Mar 21, 2022
  11. bisco
    52,417
    i can't even change a bicycle tire :oops:
    ASRDogman likes this.
  12. Leadfoot J. McCoalroller
    8,152
    7,654
    Pennsylvania
    2018 Prius c
    A set of tire spoons and some lube and a beginner has a fair shot at dismounting and remounting tires on steel rims without damage.
    If they are aluminum rims that changes things a little- it's easier to scratch those rims.
    I salute the blacksmith who chops the firewood for his own forge and all, but full manual tire remount is a brutal amount of hard labor to do.
  13. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I mounted my OEM tires onto new aluminum wheels after having winter tires mounted on the OEM aluminum wheels.
    It was a timing issue and I needed a challenge.
    Secret is to use tire bead lube and rim edge protectors. A large pry bar is also required.
    Take it slow and be cautious not to ding the wheel with the pry bar.
    iPhone ?
  14. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    The hard work is breaking the bead and removing the old tires. Mounting tires is pretty easy. In fact, you can almost certainly mount 15" tires without any tools. 17" tires, with their shorter/stiffer sidewalls, take a bit more force. You'll then want a good air compressor to be able to seat the new tires, again probably easier with 15"s than 17s.
    The truly expensive equipment are the tire balancers. You might get away without balancing new high quality tires, but I wouldn't count on it.
  15. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    I won’t do anything larger than 15” on a manual changer but have been forced to use it on my small nonstandard stuff (the tire places won’t even touch the 125/80r13’s on my Comutacar
  16. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    I've found most low budget tire and alignment shops do mount and balance for $20 cash if you bring new tire and wheel with old tire on it and not the whole car. This also includes tire disposal. I use the spare tire to get around as this work is done one at a time. It works well for me.
  17. Mendel Leisk
    41,947
    I'd put tire mounting and dentistry in the same category: sorry, but I'm not that self-reliant.
    CR94, jerrymildred and PriusCamper like this.
  18. PriusCamper
    13,102
    5,310
    I actually do all my own dentistry, but wouldn't risk doing my own tire mounting...
  19. sherlockcrypto
    Thanks everyone for chiming in. For anyone interested in what I ended up doing, I decided to just grab some costco tires using their coupon/ special. Buying 4 tires, get $150 off and free install. Replaced all 4 with michelin tires and saved 1 of the old tires as backup.
    I ordered online last week, and they arrived in shop earlier than expected. I gave them a call to schedule an appointment for the net day which they were surprisingly able to do (Better than the online appointment system).
    From doing the math, the total came out to $484 inc tax for 4 tires and install from costco compared to $405 for 3 tires and scheduling install with walmart / local tire shop. For reference, prices are for California.
  20. bisco
    52,417
    great deal!
    i think i paid almost $700. including install for my michelins a few years ago. got them from tire rack and local mech installed them.
