Stop vehicle immediately, fuel cap
Discussion in 'Prius c Technical Discussion' started by Supplyz, Mar 21, 2022.
  1. Supplyz
    Supplyz New Member
    Australia
    ----Australia----
    Had the triangle of death, stop vehicle immediately, replaced ev water pump, still got the triangle of death. Had been noticing when fuel cap removed on occasions large amounts of air bieng forced out.
    Drilled a hole in fuel cap with smallest drill i could find and cars been running fine ever since.
  2. ChapmanF
    18,447
    It would be very helpful to at least include what trouble code your car was reporting.
    Otherwise I foresee a lot of fuel caps getting drilled in attempts to solve unrelated problems.
  3. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    If you had to modify the fuel cap to fix the problem, you didn't fix the problem...
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Sounds like a purge valve problem.
  5. Mendel Leisk
    41,814
    Many years ago a knuckleheaded dealership mechanic did just that to one of our cars. I'd heard a sound when parked on hot days, and learned later it was by design. Anyway, asked the service writer if that sound was normal, and their "solution" was to drill a hole through the gas cap. After smelling gas stink in the garage for a few days, I just effing gave up and bought a new cap, bigger fish to fry.
  6. 2010moneypit?
    314
    122
    Beaumont ca
    Because of Smog regulation we now use non-vented caps. Replacing the cap won’t fix it and drilling a hole in the Cap is covering up other problems.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,474
    Taylors, SC
    The evap valve is either stuck open or closed depending if the hole is venting pressure or drawing a vacuum.
