New 12V battery: car won't start
Discussion in 'Gen 2 Prius Main Forum' started by Herman7, Mar 22, 2022.
  1. Herman7
    Herman7 Junior Member
    17
    Netherlands, Europe
    My 2006 Prius does not start, even after I just put a brand new 12V battery in. A few weeks ago the car had been on the parking lot behind my apartment building for a while and I had not used it for several weeks. I could not open the door with the fob so I did it manually and checked the 12V battery, it was at only 2.9V (under load) so shockingly low. So I charged the battery overnight hoping I could still revive it but my expectations were pretty low. To my surprise it started the next morning.
    But a few days later it did not start anymore and I decided I needed a new battery, the old one had probably been drained way too low and was about 6 years old. I ordered a new one, it arrived yesterday and I just installed it. It reads 12.8V but the car still won’t start, I can hear the brake booster humming when I press the pedal and the headlights burn bright, dome lights work fine but it won’t start and nothing else on the dashboard comes on. Only the open-door symbol does light up when I open a door but that seems to be all.
    Just to make sure I checked the old battery, it was at 11.7V so maybe there was not even a need to replace it. I do not drive regularly and mostly short distances but I had the hybrid battery replaced last year and it would be nice if I could use the car for a few more years.
    Any suggestions on what to check next? I already had a look at the IGN fuses and they seem to be okay. I tried the spare key fob but that did not make a defference. I heard something about the fusible link giving problems, just by looking at it it seems ok but I don’t know how to check if it is still okay. Hope someone can help.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    I’d charge the new battery with an external charger to make sure it’s got sufficient CCA. Or get it tested for free under load at parts store. Could be it’s not charged enough. Lighting up the dash is not a test.
    Herman7 likes this.
  3. Herman7
    17
    Netherlands, Europe
    Thanks for your response. New battery is at 12.8V and if I turn all the lights on, doors open, honk the horn it drops to 12.3V. Safe to say the new battery is excellent and has more than enough power. Car simply does not go in Ready mode.
  4. bisco
    51,758
    sounds like a bad connection. what does it read at the jumppoint under the hood?
    Herman7 likes this.
  5. Herman7
    17
    Netherlands, Europe
    About the same as directly on the battery bisco. I have a feeling the receiver of the keyfob somehow does not work. Without pressing the break pedal the startbutton should light up green when pushed but that does not happen. Tried the spare keyfob but makes no difference. Could not find any blown fuses under the hood. Will check the ones under the steering wheel this afternoon. To make sure I will also disconnect and clean the terminals on the 12V battery once more.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Are you sure you got all the connectors solidly snapped back in place on the positive terminal of the battery?
    Herman7 likes this.
  7. Herman7
    17
    Netherlands, Europe
    Thanks Jerry, it could be something simple like that. I have made stupid mistakes like that before. There is a big connector on the + and also a small single wire connector. That should be all, right? I have the European version but I guess it is the same for a US Prius.
    P.S. When I changed the battery before years ago I only took the 2 clamps off. This time I removed both connectors first, left the one on the control box on and simple moved it to the side. Put the new battery in and reconnected both connectors.Then screwed everything back in place.
    #7 Herman7, Mar 24, 2022
  8. Another
    1,819
    517
    Naples, Florida
    Just asking, is the SKS button on the dash turned off?
    Herman7 likes this.
  9. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    My WAG wonders if you have a 'combination meter' issue : https://www.texashybridbatteries.com/prius-combination-meter-repair
    There are threads for a DIY fix (under 10 duckets), or you might be able to find someone locally that offers such, with or without the swap.
    Herman7 likes this.
  10. jerrymildred
    11,517
    14,147
    Tampa, FL
    I can't rule out the CM, but I've never heard of it interfering with starting -- only shutting off the car.
    If all the connections are good (and with lights working, that seems most likely), I think the next thing I'd do is check to see if there are any trouble codes.
    Herman7 likes this.
  11. Herman7
    17
    Netherlands, Europe
    I tried that Jerry. I have a ScanGauge 2 which I have used a lot in the past but when I plug it in it cannot connect with the car 'connection failed'. The device clearly detects the +12V, powers up and tries to connect but simply does not 'see' the car. Also, the car will not go in Ready or even IGN ON Mode, maybe it has to before it can connect to it. So that could be the reason for failing to connect.
    What is most puzzling to me is how a new car battery could damage anything in the car without blowing a single fuse. I found another thread on this forum where, after putting a new 12V battery in, the dash would light up but not start because somehow the brake fuse had blown. Could take a while to figure that out but at least that makes sense.
    This does not make any sense at all: a car does not stop working when a new 12V battery is placed. I replaced the battery before some 6 years ago, it is one of the simplest things you can do yourself. Very frustrating. I guess I could have it towed to the dealer but they usually charge you an arm and a leg, no way to check if what they claim is true, not sure if a 2006 Prius is worth it.
    #11 Herman7, Mar 26, 2022
  12. bisco
    51,758
    does your car have a slot in the dash for the fob?
    Herman7 likes this.
  13. Herman7
    17
    Netherlands, Europe
    Yes it does bisco. When I insert the fob and press the start button nothing happens. The led on the Start button should light up green when I press it but it does not. No ACC, no IGN ON, no READY.
    With the head light high-beams on (they still work) the voltage drops from 12.8 to 12.3V so under load the voltage drops a bit but not by much. To me the new battery seems to be working fine. Except for the door-open indicator nothing else on the dashboard lights up.
  14. bisco
    51,758
    it sure does sound like a fuse, did you run a resistance test on them?
    Herman7 likes this.
  15. Herman7
    17
    Netherlands, Europe
    Yes, all fuses under the hood and below the steering wheel are fine. Borrowed a realy (contactor) tester from a friend and will test those tomorrow. I more and more have the feeling that the problem occuring during the battery swap was purely coincidental. Could be the Start button or fob receiver. Anyone have schematics of the wiring in that area?
  16. bisco
    51,758
    a few years ago, i was having annual service done on our home backup generator. when the mech replaced the 12v battery, it blew the main ecu, or so he claimed. he said that sometimes happens when you reconnect 12v power. idk, maybe.
    Herman7 likes this.
  17. Another
    1,819
    517
    Naples, Florida
    Especially when the tech connects the poles incorrectly, the does an Oh Sht.
    Herman7 likes this.
  18. jerrymildred
    11,517
    14,147
    Tampa, FL
    Hmmm. If you can't even get it into IGN ON, then scanning for codes isn't going to work.
    I agree with your guess earlier that it probably has nothing to do with the battery. With all fuses good, that makes me wonder about wiring damage. Perhaps rodents eating wires since it's been sitting a while?
    Herman7 likes this.
  19. Herman7
    17
    Netherlands, Europe
    Not sure about rodents but I have had issues with moist in the past: even had windows frozen on the inside during winter and the radio did not work for a few months, then suddenly started working again. Could be a buildup of corrosion causing bad contact somewhere.
    jerrymildred likes this.
  20. bisco
    51,758
    older prius to tend to corrode at connection points and ecu pins. usually sets a code though
    Herman7 likes this.
