Best used years 2014-2021, for delivery services heavy use?
Discussion in 'Newbie Forum' started by 2R45, Mar 18, 2022.
  1. 2R45
    2R45 Junior Member
    Maryland
    Looking to find best used Prius years for reliability and least maintenance
    51,795
    2015 is the only good gen 3. any gen 4 is fine. if you don't do your own work, find a mechanic before buying a car.
  3. rjparker
    10,052
    6,216
    2016 up excluding the 2016-17 Prius v since it is still a gen3.
    In your choice of years, the worst are 2014s with vins prior to the following:
    Compare last six digits of vin
    #3 rjparker, Mar 18, 2022
    jerrymildred likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,647
    5,108
    Pacific Northwest, USA
    The 2017 Plugin Prius is the one I worked on that I liked the most... Whenever I see a plugin Prius at the gas station I always ask 'em when was the last time they filled the tank and they always say it's been months. One dude said it's been almost a year. Super reliable well built car!
    FireLawdZuko and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    The Prime won't save you a lot on fuel if you're driving most of the day, but it is the best of all generations and models for almost anything but carrying capacity. Any other 4th generation would be a very close second place. And I'm one of those who only buys gas every 2,500-3,500 miles, so I obviously have lots of drives shorter than 30 miles. But then again, we went to St. Augustine (about 180 miles away) and got 58 mpg round trip. Still have almost half a tank left. A regular 4th gen (2016-22) will do about the same mpg. And it will be vastly more comfortable than the older models.
    PriusCamper likes this.
  6. 2R45
    2R45 Junior Member
    Maryland
    Any thoughts about a 2014v with 130k, wagon
  7. rjparker
    10,052
    6,216
    Read above
  8. jerrymildred
    11,517
    14,147
    Tampa, FL
    The Prius V has all the same EGR/head gasket issues of the other 3rd generation Prii. Plus the cooling air intake for the hybrid battery is right down low on the rear floor and liable to suck in more dirt and hair. Not nearly as good in the fuel department, but it does have plenty of room.
  9. rjparker
    10,052
    6,216
    The v certainly rides and drives better and has more room for cargo. Bigger standard tires, pitch and bounce control and higher btu ac are all great. But you will have a $2500 brake booster, $2k battery and most likely a new engine at least once during your ownership. If only they made a v with a gen4 engine. But that functionality went to the Rav4 hybrid.
  10. bisco
    51,795
    disaster waiting to happen
  11. 2R45
    2R45 Junior Member
    Maryland
    Bisco - what year V would you buy?
  12. bisco
    51,795
    the newer the better. but rjparker knows the v much better than i do. i would assume the 15 and up have new pistons and rings, but i would confirm it through part numbers.
    and then, i would clean the egr circuit before driving it, and have a savings account for actuator replacement if necessary
    2R45 likes this.
  13. 2R45
    2R45 Junior Member
    Maryland
    Can an extended warranty from Toyota cover the actuator?
    Remember, I’m the guy with a 2011 Prius 4 with Solar currently 180k and still- knock on wood, … and my son has a neighbors 2004 with hybrid battery change in 2017… we both love our cars, I’ll probably give him the 11 and sell his. Just trying to determine what’s next.
  14. bisco
    51,795
    i don't know anything about the warranties, it is certainly worth exploring. make sure you read all the fine print.
    also, there may already be an extended warranty. you should be able to find out at toyota.com/owners.
    don't get me wrong, there may be lots of v's without issue. we only see what comes through here.
  15. Mendel Leisk
    41,240
    Keep an open mind about 3rd gen Prius of model year 2010~2014 vintage. We have a 2010 with 93K kms, not using a drop of oil between changes so far. Knock on wood...
  16. bisco
    51,795
    but you had better maintain it like mendel :cool:
  17. Mendel Leisk
    41,240
    One thing, eight-o’clock-day-one it had a block heater, and we try, mostly successfully, to plug in for a couple of hours before any stone-cold start. Also, following Canadian 3rd gen schedule for oil changes, which is 6 months or 8k kms, whichever comes first. And we’re doing under 5k kms yearly now.
  18. Alex0910
    Alex0910 New Member
    Montego bay, 02 JM
    Two Eco
    After reviewing and reading I decided to buy this vehicle. I'm very surprised I can't find them to buy in Jamaica. I am looking for 2014 -2016 prius to buy. If anyone knows a dealer please assist. This vehicle ticks all the boxes.
