  1. RayL99
    RayL99 Junior Member
    I felt like the front end was too high with the TRD springs so I installed the 2010-2011 eBay lip on my 2013. Thinking about color matching, but the black doesn't look bad at all. IMG_20220219_181928.jpg IMG_20220219_182000__01.jpg
  2. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
  3. KamiKKazi
    KamiKKazi Member
    91
    58
    OC
    Added ijdmtoy blue courtesy lights. They’re super bright! Matches the oem illuminated door sill. Next will be to change the amber foot well lights to the blue lights from the special edition rav4.
    Burna J, Dylan Doxey and Johnsk93 like this.
  4. Sterlingarcher6969
    Sterlingarcher6969 Junior Member
    64
    22
    Did a test fit of my custom underglow strips.
    The end goal is to have an Arduino take the turn signal input and automatically change color to amber and blink on the appropriate side.
    Then return to the previous chosen color.
    Montgomery likes this.
  5. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I did something today. At 177640 miles, it’s time for me to say goodbye to my car. I reserved a new car a couple of months ago but luckily for me, the buyer backed out and I picked this up at MSRP despite my wait would be close to 12 months. Loving it so far!! ⚡️⚡️⚡️
    #19005 WolfpackBill, Mar 16, 2022
  6. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
    P1070138.JPG P1070212.JPG P1070281.JPG Drove the Wide Prius From San Diego,CA to Seattle,WA
  7. natekia
    natekia Junior Member
    27
    Phoenix
    I guess it been a while since I posted . Over the weekend ended doing the inner tie rod. Toyota only sells it by the entire steering rack. Napa or Amazon sells them by the inner if you don’t want to replace the entire steering rack
  8. Matthew ward
    Matthew ward New Member
    Vermont
    New here so figured this would be a great place for a 1st post.
    2012 new to me at 105000 and no mats so got the weather techs and left it be... its a prius there's nothing to be done right, I just needed a commute car.
    "Mod list"
    Remove those horrible hub caps
    Black out badging
    20% rear 35% front tint
    Tail light blackout
    6k Led interior and exterior
    8k 24v HIDs (should have done 6k)
    25mm wheel spacers all around (need another 5-10 on the rear)
    Tanabe springs are in a box waiting to go on
    And by the end of May she'll have 1320 V11 blastpipes with muffler delete.
    Having issues with uploading files tho so hopefully update later with pics
    Johnsk93, Matth Torrijos and Burna J like this.
  9. Matthew ward
    Vermont
    1st post issues. Here's some of the progress.
    RayL99, BlkGenIII, Inza2 and 4 others like this.
  10. RayL99
    I got great deals on some 2010/2011 led headlights. Found a driver side headlight with ballast for $96 shipped on FB marketplace and found the passenger side headlight and ballast on eBay for $206 shipped. Halogen to LED harness from Japan was $40 shipped. Only problem is the eBay lens looks a bit cloudy compared to the cheaper FB marketplace lens. Here they are after I used the Turtle wax kit on just the passenger side light. Still not as clear as the driver side. IMG_20220408_115647.jpg
    #19010 RayL99, Apr 8, 2022
    Burna J and apt5020 like this.
  11. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    Buy this one. I have used it and it’s fantastic. Everyone I recommended to buy this are also super happy with it. Just follow the instructions for best results.
    iPhone ?
    RayL99 likes this.
  12. ASRDogman
    ASRDogman Senior Member
    7,751
    3,964
    Mothers Aluminum Polish will clear them up. Simple to use.
    Wipe it on, and then use a buffing wheel for drill to buff it off.
    Then a micro fiber cloth to wipe it down afterward.
    You can get it at walfart for about $6.
  13. RayL99
    I figured I try to compound and polish them up with a drill tomorrow before I try another kit. They made it on the car today and look great! IMG_20220408_175320.jpg IMG_20220408_201252.jpg IMG_20220408_201333.jpg
    PriusHead05, Inza2, Burna J and 2 others like this.
  14. ASRDogman
    7,751
    3,964
    There are several items you can use. But this for me was inexpensive, and easy!
    And only took about 10 each lens.
  15. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Not today, but last Friday I won the Mod Hybrid class at the Green Grand Prix at Watkins Glen for the third time. 69.0 mpg over 80 miles on the long course. 4th out of 12 in the Hybrid class at the autocross in the afternoon.
    tony_2018, Burna J and Montgomery like this.
  16. Matth Torrijos
    114
    208
    Poway
    Deleted emblem and filled with bondo. Video in IG @priimayed 20220425_135426.jpg GOPR0058.JPG GOPR0052.JPG
    ockevin, Grit, Montgomery and 2 others like this.
  17. hoffeck
    hoffeck Member
    Germany
    After I recently installed my new steering wheel, I also had to exchange the shift knob for a black one and paint the silver ring black.
    The shift knob is from a European Toyota Auris.
  18. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Headed to Hybridpit for a brake booster assembly/ABS replacement. Just so everyone knows, dealers are charging ridiculous amounts for this job if you are out of the support program warranty. I was quoted $4280 out the door by Marina Del Rey Toyota. Believe me when I say the guys at Hybridpit took care of me. Also got brand new OEM rotors, pads and fluid. Andrew, Greg and Roger never disappoint. 150k miles of services through these guys. Everything I’ve ever needed. FC322189-954A-41C5-8DA9-C8A65717744A.jpeg
  19. SnowMexicanuck
    56
    66
    Quebec, Canada
    Done something very simple. Ditched the cartridge oil filter housing for a standard housing with spin-on filter.
    Friend with a '11 CT200h had a slight problem where one of the connecting rod created an inspection window in the block (car is in the 300,000 km range). We both work at a Toyota dealer and a customer had his engine replaced at 14 km on his Corolla after he hit something directly on the oil pan. So friend got a free block for his Lexus and I've got a free filter housing.
    Paul E. Highway and Montgomery like this.
  20. ChapmanF
    18,436
    What's making the string-of-pearls light effect I think I'm seeing around the bottom of the shift knob, and around the inner circumference of the trim ring?
