Airbags deployed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dklayton0213, Mar 30, 2022.
Tags:
  1. dklayton0213
    dklayton0213 Junior Member
    35
    Hattiesburg MS
    My wife ran into a pole in the parking lot. She was only going maybe 5mph but the airbags deployed. Since then the car will not go into gear due to the ecu detecting that the airbags deployed. I have since got her another car but would like to see about getting this one going. After visually inspecting it I do not see any damage. You can't even tell she hit a pole by looking at the front of it. Is there a way to reset the ECU for diagnostics purposes before I spend money to replace the air bags? I know they sell srs airbag simulators, but I did not know if I needed this or if I could use tech stream to reset the ECU.
  2. Mendel Leisk
    41,822
    What’s your insurance like? File a claim? It’s a 3rd gen? What year, miles, condition?
  3. dklayton0213
    35
    Hattiesburg MS
    Insurance was only liability and uninsured motorist. It's a 2011, 250,000 miles, good condition.
  4. Mendel Leisk
    41,822
    I've heard insurance companies will "total" a car if the air bags are deployed. Even without collision insurance, that's maybe food for thought? Talk to a body shop, get some quotes. Even if you don't follow through with them, gives you some idea.
    Can you post pics of the damage from the impact with pole? Front end? Hopefully you can appreciate levity right now; it better not look like this... ;)
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,076
    1,992
    NJ-USA
    Usually if the airbags deploy then the srs control module is done- toast- put a fork in it. Almost all manufacturers stipulate replacing the module, all deployed pyros, and the clockspring ( if the driver's airbag was involved).
    For testing purposes, IDK if you could unplug the srs module then clear other codes to see if the car will ready up and go into gear. Anything more will (likely) require lots of replacement parts (which is why a "minor" collision can result in a car be declared a total loss).
  6. dklayton0213
    35
    Hattiesburg MS
    Insurance said they wouldn't cover because I don't have liability. I'd like to DIY this car and a body shop would not know how to reset it. I've read that you need to take it to the dealership to get it reset after an impact but I'm wondering if they just put a new airbag module in. Here's a pic of the car. IMG_20220401_122400.jpg
    #6 dklayton0213, Apr 1, 2022
    Aknoten and Mendel Leisk like this.
  7. dklayton0213
    35
    Hattiesburg MS
    I don't mind replacing those things I just want to make sure that's the only issue. I think I'm going to take out the airbag srs module out this weekend and send it off to be reset and go from there.
  8. PriusII&C
    PriusII&C Active Member
    426
    145
    San Jose, California
    Your car barely shows any damage in front. A couple of months ago my Gen 3 had a rear-end accident. The front bumper cover was torn, driver front side lights damaged, even the inverter pushed backward by 1/4". But the airbags were not deployed.
    Just wonder how the car decides the impact to set off the airbags.
  9. Mendel Leisk
    41,822
    Yeah looks very minor. The hood seems pushed up a bit though.
    At least get a quote or two, for professional repair.
  10. dklayton0213
    35
    Hattiesburg MS
    I plan on only getting a body shop to repair my hood. The rest I'd do myself. If I ever get it running I'll take it in for a quote but I don't want to pay for a tow just for a quote.
  11. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Prius vehicles have 3 generations of impact sensors.
    The first generation impact sensor is a "simple" metal ball held by a magnet at one end (e.g. towards the center of the vehicle), and electrical contacts at the other end. So, when an impact happens, the kinetic energy of the metal ball overcomes the force of the magnet, goes forward, and connects the electrical contacts at the other end of the sensor.
    The nice thing about those types of designs is that they are simple, reliable, very resistant to any electrical noise/spikes (like may happen if a battery shorts before/in a crash), etc.
    However, they clearly are very directional, and therefore, are not that good at detecting an angular impact.
    The 3rd, latest generation, impact sensor uses a mutli-axis force sensor, and can it be located at different places on the car/vehicle.
    Here's a good overview, just ignore the math stuff :).
    https://www.experts.com/content/articles/kenneth-solomon-airbag-paper.pdf
    Some quick excerpts that cover most of the theory:
    CRASH SENSOR HISTORY
    Early air bag deployment systems in older vehicles utilized mechanical sensors for crash
    detection, which were phased out of the US market around 1994. Early mechanical sensors,
    such as the “rolamite” by Sandia National Laboratories, relied on a metallic sphere that was
    stabilized at a standby position by a spring or a magnet.
    When the sensor was subjected to a force beyond a designed threshold, the spring or magnet
    could no longer keep the metallic mass in place. The mass moved and made contact with an
    electrode, sending an electrical signal to the air bag control module, which then sent a signal to
    the air bag control module. Systems with mechanical sensors were generally inaccurate at
    interpreting minor collisions. Movement within mechanical sensors can be underrepresented
    with frontal collisions, and the acceleration the sensor experiences are sometimes slightly
    delayed. As an improvement, modern air bag deployment now relies on microelectromechanical
    system (MEMS) components.
    (Note: Micro-electromechanical systems (MEMS) is a process technology used to create tiny integrated devices or systems that combine mechanical and electrical components.)
    NEW CRASH SENSING SYSTEMS
    New MEMS crash sensors measure acceleration with an accelerometer that sends a continuous
    stream of data to the air bag control module. Accelerometers are typically piezoelectric or
    variable capacitance sensors. The most common MEMS accelerometer in use today is the
    ADXL-50 by Analog Devices.
    As an anchored mass moves relative to the sensor’s body due to acceleration, a plate attached to
    the anchored mass moves closer to a stationary plate. The change in distance between the plates
    affects the capacitance of the sensor, or the ability to hold an electrical charge. This change in
    capacitance is easily measured and is then converted to a change in voltage. The voltage change
    is directly correlated to force due to acceleration, and the readings are interpreted as acceleration
    by the air bag control module. Using an algorithm, the control module can determine if air bag
    deployment is necessary based on the pattern of the acceleration pulses over time.
    THE DECISION PROCESS
    The air bag control module (ACM) receives a continuous signal from each MEMS sensor and
    records the data for a fixed period after a specific event. With a central processing unit (CPU), it
    performs algorithmic computations and controls the “fire” or “no-fire” command for air bag
    deployment. The triggering algorithms determine crash severity by evaluating one or more of
    the kinematic variables (derivatives/integrals of acceleration) shown in Table 1. Examples of
    algorithm decision flow charts are shown in the following Figures 3, 4, and 5.
    Two vehicles of similar weight may have very different stiffness values, as seen when comparing the 2010 Ford Fusion
    to a 2010 Toyota Prius. Both vehicles have approximately the same vehicle weight, yet the
    front-end stiffness of the Toyota Prius is substantially greater than the Ford Fusion. Since both
    the amount of displacement and the duration of impact for a Ford Fusion are greater, an air bag
    would need to deploy in the Ford Fusion within a range of deceleration values lower than those
    required for the Toyota Prius.
  12. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Well it may not seem much but the damage is there. The hood is clearly pushed up which require a body work. Not sure if the fenders are out of alignment as well.
    Could you tell us the contact point? I can't see which part of the bumper came in contact with the pole.
  13. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Five friggin miles an hour? That’s all it takes? Are you sure she’s being honest? :)
  14. dklayton0213
    35
    Hattiesburg MS
    The contact point is between the lower grill and the driver lower blinker. I was with her when it happened. It might not have been exactly 5mph but it was definitely no more than 8. Wasn't even hard enough to jolt me. I just sat there looking at the air bad thinking to myself I wish the airbags wouldn't have just gone off. From my understanding because the concrete pole did not give at all it caused the airbags to go off more easily. I feel like we're getting a little off topic on this thread. Yes it has some damage to the hood. Yes I'll eventually take that to a body shop. No it does not have any visible damage inside the engine bay. I looked hard around the inverter. What I really need to know is how to reset whatever keeps it from starting after it detects an impact. Today I plan on scanning the codes and sending off my airbag srs module to be reset. Any other advice would be appreciated.
  15. PriusII&C
    426
    145
    Good to know it is MEMS. Thanks.
  16. ChapmanF
    18,451
    Argh, I just noticed for the first time that whoever made the PDF copy of Gen 3's repair manual that's been circulating online used the airbag section from Gen 2. (Pages 6775 through 6956 of the PDF, and sure enough, that's a drawing of a Gen 2 on page 6775.) Well, you get what you pay for,
    Yuck. So somebody will have to go to TIS or the library (more info) to see the right repair info for Gen 3 airbags.
    But the Gen 3 wiring diagram does show a similar design, where the "center airbag sensor"/ECU is on the center cabin floor roughly below the heater, and there are also front left and front right deceleration sensors mounted out at the front corners of the car.
    To trigger the front airbags, there needs to be agreement by the "safing" sensor inside the center unit that the car is decelerating above some minimal rate, at the same time as one of the front decel sensors detects a rate high enough to call for the airbags. The (wrong, Gen 2, argh) manual also says there's a decel sensor inside the center unit that can trigger the airbags without a front-sensor signal, if the deceleration at the center sensor is strong enough.
    I am wondering if there was some pre-existing weakness in the body structure where the front sensors mount (rust, or frame damage from an earlier collision, etc.), or one of the front sensors was somehow not mounted securely.
    It's trying to measure the force of the collision by how fast the nose of the car is decelerating, but of course it really only sees how fast the sensor decelerates. If the sensor was somehow insecurely mounted, or mounted on some weakened structural metal, it could have been knocked back more than you'd normally expect for a 5 mph collision, enough to trigger the airbags.
    Don't forget to also replace the front seatbelt retractors, which probably had their pretensioners ignited.
  17. dklayton0213
    35
    Hattiesburg MS
    Yes the 2 front seatbelts will definitely have to be replaced. There is a service that will repair for $50 I'm considering using though. Same place I'm sending me airbag srs module to be reset. I'm hoping once I get the srs module back and hook it up that the safety feature will be disabled and it'll let me start the car. I'd like to know for sure that the engine and hybrid system is fine before spending the money on the airbags.
  18. dklayton0213
    35
    Hattiesburg MS
    IMG_20220403_153541.jpg Well I sent the airbag module off to be reset today. 12v was dead so didn't bother trying to pull codes with tech stream. When airbag module comes back in I'll try to give it a jump and get codes. Will keep you guys updated.
  19. dklayton0213
    35
    Hattiesburg MS
    Got the airbag module back in and gave it a jump and it cranked! Engine is completely fine the only error was the red airbag light of course. I got new airbags and a new sensor coming. I hope this helps anyone else with the same problem.
    Henrik Helmers likes this.
  20. prius16
    462
    246
    New England
    2022 Prius Prime
    That's good to hear!
    Congratulations on the repair!
    (y)
    dklayton0213 likes this.
