Need help with a part number on a damaged under tray
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gptoyz, Apr 1, 2022.
  1. gptoyz
    gptoyz Junior Member
    85
    17
    los altos
    So my Prius was the victim of negligent Caltrans and I had no choice but to run over a cone
    It took out my lower under tray which I believe to be:
    51447-47010
    but the part that is still intact is:
    51451-470.10
    just want to check that I’m replacing the same one
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    After entering your VIN on top of this site https://www.japan-parts.eu/toyota/eu/2008/prius/nhw20l-aheebw/2_222220_001_358W/tool-engine-fuel (or just after navigating to your car with the buttons from left to right below the VIN search field) you can have a look to every part of your Toyota. And if you click at a part number there will be a small pop up with the full part number and name.
    If it's the one in the picture, the footnote seems to say there's no original spare part or at least the screws are already fitted. Screenshot_20220401-221552.jpg
    FP4 ?
