Please help make sure I order all necesary parts for brake job.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by DHurt, Apr 1, 2022.
  1. DHurt
    DHurt Junior Member
    17
    Palm Bay, FL
    One of my front calipers seized on my way home from work yesterday. My car spent most of its life in Minnesota so I'm just going to replace both front calipers, hoses, rotors, and pads. I replaced the rear calipers a year or so back when money was tight so I didn't replace the pads or rotors. I'll get them this time around.
    Please look at this list and let me know if I'm missing anything. I spoke briefly with the parts department at my local dealership over the phone, they seemed very busy and not interested in making sure I was getting everything.
    It's for a 2012 v
    Disc Brake Caliper (Right, Front)
    Part Number: 4773012A70
    Disc Brake Caliper (Left)
    Part Number: 4775012A70
    HOSE, FLEXIBLE, NO. 1(FOR FRONT)
    Part Number: 9094702G30
    HOSE, FLEXIBLE, NO. 2(FOR FRONT)
    Part Number: 9094702G31
    Disc Brake Rotor (Front)
    Part Number: 4351242040
    FITTING KIT, DISC BRAKE, FRONT
    Part Number: 0494742050
    Disc Brake Pad Set (Front)
    Part Number: 0446542200
    Disc Brake Rotor (Rear)
    Part Number: 4243147080
    SHIM KIT, ANTI SQUEAL(FOR REAR DISC BRAKE)
    Part Number: 0494647080
    FITTING KIT, DISC BRAKE, REAR
    Part Number: 0494847020
    Disc Brake Pad Set (Rear)
    Part Number: 0446647051
    Thank you!
  2. DHurt
    DHurt Junior Member
    17
    Palm Bay, FL
    I bit the bullet and ordered the parts listed, I'll find out if I got everything when they come in and I start swapping parts.
    Part Description Quantity Price
    0446542200 Disc Brake Pad Set (Front) 1 $73.03
    0446647051 Disc Brake Pad Set (Rear) 1 $46.58
    0494647080 SHIM KIT, ANTI SQUEAL(FOR REAR DISC BRAKE) 1 $27.20
    0494742050 FITTING KIT, DISC BRAKE, FRONT 1 $21.37
    0494847020 FITTING KIT, DISC BRAKE, REAR 1 $17.95
    4243147080 Disc Brake Rotor (Rear) 2 $56.65
    4351242040 Disc Brake Rotor (Front) 2 $53.26
    4773012A70 Disc Brake Caliper (Right, Front) 1 $125.56
    4775012A70 Disc Brake Caliper (Left) 1 $123.44
    9094702G30 HOSE, FLEXIBLE, NO. 1(FOR FRONT) 1 $77.57
    9094702G31 HOSE, FLEXIBLE, NO. 2(FOR FRONT) 1 $77.57
  3. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    SHIM KIT, ANTI SQUEAL(FOR FRONT DISC BRAKE
  4. DHurt
    DHurt Junior Member
    17
    Palm Bay, FL
    Thank you!
    vvillovv likes this.
  5. MattFL
    MattFL Member
    187
    55
    Were these part numbers correct? Thank you for posting them!
    I'm trying to find new rear rotors for my 2012 Prius, for some reason there's no listing on the autoparts.toyota.com site for the rear rotors, but a google search came up with part# 42431-06110, and you have here listed part# 42431-47080. The Toyota web site shows neither fit my VIN so I'm not sure what to order. When I put my VIN into the Toyota web site, it translates to: "2012 Prius Three 5Dr. Sedan, 2WD 1.8L L4 CVT".
  6. vvillovv
    4,324
    1,512
    NY
    for your 2012 Prius rear brake rotors try this part # 42431-12310
    looking up the number you posted above 42431-06110 on toyotapartsdeal.com says that rotor doesn't fit your 2012 Prius.
  7. MattFL
    MattFL Member
    187
    55
    Thanks for the response. Part# 42431-12310 is a drum, but my car has disc brakes in the rear.
  8. vvillovv
    4,324
    1,512
    NY
  9. vvillovv
    4,324
    1,512
    NY
    I double checked using the part # I posted above in browser search after you said that part came up as a drum brake part. And I too saw some links is the search results saying drum brake. Go to any toyota parts web page and you should see that part number is for a disk rotor and a disk rotor that fits your Gen 3. 2012
    if your part(s) are out of stock or backordered for some reason, once you are sure you have to right part # for your car it's a lot easier to find after market brake parts that are near to if not equal to OEM brake parts, except for the pads (I read recently that Toyota OEM pads are the best according to testing results) at Arts Garage berkeley .
    #9 vvillovv, Jan 3, 2024
  10. MattFL
    MattFL Member
    187
    55
    Thank you everyone for the replies. This is to close the loop for the next person with the same question as me; I took the car for new tires yesterday and told them go ahead and put the new rear brakes on (I got lazy) while they have the car, but they called and said it did not need rear brakes so nothing to do. Which is interesting, because the car was at the dealer a few months ago for a recall and they told me the rear brakes should be replaced. So all of this to say, I did not order the discs and therefore cannot verify the part number, but I will save all of this info for when it does need rear brakes. :)
  11. Mendel Leisk
    41,865
    In Florida rotors will likely last the life of the car. Unless rotors are hopelessly rusted up, I would first check rotor runout and thickness (requires magnetic base dial indicator and micrometer, both of which can be acquired for under $100 USD). This is for Prius v? I don't have Repair Manual for that, but 3rd gen Prius should be "similar", at least for rotor specs. For definitive, a short term Tech Info subscription would help. Attached is for 3rd gen Prius.
    MattFL likes this.
