1. Trollbait
    12,430
    Well, it's not actually loose. The gap between the right, rear quarter panel and bumper is a smidge wider than on the other side. Plus, there is some more give when I pull up on the bumper. Could someone point me in the direction of a bolt or clip that I could try tightening up?
    Thanks
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I'm nowhere near a digital camera but there is a 10mm bolt/screw around the rear wheel fender. It's on the edge of the rear wheel fender liner...about a 11 o'clock position. If you unscrew you will be able to "pop out" just the tip of the bumper and possibly slightly relocate it to your desired position.
