Why do I only get around 380 miles range for my Prius 2020 XLE AWD?
Discussion in 'Gen 4 Prius Technical Discussion' started by Tianen Chen, Mar 11, 2022.
  1. BiomedO1
    3,155
    1,668
    SacTown, Ca
    IMHO; "jack-rabbit" starts and stops is hard on the car and mpg. I had a friend, and that was his driving style - I'm guessing since day one. I don't know how he got his drivers license. When you ride with him, you better be wearing your seat-belt or you might hit your head on the dash board. Well maybe not that bad; but your body will shift forward and you know when he's on the brakes - without looking. He always complained that all OEM car manufacturers lie; since he can never get close to EPA mpg; even on his new car. When I told him it was his driving style; he called BS on me. So we switched cars for a week, filled the tanks, and reset the trip meter. I let him use my "dirt truck"; not my daily driver. When we swapped back cars, I easily achieved OEM EPA mpg - and told him to get the brakes checked; they've got a lot of "run-out" and pulsates on light braking. He stated that it was due for new brakes, "it's got 20K miles on them".(n):cry:
    Moral of the story: You've got a computer, that's rating your driving habits. You can simply choose to ignore it and ask us why the car isn't performing as specified by the OEM - and we can just keep giving you excuses on what's what.... Now that's FREEDOM....
    Sorry for the "soap box" lecture in advance...
    #21 BiomedO1, Apr 7, 2022
    dacoobob likes this.
  2. Tideland Prius
    16,504
    Well I guess we’ve found the potential issue.
    Try getting 4 squares at least. And use the blue accelerator guidance to help.
    BiomedO1 and jerrymildred like this.
  3. yetanothergreenprius
    Northern California
    could it be the roof box causing extra drag?
  4. Tianen Chen
    Tianen Chen Junior Member
    43
    United States
    2020 Prius
    XLE AWD-e
    By the time of the OP, no roof box had ever been installed
  5. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    Well there's your problem. Drive less aggressively and your fuel efficiency will increase.
    Mambo Dave likes this.
  6. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    I do not think so
  7. jdenenberg
    jdenenberg EE Professor
    3,937
    1,934
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I get about 500 mile range (summer, not winter) in my 2020 AWD Prius.
    JeffD
  8. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I've only had my FWD Gen 4 for less than 1000 miles/1 month but here are my observations so far. I'm averaging 53 mpg. One thing that really seems to affect the mpg of individual trips is speed. When I'm on a highway with a speed limit of 65 - 70 mph, my mpg is in the high 40s. Another problem is urban areas with stop signs or stop lights on every corner. It's not as bad as my Gen 2 on those trips but still under 40 mpg.
  9. bisco
    51,539
    you don't think less aggressive acceleration saves fuel?
  10. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    Do you primarily drive in cities, Jeff?
  11. jdenenberg
    3,937
    1,934
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, much of my mileage is on the interstate system at about 72 MPH. I do run my tires at 42(F)/40(R) PSI.
    JeffD
  12. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    You are wrong, but ok. Enjoy your poor mileage I guess :whistle:
  13. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    We have discussed previously that overly slow acceleration hurt MPG even more than fast acceleration.
  14. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    How’s the terrain in where you drive, mostly flat?
    I drive in huge windy mountainous terrain in Inland Northwest
  15. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    In my experience, urban driving provides better mileage for my 2020 Prius AWD XLE than high way driving is.
    jerrymildred and Mambo Dave like this.
  16. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Urban I can get upwards to about 48 to 50 MPG.
    But I don't drive that often. I'm doing something at the moment that has me more at 36/37 MPG, but I'll put it back to 39/40 soon enough.
  17. Doug McC
    Doug McC Senior Member
    1,055
    402
    Midwest
    2022 Prius
    If I read the OM correctly, the displayed range is based on fairly current mpg (within minutes), while your odometer mpg is just that, averaging all the times you drive in an intelligent manner, and the times you drive in a less intelligent manner (ie: ignoring the laws of physics and then wondering why you get bad gas mileage).
    The distance to empty is one of the most useless bits of info these cars provide.
    Tianen Chen likes this.
  18. Mendel Leisk
    40,985
    I wouldn't even be able to find Distance-To-Empty on ours (3rd gen). If I'm trying to determine when to get gas, there's the gas gauge, lol. And if you're trying to determine your mpg, one of the trip meters reset when you fill up will give you a "rosy" estimate, invariably optimistic, anywhere between 5~10%. For semi-accurate, lopping 7% off what it tells you is pretty good. For accurate: distance-traveled-divided-by-gallons-pumped works. Liters per 100 kms is slightly more convoluted.
    Doug McC likes this.
  19. jdenenberg
    3,937
    1,934
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Hills/mountains here in the Northeast, but winds, not so much except when there is a "Noreaster" (not when driving).
    JeffD
    Doug McC and Tianen Chen like this.
  20. Tianen Chen
    43
    United States
    2020 Prius
    XLE AWD-e
    Ok… I’ll be more patient in the future then, until I run out of patience.
    bisco and Doug McC like this.
