Remote fob requires closer proximity now....
Discussion in 'Gen 2 Prius Main Forum' started by Toyotally04, Apr 9, 2022.
  1. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    I always have my keyfob in my pant's front pocket. It used to be that I can approach the car within a few feet that the car would beep and unlock.
    Now I have to stand next to the door handle for the car to remotely unlock.
    Not sure whether this is a battery thing, because I didn't change batteries that long ago.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    I would start with the fob battery. Have you already tried the second fob to see if it behaves the same?
  3. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    I don't know where the spare fob is.
    Also, anyone know where I can get replacement screws for the fob... the screw heads are pretty stripped, I think.
  4. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Just because the battery was "new" doesn't mean it was good. If the battery is anywhere approaching 2.9 V, it needs to be replaced. Check the battery with your voltmeter.
  5. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    The screws that Toyota supplies are an odd size. I think they are 3.5 or 2.5 Phillips heads. Most people don’t have those half sizes so they routinely strip the heads. You may be able to find replacement screws at a large ACE hardware rack that will work.
  6. Stevewoods
    Stevewoods Senior Member
    663
    1,201
    Seattle, WA
    You most likely will fail trying to find replacement screws at a hardware store. Try a jeweler that does watch repairs or the dealership or ebay or online parts -- but dealer would be my choice
    89759-47010 Genuine Toyota Screw, Door Control
    SFO likes this.
  7. bisco
    52,396
    and check the 12v health
  8. PriusCamper
    PriusCamper Senior Member
    13,075
    5,306
    Pacific Northwest, USA
  9. Stevewoods
    663
    1,201
    Seattle, WA
    Yeah, and rather than fumble through laptop screws, which may, or may not fit, you can spend less than $2 and get it either the same day or the next day from the dealer. And, at the dealership I usually visit, if they have it in stock -- not likely, but -- odds are they will replace it for me and "gift" me the screw for a total cost of zero and NO work on my part. :)
    If they order it in, well, then I have to spend the whopping $1.50 (which is pricey for one screw), but they still will "install for free." :p:p:p
    Once I ordered, then tried to get them to install the passenger side-view mirror for free, but they balked. No big deal, a 10-minute job.
    #9 Stevewoods, Apr 9, 2022
  10. cyberpriusII
    1,157
    1,840
    Hyampom
    My repair efforts are not as aggressive as they used to be, but I always appreciated it when the dealership -- surprisingly -- gifted a small part and installed. It has happened a couple of times.
    Of course, it has happened at NAPA Auto Parts, my local tire shop, hardware store, etc., also. I think it depends on how you treat people. I always try to make friends. Better than the alternative. As I have learned (the hard way --), life is fleeting.
    Kris
    #10 cyberpriusII, Apr 9, 2022
    SFO likes this.
  11. SRQ
    SRQ Member
    158
    56
    If you purchase a new FOB shell, make sure you transfer over the all electrical components within the FOB. I left some kind of metallic strip (don't remember exactly what it was) and my FOB didn't work properly until I dug up the old FOB and transferred it over.
    SFO likes this.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    Yep, that's the "RFID" chip for the immobilizer - it works when you put the fob in the dash slot.
  13. Another
    1,819
    517
    Naples, Florida
    The odd size of the OEM screw head is a PiTA. That is why they get stripped because most people don’t have the right size Phillips driver. I gave a 36 piece driver assortment from Amazon and this is the only time I can reall ever using a half size. I thought the head was stripped, was just the wrong size that I was trying.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Couple things:
    1. Your range symptoms are very normal for a fob battery getting weak. Buy and install a quality CR2032, not a cheap chinese dollar store battery.
    2. I've replaced a LOT of Gen 2 fob cases with aftermarket ebay cases. NONE of them have the same size screws as the OEM, always slightly larger and easier to deal with. They are not interchangeable with OEM screws.
    3. It's likely you'll spend way too much time and effort trying to find replacement screws for the OEM fob. See below.
    4. Most likely, the OPs FOB buttons are worn and need replacement anyway, so just spend 7 bucks and buy a new case. Make sure you transfer all components, including the RFID chip or you'll hate life later when you need it. Make sure you move your OEM key to the new case. Put your old case parts in a ziplock bag and keep them. That way, a month from now when you realize you still forgot to move the RFID chip, you'll still have it.
