"Check the Connection of the Air Conditioner" MFD Warning?
Discussion in 'Gen 2 Prius Technical Discussion' started by Kactus, Apr 8, 2022.
  1. Kactus
    Kactus Junior Member
    39
    Los Angeles, California
    hello!
    my MFD isn't working. the screen shows: "check the connection of the air conditioner". actually, it will occassionally work but then not work for long periods.
    the prius boards point to a bad MFD screen as the main culprit. so I bought a used one off ebay that the seller said worked, but the problem persisted.
    problem solving:
    1. the ebay MFD could've also been broken.
    2. there's another issue that could be causing it? is anyone aware of another possible issue which could be causing this?
    **note, it could be a coincidence but the problem began just after I had a new aftermarket hybrid battery in? I've had no issues with the car or battery otherwise. taken it on long trips so the hybrid seems to work fine. but thought potentially there could be a link between the hybrid battery and the MFD? shot in the dark! ;0
    any thoughts on this greatly appreciated!
    cheers john
  2. PriusCamper
    PriusCamper Senior Member
    12,986
    5,281
    Pacific Northwest, USA
    How old is your 12volt battery? Have you tried putting it on a legit 12v charger for recharge? Also replace the cabin air filter and please give us some details on how well climate control works when screen is functional.
    Kactus likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  4. spdracrm3
    spdracrm3 Member
    58
    47
    estacada or
    Had to have my MFD repaired at local computer shop for this condition(see MFD link above) i removed disassembled and took in and pointed out right where the suspected issue was as seen in link and they inspected and reflowd the entire connector. Working great 3 yrs on
    SM-G960U ?
  5. Kactus
    39
    hello...the 12v is almost brand new. and the cabin air filters have been replaced fairly recently as well. the screen doesn't work at all for the AC anymore. When it was of and on... the climate control worked fine. I could operate it with no issues. Then I'd park the car and try again an hour later and the same error message.
    Btw.... I just tried a different replacement MFD from ebay and am getting the same error message.
  6. Kactus
    39
    thanks SFO...I'd been thru a bunch of search results on MFD. but didn't see the one about the culprit possibly being the AC ECU? will search more in that direction.
  7. Kactus
    39
    thanks...but again i've replaced the MFD with two separate ebay units and getting the same error message>
  8. Kactus
    39
    hi again....I didn't want to assume anything with the 12v. I just did a voltage check using the MFD and the battery readings were:
    during test no accessories: 12.1 v
    stand by mode? (pressed power again): 11.9-11.7v
    engine on: 14.4v
    do those look right? I do remember now that I've replaced the 12v battery a few times in past year. I assumed I got a bad one? not sure if there's an underlying issue that draining it?
  9. PriusCamper
    12,986
    5,281
    Buying a decent 12v battery charger could improve your odds... But you want at least 12.6v at the jumper at the front of the car when car is off to be sure it's not gonna create any issues.
  10. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Looks low. Get a digital battery load tester $29 KONNWEI KW208 from the "River"
    Test it properly at front jump point.
  11. Kactus
    39
    actually have one and did a test this AM from the battery itself:
    after sitting overnight: 12.41v
    standby mode: 12.33v (slowly rising)
    load test (headlights 20 sec): 12.26v
    car on: 14.10v
  12. Kactus
    39
    cheers- i did a proper test w/ meter this AM after the car was sitting overnight. if I need to be at 12.6v with car off, i'm about .2 below that (see new readings below), could that little amount cause the MFD issue?
    car on: 14.10v
  13. ChapmanF
    18,458
    Not by a country mile.
    Kactus likes this.
  14. James Analytic
    351
    53
    Michigan
    What did you find was the cause of the issue?
