Had an accident my 2013 Prius needs to be towed lifting the back ?
Discussion in 'Gen 3 Prius Technical Discussion' started by Markee, Apr 14, 2022.
  1. Markee
    Markee Member
    334
    South Florida Broward County
    Is there a specific way it needs to be towed in order to not damage the vehicle ?
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    put a new tire on there or add some air. Then ask for a flat bed tow truck
  3. Mendel Leisk
    41,329
    Just from what I’ve seen: tow truck operators would put back wheels on a cradle (with wheels), then lift and tow from the front.
  4. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    Either put the spare on or use a set of dollies:
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    IF.....that is the only damage, put on a new tire and drive it to the shop.
    IF......it really needs to be towed with no access to the front for the wrecker, then yes they either put the car in Neutral if it "runs" or they jack up the front and use dollies to get it out into the street.
  6. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    The owner's manual warns not to tow backwards (even in neutral) with front wheels on the ground.
  7. sam spade 2
    7,035
    2,801
    2017 Prius c
    Yes. True.
    But rolling or pushing it backwards far enough to get TO the front hardly qualifies as "towing".
  8. fuzzy1
    10,409
    ... or just drag it out of its parking space far enough for the wrecker to get better access. The locked-wheel drag won't hurt the car at all, and the distance ought to be short enough to be of little consequence to the tires.
    The response did say "towed", and there was more than one way to read it, so the clarification could save a few readers some grief.
  9. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    It's no big deal to drag the car for better access.
    Many tow drivers carry a jumbo bottle of dish soap to lube the tires & pavement when they need to do this.
  10. tak1313
    tak1313 Member
    MA
    Towing instructions from the manual. That's not to say you can't at least MOVE the car backwards for the sake of access/positioning.
  11. Markee
    Markee Member
    334
    So the original guy that towed the vehicle to my house from the accident scene said he owns 2 Prius and said the car needs to be in neutral to tow it. Then he strap tied something inside the cars steering wheel to stop the steering wheel from moving put the car in neutral and lifted the back and towed it to my house pulling it from behind. When it got towed from my house to the body shop they used a flatbed .
    Do you think this damaged my tranny and how will I know ?
    How do you think i should to handle it should i tell the claims adjuster?
    The original tow from the accident scene was not connected to my insurance it was just some random tow company I googled and called.
    #11 Markee, Apr 18, 2022
  12. tak1313
    tak1313 Member
    MA
    I don't see anything about being able to tow from the rear if in neutral. You may want to call your local dealer to discuss the matter and what the ramifications are (if any).
    EDIT - forgot to mention, as the Prius does not have a torque converter (it uses a variation of a CVT), there is no "slip" as would be allowed in an old style transmission with a torque converter - plus the fact that the transmission has some pretty sensitive stuff related to the hybrid system.
    #12 tak1313, Apr 18, 2022
  13. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    A couple of guesses why they don't want you towing backward, even in neutral: 1) Possible excessive speed of motor-generator #1 (for either structural or back-emf reasons); 2) Lubrication issue in the transmission.
    Obviously rolling the car backward a very short distance at very low speed is harmless; I do that practically every time I go anywhere..
  14. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    CVT WS fluid pumps when wheels rotate forward
  15. douglasjre
    2,164
    715
    Null, NL
    Car looks totalled anyway. Won't matter unless u do like we do in NY and body fill it til it looks like a cab
  16. fuzzy1
    10,409
    Prevention of mechanical overspeed of MG1 is the reason why the ICE must spin when the car is moving above some threshold speed, even if it burns no fuel. That max speed varies by generation and model, and is about 46 mph for Gen3 Liftbacks, a bit lower for Gen2, about 60 for Gen4, and higher for plug-ins than there non-plugin siblings. Since a towed car cannot spin up the ICE to protect MG1, this places a cap on the allowed tow speed. For Gen3 and earlier, this max speed is significantly lower than highway speed.
    There is some built in safety margin, we don't know how much, other than some coast-in-Neutral daredevils have exceeded this max speed a bit without admitted damage.
    This isn't to say that MG1 overspeed protection is the only reason to limit tow speed, there may be other factors demanding lower max speeds. The 18 mph limit in the owner's manual excerpt above does strongly suggest some other limiting factor is also present.
