ABS light is on
Discussion in 'Gen 2 Prius Main Forum' started by Larry Kosher, Apr 18, 2022.
  1. Larry Kosher
    Larry Kosher New Member
    Pittsburgh PA
    Hello.
    05 Prius, had been sitting for a while before getting acquired by a friend of mine. The extended outside parking resulted in the rear brakes rusted out. We've got a replacement from a local junkyard. That included bearing assemblies and all the drums, etc. Having all that installed we are struggling to bleed the system. I've got a cheap VCI USB with teachstream software and we were trying to use that for the bleeding procedure. However, the ABS light is always on and the active test procedure in teachstream always fails. A while ago there was a trouble code regarding an open circuit for the RL vehicle speed sensor. It took us a while to investigate the issue, and I'm not sure what was it at the end, but that trouble code is gone. Not the ABS light, however. Thinking that it might be a damaged ABS/skid module we swapped in another one from the junkyard. That didn't help. However, there was a moment when the brake red light on the left of the dash wasn't on. Now it's back on again. Of course, all the fuses and relays checked/swapped from a working car, etc. How do we investigate the issue? What could it possibly be? No trouble code in the ECU now, resetting the ABS light doesn't help - it stays on.
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    That doesn't make sense. If you have a trouble light for the ABS showing on the dash there will a one or more codes in the ABS/TRAC/VSC section of Techstream. Finding out what they are will go a long way toward knowing on what to focus.
  3. ChapmanF
    15,562
    You could also use the code-blinking method to see if any codes are reported that way. I usually reserve that advice for people who are using scan tools other than Techstream; Techstream really ought to have no difficulty here. But as dolj said, the light with no codes makes little sense.
    (It could, of course, be a malfunction of the light itself in the combination meter. You can probably find steps in the repair manual for troubleshooting that. But that seems highly unlikely to be the story here, with the background you've given.)
  4. Larry Kosher
    Pittsburgh PA
    Okay, teachstream now reports these. These weren't there before. What's going on? I'm certain it is not a bad 12-volt battery. I did test that.
  5. ChapmanF
    15,562
    If you're confident the power is ok, then it is likely those codes mean what they say, and you have communications issues to diagnose.
    That's a bit fiddly to do, but you'll find the information for doing it in the "CAN communication system" section of the repair manual.
    Toyota Service Information and Where To Find It | PriusChat
  6. Larry Kosher
    Pittsburgh PA
    I am ashamed to confess, that it turned out to be a bad ground wire from the 12-volt battery. All is fixed now, thanks, everyone!
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,502
    NJ-USA
    Well you fixed it, so that's good. It ain't likely that you'll overlook THAT particular bit again- that's how you learn. Make a mistake- then fix it.
    Larry Kosher likes this.
