WHY IN THE HELL Is our car going through OIL PRESSOR UNITS ?
Discussion in 'Gen 3 Prius Main Forum' started by LARRYG36, Apr 24, 2022.
  1. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    Maybe i'm putting a little too much in it. First one i bought at the dealer ship, second i bought of O'Rielly's.
    51,711
    doesn't sound right, how many miles on her?
    what is an oil pressor unit?
  3. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    The Membrane brakes then the oil drains out through it.
      File size:
      31.9 KB
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,426
    2,393
    Taylors, SC
    It's well known that any oil sender must be installed with a special oil sender socket or the hex might be distorted and caused to leak at the seals inside.
  5. ChapmanF
    17,926
    I never knew that. :oops:
  6. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    Lisle 13250 Oil Pressure Switch Socket
  7. bisco
    51,711
    i thought everyone knew that (n)
  8. ChapmanF
    17,926
  9. rjparker
    9,992
    6,183
    If I knew it I forgot it when I was stressed out messing with the Harrier Jump Jets
    Montgomery and JahT like this.
  10. CR94
    CR94 Senior Member
    2,681
    1,161
    Northwestern S.C.
    The one I installed in my Mazda with a regular deep socket never leaked in the remaining ~440k miles I had the car. Maybe I didn't overtighten it enough to distort it.
    Elektroingenieur likes this.
  11. Elektroingenieur
    2,515
    3,282
    Three Touring
    The Repair Manual (more info) says, when installing the engine oil pressure switch assembly, to use a “24 mm deep socket wrench,” with no mention of any special service tool. The stated torque specification (15 N·m) is much lower than for typical M16 or M18 bolts, however. The technician is also instructed to apply Three Bond 1344 adhesive (for which other Toyota publications identify LOCTITE 242 as equivalent) to two or three threads before installing the switch, and to wait at least an hour after installation before starting the engine.
    jerrymildred likes this.
  12. bisco
    51,711
    obviously, whoever wrote the manual didn't know
    JahT likes this.
  13. BiomedO1
    3,362
    1,751
    SacTown, Ca
    I've only used an oil sender socket on those oddly shaped ones - though you do need to be gentle with them. Never over-torque them or they will leak, down the road. I also use teflon tape on the threads, so if it feels like it's binding - I stop there, even though I haven't reached the specified torque specs. I only had to replace one unit a second time, factory defect - kept dropping out.
  14. Mendel Leisk
    41,143
    Yeah 15 N/M's equates to 11 foot/pounds, very low. 3/8" or 1/4" drive torque wrench would be good.
  15. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    As I recall, the industrywide standard for oil senders hearken back to the early days of automobiles. It is not metric buy 1/8x27 National pipe thread. Tapered pipe threads generally require a high torque value,
    Thus, there is a need for some sort of sealant at low torque.
  16. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    All good info guys, Sooooo, is it - (1) to much oil at one of the oil changes, (2) wrong Socket (3) Torque, too much or not enough (4) No tape or thread lock ???
  17. bisco
    51,711
    i have never heard that too much oil can do it, and we've had plenty of too much oil reports.
    this is a pretty unusual problem
  18. Mendel Leisk
    41,143
    Only you can answer those. Are you torquing it to 11 foot pounds?
  19. ChapmanF
    17,926
    The world is weirder than that. NPT (national pipe taper) is "national" to the US. The standard Toyota is using is BSPT—a British standard, but one that more of the world uses.
    It is still designated in inch fractions. But several things are different. A 1/8 BSPT has 28 threads per inch, compared to 27 for 1/8 NPT. It can be close enough to seem to be threading in ok, but not really.
    Adapters from BSPT to NPT are available, and often included in oil pressure test kits.
  20. Mendel Leisk
    41,143
    So maybe a previous owner installed a NPT thread variant PCV valve?
    If that’s the case, at least the PCV valve screws into a small bolt-on plate, not directly into the block.
