Tilt alarm
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Lodrun, Feb 28, 2020.
  1. Jenny2010Prius
    Jenny2010Prius Junior Member
    37
    Calgary
    2024 Prius Prime
    SE
    Can you please advise how to add a "mercury switch" to a Prius' factory alarm, which I think is a door alarm only?
    A diagram drawing or photos will be really appreciated.
  2. Jenny2010Prius
    37
    Calgary
    2024 Prius Prime
    SE
    Do you connect one leg of the mercury switch to the relay 87a, the other leg to the Factory alarm door switch signal line (green one)? Relay legs 30, 85, 86 stay the same as in your diagram.
    Or can the mercury switch be connected directly to the ground & door switch signal line (green one)?
    #22 Jenny2010Prius, Apr 26, 2022
  3. JahT
    JahT Member
    145
    77
    Did you see this diagram for the mercury switch, it goes between the door pin wire and ground?
    I have ordered one of the 507M tilt sensors, but I have an Omega AL-101 alarm box I can wire it to.
  4. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    Mercury switch connected in parallel to plunger switch, that white line is factory one, in black sleeve need to find wire without ground to connect to.
    Let me know if more questions,
    SFO likes this.
  5. MSusbilla
    MSusbilla New Member
    Stockton
    Hi Victorio. Do you know if your diagram also applies to a gen 3 prius?
  6. PeterJD33
    PeterJD33 New Member
    Sweden
    After 2nd cat stolen with Toyota tilt alarm installed it is obviouse it doesn't work. Instead it gets more costly. The thief knocks the driver side window, opens the hood and disables the alarm siren. Then it is no problem to jack the car up. They had 4 Prius' in the workshop with crashed side windows. So don't spend money on a tilt alarm unless you can hide the siren somewhere else. I will sell my Prius as a result of this.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,689
    803
    Southern California
    That is why people often also install "broken glass" alarms.
  8. BiomedO1
    3,766
    1,958
    SacTown, Ca
    Glass breakage and hood sensor. Unfortunately you would still have to deal with a broken window, even if they don't get to the CAT. In most cases, a good CAT shield would be enough of a deterrent.
