What is this? (piggyback wiring on door harness)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ToyXW, Apr 27, 2022.
  1. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Some idiot creased my driver's side door and the insurance is fighting the claim so for the time being I'm throwing on a junkyard door of the same color (hopefully the fading isn't noticable from 10 feet away, but for now it'll still be better than a big nasty rusty crease).
    Anyway, I go to unclip the door's wiring harness and I see this abomination piggybacked onto the door harness? I bought the car used and don't think I have any aftermarket accessories, but I'm not sure if this goes to something I don't onow about. Any idea what it is for? Aftermarket alarm maybe?
  2. ChapmanF
    18,555
    Nice, a little whodunit for you....
  3. PriusCamper
    PriusCamper Senior Member
    13,071
    5,306
    Pacific Northwest, USA
    Looks like 5 wires and a ground wire were added for some type of aftermarket device... What's the history of the vehicle?
  4. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    No idea what previous owners did - I've owned it for 4-5 years. I put the new door on without reattaching this afternarket wiring and the windows work, but the auto up/down no longer works and I can no longer roll the window down immediately after turning the car off. So I'll have to reattach it...
  5. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    So I was driving it tonight and dreading the thought of crouching over half the day tomorrow trying to rewire that in when I noticed the driver's window switch blinking:
    Blink Blink pause blink blink pause... Reminded me of reading OBD1 toyota codes...
    I search the web for "toyota power window switch blinking" and see a thread on priuschat where a Gen2 12v battery change caused the blinking switch. The solution in that thread was to recalibrate the auto switch by turning the car on, lowering the window half way, and then raising the window all the way up and continue holding the switch up for an additional 5 seconds.
    That didn't quite work for me so I tried a few different things and found the procedure for the gen 3:
    Turn the car on (to "ready" - accessory "on" won't work). lower the window all the way. Raise the window all the way and continue holding for 5 seconds. If it is dark and your lights are on, you'll see it stop blinking. So now my auto up/down works again as well the switch working for ~30 seconds after you turn the car off (or until someone opens a door).
    Yay for simple fixes...
    ASRDogman likes this.
  6. PriusCamper
    13,071
    5,306
    I bet @ChapmanF has some thoughts on this one...
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,501
    Taylors, SC
    I'd mark and unplug the piggyback connectors and disconnect them, and see what happens. Then, I'd trace the piggyback wires to see what is connected to them.
    The window issue is likely not connected to the piggyback.
  8. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    The driver's side is disconnected now and everything still works. I believe the passenger side probably has one too based on that kick panel never having the factory nut holding it in place.
    I looked back over my original carfax and the car's first owner owned it from late 2009 to late 2011. The 2nd owner bought it in 2012 and I bought it from him in 2017.
    At the time I was a little surprised he still had a lein on it 5 years into used car ownership - and that the loan payoff being nearly as much as the car was worth. So now I'm thinking maybe he got a title loan at some point and had sketchy credit so the finance company installed one of those GPS devices?
    Maybe that's why even a brand new 12V battery will go dead if you park it for 1 month...
  9. ChapmanF
    18,555
    Yup ... that's how it tells you it wants to learn where up is.
    PriusCamper likes this.
  10. JahT
    JahT Member
    145
    77
    I bet it is a dealer "alarm box" like mine, not the factory alarm but an add-on box. You'll probably see it zip tied up near the steering column. My understanding is that all dealers add these on to all new cars, they use them for security on the lot and then try to over charge you for it as a feature later. So even if you opt out of buying the alarm they have already tapped into your wiring harness.
    Funny thing, now that I am looking into adding a tilt sensor to our alarm I look up the specs. It was sold as a Rockledge Security System, but that turns out to be just a made up company owned by the guy that owns the dealership, and the name Rockledge is the taken from the name of the street he lives on. It isn't even their product, it is just a standard Omega UltiMate AL-101 which is a universal alarm box for adding features like the shock sensor they put in. So technically it does improve the factory alarm by adding a shock sensor.
    ToyXW likes this.
  11. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    I couldn't see, but I could sort of feel the wires and I am reasonably sure 3 of them forked off and plugged into this fake diagnostic port looking thing:
    PXL_20220428_223424643_exported_1651185384268.jpg PXL_20220428_223435400.jpg
    It was attached with self-taping screws to the very bottom of the interior panel below the steering column. The blue button is the only user-interface thing on it. "Tested 155/10" makes me think May 15, 2010? Or day 155 of 2010 (June 4th)?
    But I'm more motivated to remove it all after seeing some discoloration on the foam on the kick panel:
    It looks like a burn mark, but the wires are really greasy and have lots of gooey electrical tape residue. So it might not be a burn, but it doesn't reassure me...
    #11 ToyXW, Apr 28, 2022
  12. JahT
    JahT Member
    145
    77
    Yes that part number on the sticker points toward a dealer-installed Karr alarm system (add-on box).
    xliderider and ToyXW like this.
  13. JSB_99
    JSB_99 Member
    66
    48
    Houston
    The Karr alarm is exactly what i was going to say. Mine had one in it when I bought it a few months and i ripped it out. They were a money maker for Toyota Dealers.
    ToyXW likes this.
  14. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Did you have to splice anything to allow you to start the car or were you able to just remove the piggybacked clips and have the car function normally?
    I was reading on an Accord forum where if you just removed it the starter button wouldn't work until you made a splice...
  15. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Unscrewing the ground wire caused the horn to go off so that was fun for the neighborhood...
    JahT likes this.
  16. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    I bought my 2010 new from Toyota dealership in San Diego. It has the similar wiring behind the kick panal and it used to connect to some sort of pre-installed aftermarket alarm system option for additional $800. I delined the option and the dealership spent 5 minutes to deactivate and took away the module with a bright fleshing blue LED.
  17. Georgina Rudkus
    3,513
    2,501
    Taylors, SC
    A thief can do the same in 5 minutes. $800 save from the scamming stealership.
  18. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Mine didn't have the larger box, but there was an empty plug in the medium-sized box (the box with the blue plastic screw to adjust sensitivity) so maybe you got the other part if you agreed to buy the alarm:
    I did not have to cut or splice anything, just removing the wires worked although the connector with the red/white wires at the bottom of the picture liked to set the horn off if it jostled until I completely removed the ground wire.
    Unfortunately, I now have a check hybrid system light. I did forget to plug in this factory white wire connector when I first started the car so I don't know if that might have tripped it:
    The hybrid battery has sort of been acting like it does shortly before going bad though. For instance when I went to move the car into the garage (before removing the rest of the alarm) I attempted to use EV mode and the prius rejected my request. This despite 6/8 pips on the factory SOC gauge, 55% SOC on the scan gauge, and a pleasant ~75 degree temperature.
    The scangauge shows no codes, but I only scanned after I plugged that connector back in and replaced the power mirror/dimmer switch panel. I'll try unplugging the 12v battery for a while and seeing if that resets it.
  19. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    The check hybrid message was from that white plug - I didn't even disconnect the battery, it cleared on its own after 3 short drives.
    Unlike when the battery went bad, it only had one orange warning light. It also would drive like normal and shut off the ICE at stoplights...
    I still ordered an OBD2 dongle to use the dr. prius app going forward though
    JahT likes this.
