Featured Toyota bZ4X Specifications Revealed
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Oct 29, 2021.
  1. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Not for Toyota. They typically use 4 ports in the US. Port of Long Beach, Port of Benicia, Port of Jacksonville and Port of New York and New Jersey. Another car maker might use Corpus Cristi.
    They’ve been increasingly using Lázaro Cárdenas, MICH
    Mexico which is on the Pacific side to relieve some of the backup at the California ports. Then they just truck them up towards Texas which might be cheaper all around.
    iPad ? Pro
    #321 drash, Apr 24, 2022
  2. Trollbait
    12,534
    At least it was before the governor started insisting on additional inspections of trucks.:rolleyes:
    drash likes this.
  3. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    Inspections are over. The secondary inspections found nothing but spoiled a lot of food. Estimates it cost texans $4B and the country $9B. He claimed it was successful. By every metric he hurt texas.
  4. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    bz4X review and first drive from The Out of Spec Motoring channel - 56 minutes
    be prepared - Kyle has driven Tesla models for years.
    Limey Geoff and dbf like this.
  5. dbf
    dbf Member
    78
    86
    NE Ohio
    Looks like the car has a lot to offer, but the price is out of reach.
  6. hill
    8,803
    Interesting take away from them was that it's $10,000 more than a Chevy Bolt (where they feel its actual segment lies) but it charges faster.
  7. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    No, none. Port of CC is primarily petro-chemical with some agriculture. It is not a container port nor have ro-ro capability. After the new pass-over harbor bridge is completed with much high clearance, things could change.
    drash likes this.
  8. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
  9. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
  10. Trollbait
    12,534
    Has what the actual problem been explained?
  11. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Yes! The wheels might fall off, but only if you drive it
    You might call it a Bolt problem. Not that Bolt, the one that catches fire when you aren't driving it, but a wheel bolt!
    Mike
  12. Trollbait
    12,534
    But what part of the wheel is at fault?
    Early speculation is it is because Toyota switched from wheel nuts to wheel bolts. Others have been using wheel bolts without issue for years. The fix is taking too long for it simply be wrong torque for the bolts. Are the bolts failing? Or the hub plate they screw into? Or is it actually something else?
  13. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Toyota is conducting a safety recall involving 2023 model year bZ4X vehicles - Toyota USA Newsroom
    To paraphrase: "After low-mileage use, all of the hub bolts on the wheel can loosen to the point where the wheel can detach from the vehicle." "No remedy is available at this time. Until the remedy is available, any authorized Toyota dealer will pick up the vehicle and provide a loaner vehicle FREE OF CHARGE to the owner."
    That was as of today. So I plugged in a VIN into their owners recall status and it remains the same.
    Maybe they are rethinking the whole wheel bolt thing and plan on replacing the wheel hubs to accept normal wheel studs. It seems like an awful lot of time to determine whether it's a wheel hub issue or a wheel bolt issue. :cautious: And of course it's probably got a supplier issue hanging around in the back to exacerbate the problem. Maybe that's why they've suspended operations at the plant because they sent all of their spare parts to fix this issue. :rolleyes:
  14. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Wheel bolts will always be a solution in search of a problem.
    They have never been as reliable as studs, harder to self center and despite (ease of replacement) tend to also damage threads.
  15. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The common reason this happens is lack of stretch.
    What keeps bolts from loosening is stretch - the amount the bolt stretches when brought up to torque.
    A common rule of thumb is that the length of the fastener that is going to be stretched should be 4 times the diameter of the fastener. I've used this rule for about 30 years and never once had a fastener come loose, in some of the most demanding environments you can imagine (high vibration, fully reversing loads, extremely hard bolts, etc.). When a faster is shorter than that rule, you're supposed to use a locking mechanism (Loctite, nylon lock nuts, jam nuts, Stover bolts, locking washers, safety wire, etc.).
    Whether the fastener is a bolt or a stud makes no difference here. Studs are nice if you have to remove and replace the nuts often, but you also shouldn't be doing that. Fasteners will fatigue from having that done. Ideally, you replace the fasteners every time they are brought to torque (or tension) and then released. Obviously we don't do that with wheel studs. But maybe we should since I have had a couple break on me over the years. I think that's mostly from a monkey over-torqueing them with an air ratchet, however. I found a couple of 76 ft-lb rated fasteners at 250+ ft-lbs before.
  16. mikefocke
    3,994
    1,804
    Sanford, NC
    Wheel bolts aren't new to the automotive industry. Porsche uses them and lots of those cars are driven in high stress situations with lots of tire changes. (The included tool kit comes with special mounting stud/bolt to make mounting the wheel easier) So it isn't that bolts are bad, just in this application.
    austingreen and jerrymildred like this.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    If they have a way to locate the wheel while you start the bolt (technically a screw, since there's no nut), I can see how the might be a little more user friendly than the typical stud and nut.
    One of my first jobs, back in my college days, was in a tire center. I'm 69 now and have almost always rotated my own tires, and changed my own flats. Now I'm working part time on cars again. Two weeks ago, as I was putting a left front wheel back on a Prius, half way home, the stud spun and all the splines were stripped. Had to drill it out and replace the hub and bearing. Last week, a coworker was taking off a customer's (Camry) left front wheel (What is it with left front!!??), and he had a stud strip out. Oh, and he was taking off the wheel to replace a stud that had broken at some tire shop. So, one going on and one comping off. And those are the first times I've seen or experienced that happening. But it probably would not happen with a bolt since there are no splines to give out.
    But I really don't think it matters much which you use as long as they are speced properly and make it easy to keep the wheel in place while you start the fasteners.
  18. mikefocke
    3,994
    1,804
    Sanford, NC
    The Porsche mounting item is just like a bolt with the head cut off you hand screw halfway in and then remove once you have hung the wheel on it and screwed in several of the other bolts. The real bolts have a shaped collar to allow the bolt to slide and make good contact into the hole in the wheel. Maybe that is what Toyota forgot.
    People just cut the head off a common bolt when they have lost the original nicely polished special one in the kit. Of course replacing it is nicely priced if you want the Porsche one.
    jerrymildred likes this.
  19. bwilson4web
    16,204
    This is a sad report: Toyota is now offering to buyback recalled bZ4X EVs - Drive Tesla
    Toyota’s newly launched Toyota bZ4X is already facing a massive recall, and Toyota is now offering owners an option for the company to buyback the vehicle.
    Toyota has sent letters to buyers to advise them to continue not to drive the vehicle until Toyota can establish a fix.
    If owners want to keep their vehicles, they can:
    • Get reimbursements if the car was paid in full
    • Continued access to a loaner vehicle free of charge
    • Storage of their bZ4X
    • Free charging
    • Extension of factory warranties
    However, if clients are still unsatisfied with that offer, Toyota is now offering to buyback the vehicle.
    Bob Wison
  20. bisco
    51,901
    i am not an engineer, but it's hard to believe that this is such a difficult problem to solve
    Zythryn likes this.
