Lower fuel economy after CAT replacement
Discussion in 'Gen 2 Prius Fuel Economy' started by Gecko19, Jan 5, 2020.
  1. Gecko19
    Gecko19 New Member
    Hanworth
    Hello All,
    I have a gen 2 Prius with 105k miles on the clock. The catalytic converter on the car was stolen along with the 02 sensor. My local garage replaced the catalytic converter and the rear exhaust box(since it was corroded) along with the O2 sensor -- all after market parts. I noticed that 2k miles after the car chnage the mileage I get from a tank of fuel has dipped and also, the car seemingly is a bit more quicker to drive than what it used to be(before the cat got stolen) -- any ideas if the after market O2 sensor could be the culprit here, or is it just the winter(which is not bad and temps are in the lower 10 degree C). The cars 12 V battery was replaced 2 years ago .
    By dip in fuel mileage I mean from a consistent 51 mpg to consistent 45 mpg.
    Cheers,
    G.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Almost impossible for the new converter or rear oxygen sensor to reduce your actual fuel economy. Most likely just a coincidence and/or maybe you're driving it harder now?
  3. George W
    George W Senior Member
    911
    511
    San Antonio
    Are O2 sensors supposed to be changed in pairs, so that they match?
  4. valde3
    2,002
    745
    Finland
    No. And Prius does actually have air fuel ratio type sensor in the front. Rear sensor is oxygen sensor and is mostly used just to check that catalytic converter works.
  5. audiodave
    audiodave Active Member
    787
    268
    US
    Mine did that too. But my freeway milage is great. I'm curious how my fuel trims look, I'd bet its off from the normal range and I've considered replacing the front O2 sensor. After 260,000 miles the accuracy has to be a little off.
    George W likes this.
  6. audiodave
    787
    268
    US
    I also notice my oil get dirty fast too like the fuel trims are high. Maybe the rings I don't know.
  7. lexidium
    lexidium Active Member
    236
    110
    manchester
    Strange. After I had new cat and sensor (same reason) I'm under the impression that I get a bit more. Aftermarket parts as well.
    It's probably just psychological . . . . .
  8. Pezzie
    Pezzie New Member
    Seattle
    I also had my cat and O2 sensor replaced. City mileage dropped approx. 8mpg!!! Highway mileage dropped just 3mpg or so, if that.
    Toyota never warned me about this. I called the dealer when it got ripped out by thieves. Only after I had it replaced by my standard mechanic did the dealer then say “Oh yeah, that happens with the after market. It’s illegal to resell your Prius in California now.” Um what?
    Naturally, with no info at the get go I chose the$1200 fix to replace vs Dealer’s $2900 one.
    Toyota needs to offer catalytic converter replacement and cat guards at reduced cost. Older Prius’ are sitting ducks.
  9. shane fast
    shane fast New Member
    Washington
    Is Denso the OEM manufacture for the 02 sensors? Does anyone know.
  10. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    Yep.
