It's Here! Lexus New RZ 450e
Discussion in 'Lexus Hybrids and EVs' started by drash, Apr 20, 2022.
  1. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Highlights from the news release:
    • Total HP: 308 (230kW)
    • Front motor: 201 hp (150 kW) :whistle:
    • Rear motor: 107 hp (80 kW) (n)
    • DIRECT4
    • Battery: 71.4 kWh :whistle:
    • Mfg estimated Range: 225 miles (362 km)
    • "Driver and passenger comforts include radiant heaters" - where have I heard that before
    • Available panoramic sunroof with "Lexus-first, available dimming function" - Venza??
    • Available HUD
    • Expected to go on sale end of 2022
    You can read all about it here:
    MEET THE ALL-NEW LEXUS RZ, THE LUXURY BRAND’S FIRST BATTERY EV - Lexus USA Newsroom
    Even uses the same dial shifter as the BZ4X. Reads a lot like the BZ4X and Subaru Solterra. Except they are using a small motor (exactly the same as the AWD BZ4X and Solterra - including the use of eAxle) on the back and a larger motor in the front (exactly the same as the FWD BZ4X). What do you want to bet there are going to be many drive comparisons between the Subaru designed system on the AWD BZ4X/Solterra and the DIRECT4. No charging info. I guess they are not going with the CATL battery.
    51,583
    ah, finally an ev for the people, as john1701 is wont to say
    TGrracie, Trollbait and drash like this.
  3. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Size wise, this slots somewhere between the RX and NX. Slightly longer and wider than the bZ4X but has the same wheelbase so the wheelbase is longer than the RX. Same horsepower as the RX 450h, but without the noisemaker, and slightly more than the NX 450h+. Might be a push as to luggage space compared to the bZ4X. Loses a little luggage because of that double wishbone rear suspension but gains it back because of it being longer (> 4 inches) and wider (> 1 inch) than the bZ4X. Not as high but it's probably not going to have the ground clearance the bZ4X has. I would assume it'll be in the 6+ inch range. Target audience is probably not off-roaders.
  4. Mendel Leisk
    41,024
    Garish front snout, massive low-profile wheel/tires, go-cart steering wheel, touch-screen controls in the middle of the dash, what's not to like.
    Is it impossible for those guys, to reign themselves in??
  5. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Looking on their Canadian, European and Global sites, not much else can be gleamed from their respective news releases except for the following:
    • The yoke steering wheel with it's steer-by-wire will be available in the US and Canada at a later time - it is called One Motion Grip in Europe
    • 0 to 100 km/h ( 0 to 62 mph): 5.6 seconds Europe/5.4 seconds China
    • Online reservations for the RZ 450e is available now in Europe.
    • No mention made of a Solar Roof option like you can find for the bZ4X
    MEET THE ALL-NEW LEXUS RZ, THE LUXURY BRAND’S FIRST BATTERY EV | Lexus Canada
    WORLD PREMIERE OF THE ALL-NEW LEXUS RZ
    Lexus Unveils the All-New RZ, the First Pure Battery EV for Global Markets | Lexus | Global Newsroom | Toyota Motor Corporation Official Global Website
    Tideland Prius likes this.
  6. Tideland Prius
    16,508
  7. Trollbait
    12,448
    "While there are four levels of regenerative braking in the RZ the systems weren’t fully online in the prototypes on hand. Regenerative braking will only come from lifting off the accelerator and the brake system is friction-based only. There will be no one-pedal driving mode according to Wantanabe, as philosophically the company wants to keep the operation of the brake pedal and accelerator fully split."
    Does that mean no control over the regen rate except for the 4 defined levels?
  8. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Well kind of. Just through the paddle shifters. Same as the NX 450h+ or any of the h hybrids from Lexus, such as my NX 300h. But at least you don't have to shift into S like you do on the hybrids before using the paddle shifters which is a pain.
  9. Trollbait
    12,448
    I assume those Lexus hybrids are like my old 2005 Prius in having blended regen braking control through the brake pedal. From what I quoted, it sounds like this BEV's brake pedal will only control the friction brakes.
    At least, they give you paddle shifters for the regen.
    Then the hybrids work differently than the ICE models. I could use the paddle shifters in my Camry without having the transmission in S. The car would shift back to D from a selected gear when stopped when it wasn't in S, but otherwise, you had full use of the paddles.
    drash likes this.
  10. Tideland Prius
    16,508
    Seems like it. And no blended regen (like Tesla).
    That's weird. I mean, the RZ isn't a sports car so why the need for friction-only brake pedal action? Even Porsche managed to develop blended braking with the Taycan.
  11. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Since it is being built on the same line as the bZ4X and Solterra I’m pretty sure they will be using blended mode as the engineer indicated they haven’t activated them yet for the production models.
    Sorry for the error but you are correct, doesn’t need to be in S to use the paddle shifters. I tried it last night for the first time as we were going down a long steep hill. Worked to brake the car quite well. The NXh has the smoothest blending of any hybrid I’ve driven when using the brakes. Coasting, unlike my previous 3 Prius, supplies very little to regen and coasts like a typical car.
    iPad ? Pro
  12. Trollbait
    12,448
    A misunderstanding in the article can't be ruled out.
    Then again, as I understand it, the Model 3 has the means of blended braking in place, but Tesla chooses not to use it. What is the braking norm of domestic BEVs in the Chinese market?
  13. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Here's a prebrochure (not sure that's a real term) for the RZ 450e.
    https://www.lexus.com/content/dam/lexus/documents/brochures/models/2023/MY23-Lexus-RZ-PreBrochure.pdf
    Some new info:
    • 18" wheels will get you up to 225 miles (362 km) in EV range
    • 20" wheels yields up to 200 miles (322 km) - both are manufacturer estimates
    • 312 hp (233 kW) - a touch more than the original 308
    • 5.2s 0 - 60 mph
    • ECVT - :eek: huh? In an electric car? Maybe that's why it's called a prebrochure.
    • Two trim levels - Premium and Luxury plus some packages and options listed
    • Still lists the 71.4 (Panasonic) battery but curiously doesn't list the DC Charging speed of 150kW.
    These will be pretty rare for a bit as most of these will disappear into Europe and China.
  14. Trollbait
    12,448
    I didn't see anything at all about DC charging in that prebrochure.
  15. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
  16. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Lexus Canada releases 2023 Lexus RZ 450e pricing. 2023 Lexus RZ 450e Signature starts at $64,950 then moves up to the Luxury trim for $73,550 and the Executive trim for a cool $80,950. Manufacturer range estimate is 360 km (224 miles) with 312 hp pushing it from 0 to 100 km/h in 5.4 seconds. It has the Panasonic battery of 71.4 kWh (raw, not net), and leaves out recharging speed. Couldn't find the corresponding Lexus Canada announcement except for the media announcement:
    MEDIA ADVISORY: THE ALL-NEW 2023 LEXUS RZ 450e MAKES ITS CANADIAN DEBUT AT THE MONTREAL INTERNATIONAL AUTO SHOW | Lexus Canada
    https://motorillustrated.com/2023-lexus-rz-pricing-announced-in-canada/109249/
  17. Trollbait
    12,448
    Surprised if it charges faster than the bZ 4X FWD.
  18. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Found the Canadian Press Release:
    WELCOME TO LEXUS LUXURY, ELECTRIFIED: THE ALL-NEW 2023 LEXUS RZ 450e | Lexus Canada
  19. Tideland Prius
    16,508
    What’s the wait time in Canada? 5 years? :ROFLMAO::ROFLMAO::ROFLMAO: Or never (like the bZ4X and RAV4 Prime which they aren’t taking orders for)
    drash likes this.
