Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tideland Prius, Sep 28, 2018.
  1. EH6TunerDaniel
    55
    29
    Good luck on your swap. Its one of the easier swaps I have done. I also have a 2000 MR2 spyder with a honda K20 swap and turboed. 520 whp.
  2. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    i have done it on my 2010. Had alot of fun because the car was used near the coastline so there was alot of corrosion and 3 of the 9 head of the bolts broke off.
    I am doing it on prius v wagon. I might do the 4th gen egr modification depending on the time.
  3. EH6TunerDaniel
    55
    29
    Ah ok. I kept my gen 4 egr stuff in a box for possible future but the engine I bought did not come with the gen 4 exhaust mani.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    You can keep the gen 3 exhaust. Just have to bend the pipe thats coming off of exhaust manifold and going to the egr cooler.
    Here is the video of it
    vvillovv likes this.
  5. Mendel Leisk
    42,259
    In other words using the fourth gen EGR components, with a mod to the 3rd gen exhaust manifold? IIRC @RightOnTime is associated with a shop that HAS done this. Still, I've heard it can be problematic: the 3rd gen ECU doesn't know there's 4th gen EGR in there, and...
    Are you talking about head bolts? Considering how deep they are in the engine, I can't see coastal air effecting them. Either way. Gasket Masters has a video on dealing with stubborn head bolts:
    #1045 Mendel Leisk, Apr 20, 2022
  6. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    the bolts that hold engine to the transaxle. I dont know what you would call them specifically.
  7. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    I just bought 2019 engine with 30k miles. My mechanic will start working on it this Saturday. Did you start the swap process?
  8. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I have so far took off connectors, air intake and the wiper assembly. i am working full time with college so doing it here and there.
    next up is exhaust and then the main engine bolts
  9. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    @Ragingfit @EH6TunerDaniel
    so the engine i bought has new oil pan with toyota parts sticker. So do i need to do anything special since the oil pan was off.
  10. EH6TunerDaniel
    55
    29
    Not really just don’t forget to fill with oil and check for leaks.
  11. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Yup i filled it with oil, the drain bolt didnt come with it so i am guessing they probably cross threaded the bolt on the old pan
  12. EH6TunerDaniel
    55
    29
  13. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Everything is put together and added coolant. I am getting P3190 and P148F code. The coolant goes to 250F and after 242F it flashes overheating sign till the coolant temp goes down
  14. EH6TunerDaniel
    55
    29
    Sorry if you have already said so, but did you do a new thermostat? When these engines sit at the yards they will get stuck. I would also make sure its burped and the coolant lines are routed correctly.
  15. ChapmanF
    18,956
    The "Elec Water Pump Spd" doesn't look very close to the "Elec Water Pump Target Spd".
  16. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Do you think the impeller has separated ?
    I used whatever it came with. The engine had 8,000 miles and water pump was removed to make space for putting the engine. I had my tank raised and the car was in maintenance mode for 40 minutes before it overheated
  17. EH6TunerDaniel
    55
    29
    Replace your thermostat. Always use a new thermostat when installing an engine. Water pump SHOULD be fine with only 8k but who knows. You can inspect the water pump when you have the Tstat off to replace it.
  18. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Get the car running again until the radiator fan turns on. Then physically touch both upper and lower radiator hoses to check to see if both hoses are the same temp.
    If not - you are having issues with a bad water pump, thermostat and or correct routing of the coolant lines.
    I would suggest if you have Techstream, to run the water pump through utilities and check propeller speed. That is the last thing you want to go out on you
  19. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I cracked open the temp sensor where the bleeder valve used to be. Have techstream connected. The temp goes to 203 which kicks on the fan for few seconds then goes down to 199 and fan turns off. Its on maintenance mode for 30 min now and outside temp of 85 degree fahrenheit
    am i in the clear now? Both radiator hoses feel the same.
    RightOnTime likes this.
  20. Jama707
    SACRAMENTO, CA
    So no more codes?
