Is there a kit that would auto start the car if the 12 volt battery gets below a certain level?
Discussion in 'Prius v Accessories and Modifications' started by chuckers, May 12, 2022.
  1. chuckers
    chuckers New Member
    2013 Prius v wagon
    Failing all of that rather complicated stuff with getting a remote start system set up to charge my battery when low, maybe there is a kit that would auto start the car if the 12 volt battery gets below a certain level? That seems like it should be rather easy to do, maybe...?
    Is there even an easy way to make sure that interior lights, when left on, are automatically shut off so they don't run the battery down? I am still dumbfounded that this isn't a feature that isn't fixed in all cars and as common as keyless entry etc because it seems so simple but causes so many problems
    Thanks for helping me out!
  2. Air_Boss
    Air_Boss Senior Member
    3,908
    1,065
    New Yawk
    If there were a “start to protect” function, the end result would be a duff HV, a duff 12V aux, and an empty fuel tank.
    #2 Air_Boss, May 12, 2022
  3. rjparker
    7,566
    4,437
    The easiest thing to do to protect your 12v battery from camping loads is to install a second larger 12v battery along with a rv style battery isolator. Then run the loads off the second battery. However this is useless if you want to keep food refrigerated or continuously run some other significant load. The second battery, when fully charged, is unlikely to stay charged more than a couple of hours under a refrigerator type load. After an initial 12v battery discharge, the car needs to run for many hours in Ready to recharge it. So the only reasonable answer is to leave the car in Ready.
    Autostart based on 12v status is not easier than the remote start. Basically it would be a function added to a remote start. Probably harder and riskier since now you have a weaker 12v battery. Even if a custom autostart was installed, the car would be running several times an hour since the hv battery in Ready is required to charge the 12v battery. Once the hv battery discharges, the engine starts but only partially recharges the hv battery. Since the hv battery is only partially charged, it discharges very quickly as it remains in Ready with your camping loads. Which is the reason RVs have gas generators to provide electricity for continuous loads without shore power.
    A Prius can be a gas driven electric generator on its own. If in Ready. So the only reasonable answer is to leave the car in Ready.
    Lights go off automatically except for the hatch light. Take it out or leave it switched off. The map lights will stay on if you manually turn them on so don't do that. The headlights will stay on if you manually turn them on with the vehicle off. This concern goes away if the car is in Ready.
    #3 rjparker, May 12, 2022
    chuckers likes this.
  4. Leadfoot J. McCoalroller
    6,798
    6,451
    Pennsylvania
    2018 Prius c
    Timed or measured starts are possible, but trickle chargers are dramatically cheaper and don't have any unexpected carbon monoxide liability.
    You can also get cut-off switches to isolate the battery and at least certain models of the Prius have a very easy disconnect built into the native battery terminal.
    Ordinary cars are built to be operated a few times per week because that's what most people want out of them, and they're generally fine with that pattern of charge and discharge. If you expect something different, adaptation is needed.
    chuckers, Mendel Leisk and Zythryn like this.
  5. bisco
    48,945
  6. Mendel Leisk
    38,207
    @chuckers what’s your parking situation; could you manage a charger?
  7. ChapmanF
    15,068
    Small refrigerant-cycle fridges made for cars and RVs can get their consumption down around a couple amps or less (average of the on/off cycling, steady state) once they have cooled down and are holding temperature. (Their literature sometimes calls this figure "amp hours per hour", which of course is just amps after you cancel the hour/hour.)
    The car's OE battery is only around 45 amp hours, but if you're talking about some larger deep-cycle RV/marine second battery in the 100 amp hour ballpark (and say the fridge is your only load on it when you're away), you could hope for close to four days of that if you absolutely had to. Naturally, this is where you'd normally apply a generous safety factor and try never to be away for more than a day or two.
  8. rjparker
    7,566
    4,437
    He did say he was going to live out of the car, so my points are primarily focused on what happens when the 12v battery is discharged.
  9. vvillovv
    vvillovv Senior Member
    3,529
    1,241
    NY
    Automatic systems can fail too and leave you stranded without notice.
    My take on 12 volt battery health is to use a multimeter and measure the battery's voltage one a week. after learning what kinds of load it's being exposed to on a daily basis and what voltage range the battery typically experiences.
    After you lean the typical voltage range, the monitoring is not to inconvenient.
    I've never heard of a 12 volt kit to automatically monitor and than also make sure the 12 volt battery doesn't get too low a voltage reading.
  10. fuzzy1
    10,039
    While not a full solution, you can greatly improve this situation by replacing the original incandescent lamps with low current LEDs. When carefully selected for low current in light-efficient configurations (i.e. unidirectional emission appropriate for the particular fixture, not stadium brightness omnidirectional lamps that waste most of their light inside the fixture), you can slash the current draw by a factor of 10. This greatly extends the time available to discover an accidentally left-on light before it causes a drained battery. With these LEDs, a light left on overnight or all weekend won't prevent the car from starting.
  11. chuckers
    chuckers New Member
    2013 Prius v wagon
    I think I'd be fine with that hah. I wish it would let you do it for x number of times that you decide yourself. I'm sure my use is quite niche though
  12. Leadfoot J. McCoalroller
    6,798
    6,451
    Pennsylvania
    2018 Prius c
    LED light conversion does help a lot- we used to have problems with my wife leaving a door open on the old car, and the battery would die before she got back to it. LEDs fixed that.
    You can also do appliance-side fixes for the fridge. I've got a portable refrigerator that can be set to stop working when input voltage drops below a user-preset threshold. It will also stop at a lower, non-adjustable point to prevent damage related to overcurrent operation.
    fuzzy1 and chuckers like this.
  13. chuckers
    chuckers New Member
    2013 Prius v wagon
    Thanks for the useful information, I'll try to incorporate all of that information into my build!
    Quick questino to you all, do you know why there aren't any monitors for batteries that keep them from shutting down? Or failing that, why don't they build in a backup or use the extra gazillion watts of power still wating to be released in the HV battery?
    It just mystifies me how many people I've seen needing to get a jump over the years, no matter how fancy the car. I figured they would have some options similar to what i've mentioned or at least timers to shut them off automatically(not the 30 second timers etc) or anything to keep people from getting stranded or late for their job etc.
    I mean they have all different kinds of options for even cheap cell phones once the battery gets down to a certain limit it does all sorts of cool things to minimize battery loss. I'm sure there must be a reason, I just can't think of it.
    Thanks!
  14. chuckers
    chuckers New Member
    2013 Prius v wagon
    I will not have access to any external power sources most of the time unfortunately.
    I was just thinking of getting some LEDs. I really would like some rather bright ones since I will be digging around through all my stuff, but I would also like to get some efficient ones that are unidirectional like you speak of. Or maybe just some low power ones so I don't run down the battery and find a way to hook a light to the ceiling that doesn't connect to my battery and drain it ha
    I've looked at a lot on amazon that were recommended from here a long time ago but didn't know if there's a good source people like on here now.
    Do you know of a good brand or where is the easiest to start looking for cheapish ones that I won't have to worry about them blowing fuses like i've read about etc?
    Thank you!
  15. Leadfoot J. McCoalroller
    6,798
    6,451
    Pennsylvania
    2018 Prius c
    Lots of cars have things like that, but there isn't anything universal. They all came up with different ways to keep the battery from running down. I don't know of any that will actively recharge, but there are several that open a relay and cut power after a few minutes.
    Every Prius came with an owners manual that says (among other things) "disconnect the 12v battery if you are doing service that requires leaving the doors open for a long time"
    ...guess what still happens at detail and tint shops every single day?
    There's not much wisdom to hand down on these because the stock turns over so fast. What was good last week is bad this week, and unavailable next week. So unfortunately everyone needs to try a few for themselves. I found some that work in our car but you can't get them anymore, so it's pointless to offer a recommendation. Good luck!
    chuckers and fuzzy1 like this.
  16. BiomedO1
    1,315
    719
    SacTown, Ca
    IMHO; Lithium Jump pack; plugged into your cig. lighter - under your front seat. It's available whenever you need it, you avoid all the tinkering, which would add additional draw to your battery and will cost less (time & money) than your experimental system. You'll be able to charge your cell phone and other small accessories.
    chuckers and arjay007 like this.
  17. rjparker
    7,566
    4,437
    There are monitors that report your 12v status back to a cell phone. They require wifi to work. You can also install a battery isolator that will disconnect a second battery from the primary 12v battery. This is a low cost rv solution normally used with second batteries to supply camping loads.
    It would be possible to have a low battery alarm module installed for a local alert but a battery isolator (known in other applications as a low voltage disconnect) is better for unattended use. The rv versions disconnect after the charging voltage lowers because the vehicle is shutdown.
    A lithium jump pack is a good solution under $100. You inadvertently discharge your 12v and it allows the car to start. It does not help your continuous refrigeration problem.
    An expensive lithium 12v battery can have a second failsafe battery built in that can be used to start the car after discharging the primary section. The Antigravity brand is around $820 with wireless jumpstart. They don't sell one with the Prius battery form factor but you could get a Corolla version and adapt the terminal connectors. I might consider this option for a second 12v battery with a separate battery isolator. You might get several days of refrigeration runtime from the Antigravity battery alone. Recharging it is another story without shore power.
    The Prius programming is setup to avoid a high voltage battery discharge. Which would happen if the vehicle kept the 12v battery charged when the rest of the car was off. The high voltage battery can not be jumped or even easily accessed. If discharged the car must be towed to a qualified dealer for a several hundred dollar high voltage battery charge. Hopefully it is still good as a new hv battery is several thousand dollars. The Prius hv battery is actually rather small compared to a plug in version or any ev.
    Remember your problem is how to charge the 12v battery before you can not start the car. With no shore power, you have to use a generator of some sort. The Prius has one designed to charge the 12v and is able to run most 12v loads. It can also cool and heat the car but it has to burn gasoline several times an hour to do so. That means leaving the car on. Manually turning it on and off based on some alert will not work well. Once the 12v is discharged it can take hours to recharge it.
    #17 rjparker, May 13, 2022
  18. fuzzy1
    10,039
    These cars are designed for safety, to prevent mechanics and emergency first responders from getting electrocuted, without having to learn a whole new set of electrical safety protocols. They already know how to disable the 12V systems for their own safety. These high voltage systems are designed so that taking down the 12V, also takes down and isolates the HV within the battery case.
    chuckers and Air_Boss like this.
