2016 Prius Temp light came on today
Discussion in 'Gen 4 Prius Technical Discussion' started by Bamapse, May 17, 2022.
  1. Bamapse
    Bamapse Junior Member
    48
    NorCal
    To start with i have a 2016 Prius Touring 4 with 88k Miles and this evening I was driving my normal highway route home at about 65mpg and not accelorating much at all and the red engine overheat indicator light started flashing and stayed. I started slowing to about 45 mph and it it then turned off. Sped back up quite slowly to about 55mph and it turned back on. I ended up exiting and limping it home trying to keep it in EV mode as much as possible and after exitting the highway, the light did not return. Temperature was about 65 degrees F so no issue there. I just checked engine, resevoirs and oil and no apparent leaking anywhere. The coolant res was indeed very low but hybrid system coolant res was full. No obvious sign of coolant in oil either so not really sure what happened to about 2/3 of a resevoir of coolant. I did a search here and didn't find any similar issues outside of one coolant in catalytic converter post. My inclination is to just refill and monitor level and temp light. Thoughts from the pros? Lastly, wanted to confirm that I can mix the prestone "red" asian coolant with factory toyota coolant. I have some here and would love not to buy more toyota coolant if they are mixable
    #1 Bamapse, May 17, 2022
    Mambo Dave likes this.
  2. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    It happened to me and was fixed for free...
    I would not mix the coolant...
    Mambo Dave and alanclarkeau like this.
  3. Bamapse
    48
    NorCal
    Hope i am as lucky. The dealership here is giving me the run around on it
  4. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Ditto; NEVER mix coolants - a chemical reaction may occur, gumming up your entire cooling system. Always go with OEM coolant or distilled water.
    Have them pressure check your coolant system. This will tell you if your system has a leak; but NOT where the leak is. If it passes the test; just top-off and keep an eye on coolant levels for the next month or two. Check every gas fill-up minimum.
    The level may go down a bit again; possible air in your cooling system being replaced by coolant. Top-off with distilled water. If it goes down a third time; the dealership didn't do the pressure test correctly - take it somewhere else and get it pressure tested again.
    2016 and early 2017 had a TSB on the exhaust heat exchanger leaking - it's warrantee work - don't let them sell you something.
    Hope this helps.
    #4 BiomedO1, May 18, 2022
  5. ChapmanF
    18,457
    There seems to be an issue with the exhaust heat recirculation system (EHRS, not to be confused with EGR) system in some Gen 4s leaking coolant into the exhaust.
    It puzzles me, because Gen 3 already had EHRS for six years and that system seemed to have no such common issue.
  6. Bamapse
    48
    NorCal
    Well it looks like I am getting screwed because the federal emissions warranty runs out at 80,000 miles and I now have 88,000 miles :-( any advice on how to deal with the dealer to get them to cover it?
  7. bisco
    52,286
    call toyota and ask for goodwill warranty
  8. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    I had the same issue, dealership told me it was a blown headgasket and tried to sell me whole a new engine. I took it to a private shop for a second opinion and sure enough, it was the exhaust heat exchanger. I was over the 80k mile limit for Toyota to fix it (and I didn't trust the dealership with my car after they grossly misdiagnosed the problem) so I coughed up the cash for the repair at the private shop. Most of the pricetag was the part.
  9. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The TSB mentions CA cars have emissions warranty through 180 months/150,000 miles
  10. BiomedO1
    4,019
    2,109
    SacTown, Ca
    NO; that's the Federal mandated minimum warranty. If your still in Ca.; your covered out to at least 150K miles and 15 years. Check here: 2016 Toyota Prius Manuals & Warranties | Toyota Owners and here: California Vehicle and Emissions Warranty Periods | California Air Resources Board
    Hope this helps.
    If all else fails; you can simply loop-out the exhaust heat exchanger. It may take a bit longer to heat the cabin, but it'll save you a lot of out-of -pocket money.
  11. Mukunda
    Mukunda Junior Member
    67
    I own 2016 Prius at 46K (Sep 2022) Dealer replaced Exhaust pipe assembly(using this TSB - T-SB-0135-19) as there was recall.
    after 6K later- now at 51K(March1st 2023) . Coolant light on and then engine stopped on highway.
    I towed my Prius to Dealer.
    Now it gave below codes and dealer said engine is overheating and needs new engine and Water Pump.
    P00B111
    P011511
    P148F AND P319000
    Please guide if above codes really says Head Gasket or something else.
    Looks like tech at Dealership are not knowledgable at all. They just gave codes and washing off their hands.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    There is no code for head gasket failure; it's a process of elimination. Start with the water pump replacement and watch the coolant levels for the next few weeks.
    Who did the 50K mile service; they should've noticed the low coolant level.
    Also check the engine coolant sensor and wiring for corrosion or something chewing on your wiring harness.
    Hope this helps...
    #12 BiomedO1, Mar 5, 2023
  13. Mukunda
    67
    Dealer who did oil change and warranty fix (at 46K) of Exhaust pipe said they are draining the coolant to fix exhaust pipe replacement.
    I can fill the coolant later, they are filling minimum required.
    Here is the service record at 46K when they did Exhaust pipe Guarantee work. upload_2023-3-5_13-18-35.png
  14. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Toyota recommends 5K mile maintenance intervals; especially if you don't know how to do it yourself!!! I've taught my kids how to check under the hood and what to look for at least once a month or every other gas fill-up. That way they can avoid expensive repair bills.
    Find a honest Prius mechanic to help you out. If it's the exhaust gas heat exchange again; you're probably out of warranty. Texas is not a CARB state, and I don't know what your consumer rights law covers over there.
    Point is that you need someone else to look at it, to determine what the problem is. It could be as simple as a coolant leak that you didn't notice. Hopefully the engine wasn't destroyed by the overheat. If you kept driving with the temperature warning lamp lit, rather than pull over right away - the likely-hood of damaging the engine increases exponentially.
  15. Mukunda
    67
    hmm
    they replaced Exhaust pipe saying it is under warranty recall.
    Looks like Toyota dealers has to comply Toyota standards of 1 year coverage for any repair they did.
  16. Mukunda
    67
    Dealers & even Valvoline etc are setting the timer for oil change for 3.5K.
    As soon as Maintenance required light blink I take it to oil change
  17. BiomedO1
    4,019
    2,109
    SacTown, Ca
    1. Can you prove that the exhaust gas heat exchanger failed again?
    2. I don't know of any automotive repair shop that will give anyone a 1 year unlimited mileage blanket warranty on everything. Just because they looked under the hood. Please post that 1 year coverage claim.
    3. What does 3.5K mile oil changes have to do with your current issue. Your maintenance lamp goes off every 5K miles. If you want to take your car to a mechanic every weekend; your free to do so - but it may be hard on your wallet.
    #17 BiomedO1, Mar 5, 2023
  18. Mukunda
    67
    This what Toyota Customer service told me when I called them.
    If any warranty repair is done. if same issue pops up again dealer will cover upto 1 year.
  19. Mukunda
    67
    T-SB-0135-19 - clearly give details check for coolant leaks into Exhaust pipe.
    warranty repair they did is based on T-SB-0135-19.
  20. Mukunda
    67
    Yes that kind of report I was expecting from dealer.
    but dealer did not provide any info.
    They just said engine is over heating needs to be replaced.
    Only thing they mentioned is pump also has to be replace.
    They did not mention anything about coolant.
    Dealer (Richardson , TX Toyota) just provided estimate of repair with diagnosis codes from CEL.
    nothing more than that.
    This is all I got from Richardson , TX Toyota Dealership for a 51K mile 2016 prius.
