prius mods
Discussion in 'Gen 2 Prius Accessories & Modifications' started by slow95gt, Nov 14, 2006.
  1. slow95gt
    slow95gt New Member
    Ite im new here, but who has the fastest car on here (prius)? and who all have you beaten on the track or either the street?
  2. cephalicprius
    cephalicprius New Member
    <div class='quotetop'>QUOTE(slow95gt @ Nov 14 2006, 08:27 PM) [snapback]349223[/snapback]</div>
    hey there man, im new here two, but i have a base 05 prius and i must say, it aint that bad. prius' respond quite well to modifications.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Prius ain't a drag racing car. We race with fuel consumption, baby.
    ...oh, and don't feed the trolls.
  4. cephalicprius
    <div class='quotetop'>QUOTE(Presto @ Nov 14 2006, 09:24 PM) [snapback]349257[/snapback]</div>
    trolls, what
  5. silentak1
    silentak1 Since 2005
    893
    28
    LA
    You can dump $7,000 into a custom-turbo and you probably won't even beat a V6 Accord. Shortly put, this is the wrong car if you want to pull anything close to 14s on the 1/4 mile.
    I can tell you that my Prius is probably slower than a stock Prius because of all the modifications (added weight). Heh..
    Beat people on the curves with some tire upgrades. Apex, apex, apex.
  6. GreenSpeed
    GreenSpeed New Member
    201
    Yeah... I've said it before... If you want fast... Get an Evo. Absolutely the cheapeast way to get a fast car. Plus it'll do the groceries and seat five. I've seen an Evo pull a 9.75 on the 1/4 mile. Gonna get one of them soooon... heh, all the money i'm saving from gas with the Prius will goto that. Yay!
  7. slow95gt
    slow95gt New Member
    No dont get an evo they are way too expensive, and if you sneeze on the engine it voids the warranty. 89 lx notch $3500, hellion turbo kit $4500= low 11's.
  8. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Measuring performance with only a dyno and a chronometer is so Twentieth Century.
  9. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    I measure my performance when I'm horizontal.... :)
  10. Tideland Prius
    16,634
    <div class='quotetop'>QUOTE(slow95gt @ Nov 14 2006, 05:27 PM) [snapback]349223[/snapback]</div>
    Ok, assuming you want an honest answer.
    Do the opposite. Strip the rear seats, replace the front seats with recaros (or sparcos) and just copy the SCCA Prius. It has wedsport 17s on slicks, a rollcage... I'm sure it has front and rear braces.
    If you're technical enough, replace the engine with the one from the Echo. It's the same engine but runs on the Otto cycle instead so you do get more power (Toyota got 143hp from its Prius GT).
    Doing the aforementioned mods will drop it to 8 secs to 60 (That's Toyota's time for the Prius GT). Other than that, replace the front suspension with a lighter set for sure. It is quite nose-heavy. Replace the rear hatch with a CF frame and plexiglass, remove the spare tyre, box, tonneau cover, floor etc.
    Anything else?
