ATF drain and fill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, May 20, 2022.
  1. nicoj36
    nicoj36 Active Member
    495
    156
    Changed my ATF on the 2012 today and the fluid came out in silver color. Has anyone experienced this before? This is the first time I've seen my ATF in silver. Usually it would just be dark brown or black. Let me know.
  2. PriusCamper
    PriusCamper Senior Member
    10,897
    4,418
    Pacific Northwest, USA
    Any loss in MPG or other symptoms? Is the lighting different than normal? Did you check in different lighting? Send Pics please!
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,124
    2,181
    Taylors, SC
    If you still have it, I'd have it analyzed. Silver is strange, It might be aluminum particles.
    Limey Geoff likes this.
  4. nicoj36
    495
    156
    No mpg loss, different lighting same, don't have pics because I drained it into a bucket of other oils and it got mixed
  5. Mendel Leisk
    38,214
    How many miles on the fluid, and has it been changed before?
  6. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Maybe this is why? Some kind of chemical reaction?
    If this is not the first draining of the transaxle, which is usually very dark red, then it usually comes out much lighter, red, not very dark in colo(u)r.
    I put that u in color for Mendel.
    Foxglove and Mendel Leisk like this.
  7. Georgina Rudkus
    3,124
    2,181
    Taylors, SC
    The difference between the old and the new should liik something like this; 9.jpeg
    xliderider likes this.
  8. nicoj36
    495
    156
    No that isn't why. I looked at the fluid that was draining out, not the one in the bucket.
    The fluid only has 20k miles and this is the 2nd time I've changed it. I did it sooner to drain more old-fluid out from the 1st one because drain and fill doesn't really drain everything out and there's a little left in the pan. That's why I was surprised that the fluid looked silver, it only had 20k miles.
  9. nicoj36
    495
    156
  10. Mendel Leisk
    38,214
    You’re using Toyota ATF WS?
    nicoj36 likes this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
  12. nicoj36
    495
    156
    Yes ATF WS from the dealer
  13. OptimusPriustus
    OptimusPriustus Active Member
    308
    130
    Finland
    There’s gotta be lots(!) of metal particles to make oil look silver color. That much metal does not come off without symptoms of some kind (sound, vibration, fault codes etc). Why you proceeded to change oil in the first place? Our atf oil was replaced first time at 130k miles. I think these transmissions can last very long with factory oil since there’s nothing to wear except bearings
    edit: when you made first change you are sure you put in correct amount?
  14. xliderider
    7,848
    3,102
    Honolulu, HI
    At only 20K on the once changed transaxle fluid, it should look pretty much like fresh fluid, like the one Georgina Rutkus posted above, on the right.
