Brakes
Discussion in 'Local Prius Club Main Forum' started by grnbean, Dec 18, 2009.
  1. grnbean
    grnbean New Member
    When (at what mileage) did you get your brakes replaced? and where? and how much was it?
  2. qbee42
    3,079
    Front brakes are usually good for over 100,000 miles. Rear brakes last almost forever.
    Generally, with the Prius, rust will kill your brakes before they actually wear out.
  3. grnbean
    grnbean New Member
    wow good to know!
    i ask just because my brakes are squeaking occasionally when i slow down to exit freeways
    i'm currenty at 38,000 miles and i don't feel any warping/pulsating feeling yet...only the occasional squeaking
    hard to believe that my brakes are gonna last me till 100k
  4. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Could what you hear as squeaking just be some regen braking sounds?
  5. grnbean
    grnbean New Member
    no. for sure it isnt the regen
  6. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    Mine were still looking good at 118,185 miles when I traded up for a 2010.
  7. qbee42
    3,079
    Noisy brakes are common on the Prius. The problem comes from lack of use. Unlike a normal car, the Prius brakes get so little use that they tend to rust.
    If your brakes get noisy, an easy fix is to exercise them a bit. Find an open stretch of road, drive up to 40 mph or so, shift into N, and brake until you slow down to around 20 mph. Shift back into D and repeat the process a few times.
    Braking in N defeats regenerative braking, which forces the Prius to use the friction brakes.
  8. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Reviving an old thread but it's appropriate here after a quick search of "brakes".
    Getting my first rear brake job tomorrow after 191,000 miles. Dealer quote is $395 installed for OEM parts. Just another part of the Prius that makes it such an economical car. :)
    Uberdriver2710 likes this.
  9. Uberdriver2710
    Uberdriver2710 Junior Member
    30
    usa
    Stealerships FTW ! :LOL:
  10. Mendel Leisk
    41,888
    What parts? Just pads? Shims too? Rotors?
  11. Mendel Leisk
    41,888
    Just noticed this, seems topical. According to the Car Care Nut, the dealership have two levels of Toyota brake pad quantity, original (semi-metallic) or economy (ceramic). Both are ok, but the price varies, and he recommends to ask which they will be using. Video starts at the relevant point:
    Evelyn Shepherd likes this.
