How do you properly Turn off your car?
Discussion in 'Prius v Main Forum' started by jacobson00, May 27, 2022.
  1. jacobson00
    jacobson00 New Member
    New York
    I have a new 2014 prius V. How do you properly turn it off? Do you just press the Power button and everything shuts down or do you press the brake and press the power button? I know to start, you press the power button then press the brake+power button again.
  2. Tideland Prius
    16,548
    On my Gen 3, 4 and Prime, I just press POWER and it shifts to park automatically and shuts off. I just have to engage the parking brake.
    jacobson00 likes this.
  3. Air_Boss
    Air_Boss Senior Member
    4,189
    1,177
    New Yawk
    There is no harm in engaging Park and/or pressing the Brake pedal prior to pressing the Power button off. I rarely use the manual parking brake.
    JohnPrius3005 likes this.
  4. ChapmanF
    18,072
    You don't have to do that to start; you can skip that first step, and just hold down the brake and press power.
    Powering off doesn't require you to be pressing the brake. A lot of the time, though, you will be pressing the brake anyway, because you've just stopped driving somewhere. So it makes sense to power off while you are still holding the brake. The car shifts itself to Park while powering off, so when you let your foot off the brake after powering off, it won't roll.
  5. jacobson00
    New York
    Thank you all for your responses.
  6. bisco
    51,841
    welcome!
    i press the brake, and then push the power button to start.
    i press the brake, and then press park, and then push the power button to turn it off
  7. Pv5
    Pv5 Junior Member
    2013 Prius v wagon
    bisco's method is the same for me.......in my "advanced years" it has been the simplest to remember!! I do apply the "parking" brake as well.
  8. Tim Jones
    Tim Jones Senior Member
    1,755
    565
    SE Texas
    2011 Nissan LEAF
    It's a good idea to let the engine shut off then hit the power button.
  9. Air_Boss
    4,189
    1,177
    New Yawk
    Clankity clank...
    vvillovv likes this.
  10. ChapmanF
    18,072
    The car will start just as happily if you skip that first part, and just hold down the brake to press the power button once.
    djasonw and Air_Boss like this.
