Engine oil Level Low add or replace warning
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jama707, May 29, 2022.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    I’m getting this warning. The oil level is correct just below the top indicator but well above the low indicator.
    Is it bad oil pressure/level sensor? Where it will be on gen 4?
    Thanks
    52,282
    what car , year, miles?
    Jama707 likes this.
  3. Mendel Leisk
    41,824
    Even though it says low level, AFAIK the associated sensor detects just oil pressure. Even though your oil level is ok, maybe there IS a problem with pressure.
    New enough to be covered by power train warranty? Either way, I would take it serious, call dealership before driving further, see what they suggest.
    Jama707 and jerrymildred like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Ditto to what @Mendel Leisk said. I've never seen that message or even heard of it happening, so I'm only guessing that something is starving the oil pump, resulting in occasional brief low pressure conditions or else the pressure transducer is flaking out. If the oil level is near the top mark on the dipstick on level ground, I would have the dealer check it.
    Jama707 and alanclarkeau like this.
  5. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Good luck getting it fixed. It makes me happy that these warnings are built into the screen that way. Much better than a check engine light or a light on the dash that would be easy to not notice right away!
  6. Jama707
    SACRAMENTO, CA
    It’s 2016 has 320k miles and I just bought it from an auction with help of a licensed friend.
    My reasoning for buying this high mileage because I already had an 2019 engine that I bought for 3rd gen swap but never materialized. My mechanic said he can’t/didnt want to do that after I brought him the engine.
    #6 Jama707, May 30, 2022
  7. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Wow that's some serious mileage. Have you pulled a history report from carfax or somewhere to see what kind of service history it's had? Any accidents? I'd be surprised any car has made it that far without something wearing out. Do you have a trouble code reader?
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Wrong oil weight perhaps?
  9. Jama707
    SACRAMENTO, CA
    I replaced the oil and filter with 0w20.
  10. bisco
    52,282
    it's gotta be the pump or sending unit
  11. Jama707
    SACRAMENTO, CA
    Based on carfax it had regular oil change until 160k and had a minor accident report. I’ve run the techstream health check and didn’t get anything related to the engine or its sensors.
  12. bisco
    52,282
    maybe a computer glitch?
    i can't believe toyota would display a warning message and show no codes on tech stream (n)
  13. Jama707
    SACRAMENTO, CA
    Maybe… it doesn’t come up right away the engine starts. It comes up after driving a 2-3 miles. And I press the back button comes back up after a while.
    There is an intermittent problem, I guess.
  14. ahmad zunba
    ahmad zunba New Member
    jordan
    Please till me what was the problem and how you solve it, because I have the same problem in my vehicle.
  15. jerrymildred
    11,517
    14,157
    Tampa, FL
    I'm curious, too, @Jama707. Did you ever get it sorted out?
  16. Jama707
    SACRAMENTO, CA
    Yes. Based on what my mechanic said - the engine had an oil leak and pressure was too low. And also I saw he replaced the engine control module (ECM) that’s next to the hybrid inverter. He got it from a donor car from Rancho Cordova.
    jerrymildred likes this.
